Hello, is it possible to make the backlight dimmable by hardware pwm port (I think its GPB1) on the mini2440 board? And how must I configure it right in the kernel source (mach-mini2440.c)? I have already tried to set GPB1 as S3C2410_GPB1_TOUT1 and setting the PWM duty but it hasn't worked yet. In a manual for this board it says that GPB1 can be used for modulated LCD power. Only GPG4 is working for me but this port hasn't any hardware PWM controller so I would have to use software PWM and thats not optimal. I use the default NEC35 as display with the On-Board controller. Also I have another problem that the backlight turns off a few seconds after loading the kernel so I have to enable it later in userspace again. How can I figure that out?
Backlight (PWM)
Just must change some resistors; http://www.friendlyarm.net/forum/topic/401
Hmmm... In the post it says that R12 must be removed and R13 must be installed on the adaptor board. But there already is an R13 on it!
Jay, those instructions are for the A70 display. It doesn't look like your display connects the PWM pin to anything on the display. Sorry.
Its a little bit tricky with software PWM (you don't need a hardware pwm port to do this!) but finally I got it: type in serial console for half brightness (depends on the kernel you use but its working for me): echo timer > /sys/class/leds/backlight/trigger echo 5 > /sys/class/leds/backlight/delay_off echo 5 > /sys/class/leds/backlight/delay_on And my backlight is at half brightness! A little bit darker (but flickering a little bit): echo timer > /sys/class/leds/backlight/trigger echo 6 > /sys/class/leds/backlight/delay_off echo 2 > /sys/class/leds/backlight/delay_on Have fun to experiment with this :) There isn't much more system load using this.
Hello Jay, can you post some delay_off and delay_on settings which will give a nick backlight (and hence good screen contrast) ?? thanks!
Dear, Maybe the subject is quite old, but I've read this : "The PWM output (GPB1 can be configured by register as PWM) and reset signal (nRESET) are led out for the convenience of testing. The LCD_PWR is the back light controlling signal." See http://resources.mini-box.com/online/MBD-mini2440+7in-LCD/MBD-mini2440+7... "The LED backlight can be turned on or off or modulated with GPB1. The backlight signal is called LCD_PWR PWM output (GPB1 be sent through Depositors configuration for PWM), and reset signals (nRESET), one of backlight control signals are LCD_PWR." See http://www.andahammer.com/assets/Uploads/All2440/Firmware/Mini2440Essent... I have not understood everything as GPB1 can be pwm, so a modulated signal. So what's the use of LCD_PWR wich is said to be a backlight control signal? Regards
