Hello, i am trying to load the android image to my mini2440, while using the chinese guide, but i`ve got the following warning while booting the image: s3c2440-sdi s3c2440-sdi: powered down. input: USB Optical Mouse as /class/input/input2 input,hiddev96,hidraw0: USB HID v1.10 Mouse [USB Optical Mouse] on usb-s3c24xx-1 usbcore: registered new interface driver usbhid usbhid: v2.6:USB HID core driver UDA1341 audio driver initialized failed to get memory region resouce s3c2410-iis: probe of s3c2410-iis.0 failed with error -2 TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. s3c2410-rtc s3c2410-rtc: setting system clock to 2010-04-28 13:29:19 UTC (1272461359) yaffs: dev is 32505858 name is "mtdblock2" yaffs: passed flags "" yaffs: Attempting MTD mount on 31.2, "mtdblock2" yaffs: auto selecting yaffs2 yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem). Freeing init memory: 116K Warning: unable to open an initial console. ... after this warning everything stops and i had a black screen. Are there any solutions for this problem? I am using an A70 display, may cause this a problem, or have i have to change the display driver to see anything? If yes how can i do this? Thanks in advance Blackman
Booting Android
I'm having a very similar problem too. It warns - "unable to open initial console", but before that I have several bad blocks too. Here is my console log: usbcore: registered new interface driver appletouch input: s3c2410 TouchScreen as /class/input/input1 s3c2410 TouchScreen successfully loaded S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver s3c2440-i2c s3c2440-i2c: slave address 0x10 s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter mapped channel 0 to 0 s3c2440-sdi s3c2440-sdi: powered down. s3c2440-sdi s3c2440-sdi: initialisation done. s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). usbcore: registered new interface driver hiddev usbcore: registered new interface driver usbhid usbhid: v2.6:USB HID core driver UDA1341 audio driver initialized failed to get memory region resouce s3c2410-iis: probe of s3c2410-iis.0 failed with error -2 s3c2440-sdi s3c2440-sdi: powered down. TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. s3c2410-rtc s3c2410-rtc: hctosys: invalid date/time yaffs: dev is 32505859 name is "mtdblock3" yaffs: passed flags "" yaffs: Attempting MTD mount on 31.3, "mtdblock3" yaffs: auto selecting yaffs2 block 522 is bad block 641 is bad block 642 is bad block 701 is bad block 1258 is bad block 1286 is bad yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem). Freeing init memory: 116K Warning: unable to open an initial console. I'm using a mini2440 with 256 MB Flash and following steps from - http://my.opera.com/vinodmunikoti/blog/manual-for-compiling-android-for-... to load Android. Thanks in advance, Tara
Hey All, Go here https://sites.google.com/site/belina76/android-booting and you would be able to resolved your problems. flux000
