Hello, I would like to understand the likn between "arm-linux-gcc" and the "linux.2.6.32" kernel... I install successfully "arm-linux-gcc" and i'm able to compile and run the examples. I install and re-compile the linux kernel ( i need gpio ports ) and it was also good ( i make a zImage that run ). For me, in the linux kernel, there is some specificty for the mini2440 ( for me know as BSP ). In the arm-linux-gcc, there is no specificity. My question is how to connect compiler and specific header for gpio ( by using for example "s3c2410_gpio_setpin, s3c2410_gpio_getpin and s3c2410_gpio_cfgpin" functions ... Please can you help me ? Fred
arm-linux-gcc and linux 2.6.32
How did you enable gpio support? sysfs? If so, 1. I would verify that /sys/class/gpio exists 2. Then verify that you can turn one gpio (ie one of the on-board LEDs on and off. Search <gpio> on this site for the method (echo ...). 3. Read http://www.avrfreaks.net/wiki/index.php/Documentation:Linux/GPIO
Hello and thank you for your answer... but my question was to an other point : I dont know how to include linux kernel library into my application : for example, if i make a small test software using "s3c2410_gpio_setpin", "s3c2410_gpio_setpin" will be unknow because i need to include something ! but what !???? Thank you for your help
How are planning to "talk" to the GPIO? From user space or direct kernel calls? The example code on the DVD shows you how to talk to gpio via directs calls to the kernel. The tutorial tells you how to do it using sysfs. As far as I am aware there is no "library" to be included. If you do a Google search (left hand Search button) you should find examples of how to write a C program to call those functions.
This might be more helpful: http://members.cox.net/ebrombaugh1/embedded/mini2440/index.html
Hi davef,
Thank you for your answer, but i'm still not able to compile a sample
application that drive multi-gpio with the function "s3c2410_gpio_setpin"
I include some header that i found on the kernel i re-compile (
linux/arch/arm/mach-s3c2440 ) but i got a lot of compiling errors.
I would like to use this function ( "s3c2410_gpio_setpin" : direct kernel
call : isn't it ??? ) instead of user space ( fopen("/dev/.... : isn't it
??? ), to increase gpio speed : my application need to drive Gpio at 10
Mhz, but i'm not sure that i am in the right way ....
Have you some advices please ?
Thx
Fred
Fred,
I could be wrong, but I thought this is an example of direct calls to the
kernel using ioctl.h
From the DVD
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/ioctl.h>
int main(int argc, char **argv)
int on;
int led_no;
int fd;
if (argc != 3 || sscanf(argv[1], "%d", &led_no) != 1 ||
sscanf(argv[2],"%d", &on) != 1 ||
on < 0 || on > 1 || led_no < 0 || led_no > 3) {
fprintf(stderr, "Usage: leds led_no 0|1\n");
exit(1);
fd = open("/dev/leds0", 0);
if (fd < 0) {
fd = open("/dev/leds", 0);
if (fd < 0) {
perror("open device leds");
exit(1);
ioctl(fd, on, led_no);
close(fd);
return 0;
Can't get to
http://lxr.linux.no/linux
but I recall seeing what you are referring to in the GPIO documentation,
say under one of the recent kernel versions.
Sorry, but I haven't used the GPIO on this machine yet.
Dave
Hi everyone, I also have a similar problem. I have a program main.c and I'm useing a cellular modem that my embedded computer has. The code seems to be good. There is only a few lines but I hava a problem with compiling it. in instruction is : compilation for applications: #arm-linux-gcc -o main -Wall -g -O2 main.c #arm-linux-strip -s main #arm-linux-gcc -ggdb -o main-debug main.c after first line I had this: [root@mariusz moxalib]# arm-linux-gcc -o main -Wall -g -O2 main.c main.c: In function ‘main’: main.c:33: warning: unused variable ‘k’ /tmp/ccKJlaZm.o: In function `main': /home/mariusz/moxalib/main.c:35: undefined reference to `cellular_modem_open' /home/mariusz/moxalib/main.c:39: undefined reference to `cellular_modem_sms_recv_message' collect2: ld returned 1 exit status [root@mariusz moxalib]# What is the reason of such a problem ? Can anybody help me ? Functions cellular_modem_open and cellular_modem_sms_recv_message are defined in main.c I don't understand it. Thank you.
main.c:33: warning: unused variable ‘k’ Just that . . . main.c is not using the variable k. k is often used as a loop counter so maybe a for loop has been removed. Those functions may be defined in main.c but where are they actually located? What #includes have you got at the top of the file?
