Hi Vladimir, As I have a working mjpg-streamer in my mini2440 with your kind support to my queries on the other topic http://www.friendlyarm.net/forum/topic/279 This time I'm trying to add 1 more USB web cam which I bought yesterday. I tried to plug-it in to my usb hub and it was detected in the system. However, I noticed that, only 1 usb web cam is working well which is my old usb web cam (with YUV format) which I bought 6 mos. ago. Anyway, to make the story short, my new USB web cam has a jpeg format. With these 2 different formats of USB web cam the syntax LD_LIBRARY_PATH="$(pwd)" ./mjpg_streamer -o "output_http.so -w ./www -c UsErNaMe:SeCrEt" -i "input_uvc.so -y" only activated YUV format. BTW, my new usb web cam (jpeg format) is working well using ./start_uvc.sh when I tested it alone (plugged in my usb hub) without my old usb web cam. Please advise. Thanks, Puma
mjpg-streamer 2 USB Web Cam
Hello, did you specify the device name for the second camera? Also, you have to use different port numbers. I.e: starting the first camera: LD_LIBRARY_PATH="/home/puma" /home/puma/mjpg_streamer -o "output_http.so -w /home/puma/www -c UsErNaMe:SeCrEt -p 8080" -i "input_uvc.so -y -d /dev/video1" starting the second camera: LD_LIBRARY_PATH="/home/puma" /home/puma/mjpg_streamer -o "output_http.so -w /home/puma/www -c UsErNaMe:SeCrEt -p 8090" -i "input_uvc.so -d /dev/video2" then the first camera will show up on the address http://<your mini 2440's ip>:8080 and the second at http://<your mini 2440's ip>:8090 Although, probably you should only use jpeg mode (without -y switch) for both cameras if they support it - mini2440 supports only USB Full Speed mode (12MBps) and there wouldn't be enough bandwidth for both cameras otherwise.
Hi Vladimir, I managed to configure 2 USB web cam, but this time I used both with YUV format. The cam 1 is working well, but the cam 2 didn't work due to "No space left on the device". Is it because of mini2440 only supports USB full speed mode (12mbps) in which the other cam doesn't have enough space on it? Is it what do you expect as shown below? Or it's not? cam 1: MJPG Streamer Version.: 2.0 i: Using V4L2 device.: /dev/video0 i: Desired Resolution: 640 x 480 i: Frames Per Second.: 5 i: Format............: YUV i: JPEG Quality......: 80 format asked unavailable get width 352 height 288 o: www-folder-path...: ./www/ o: HTTP TCP port.....: 8080 o: username:password.: yyyy:xxxx o: commands..........: enabled cam 2: MJPG Streamer Version.: 2.0 i: Using V4L2 device.: /dev/video1 i: Desired Resolution: 640 x 480 i: Frames Per Second.: 5 i: Format............: YUV i: JPEG Quality......: 80 format asked unavailable get width 352 height 288 o: www-folder-path...: ./www/ o: HTTP TCP port.....: 8090 o: username:password.: yyyy:xxxx o: commands..........: enabled uvcvideo: Failed to submit URB 0 (-28). Unable to start capture: No space left on device i: Error grabbing frames s3c2410-ohci s3c2410-ohci: leak ed ffc68200 (#82) state 2 Thanks, Puma
Hi Vladimir, The fps was already set to 5 as shown above. BTW, I tried to simulate the problem using my IBM laptop with 2 USB hosts in which my 2 USB web cam was connected separately, but the same problem "No space left on device" still exist. Any hint that caused this problem both on mini2440 and on my IBM laptop? Does MJPG-Streamer can only support 1 USB cam? Please advise. Thanks, Puma
Hi Vladimir, I got the solution for using 2 usb web cams on mini2440. basically, the problem on "No space left on device" will happen if both camera are using the same format (e.g., YUV). I configured my mini2440 by using video0 for YUV and video1 for MJPEG formats. For now, my mini2440 works with 2 usb cams. Thanks, Puma
Hi puma: I have the same question with you ,but the format of usb cams is both JPEG.Please advise. Thanks, worthing
Hi worthing, Cams with the same format won't work for 2 usb cam. Only 1 usb cam will work. Thanks, Puma
My program can run,but if the size of JPEG is large, the usb disconnect
automatically. Tips are as follows:
zc3xx: probe 2wr ov vga 0x0000
gspca: usb_submit_urb alt 6 err -28
s3c2410-ohci s3c2410-ohci: leak ed ffcbe080 (#81) state 2
gspca: usb_submit_urb alt 5 err -28
s3c2410-ohci s3c2410-ohci: leak ed ffcbe240 (#81) state 2
gspca: usb_submit_urb alt 4 err -28
s3c2410-ohci s3c2410-ohci: leak ed ffcbe280 (#81) state 2
I just read that I only can run one process with the same format - hm - is there ANY way to have two sources with the same format on one machine or is there a workaround? At the end I need the jpg from two cams on the client and i get them with an own written java-program which probably can do a conversion if I run the processes in different formats. Or can I do a conversion using another tool on the server? Any creative ideas are welcome ;-) The command looks as follows: mjpg_streamer -i "input_uvc.so -d /dev/video0 -f 5 -r 1920x1080" -o "output_http.so -w ./ -p 8081" & Kind regards Andy
Maybe when you plug usb-hub, it works at usb1.1 speed :) I have same issue when plug usb keyboard, usb webcam. Some character is missing when i use both of them. Here is i read from wikipedia: http://en.wikipedia.org/wiki/USB_hub To allow high-speed devices to operate in their fastest mode all hubs between the devices and the computer must be high speed. High-speed devices should fall back to full-speed when plugged in to a full-speed hub (or connected to an older full-speed computer port) Anyway, try to check your usb-hub speed( hight-speed USB2.0 or full-speed USB1.0)
Probably I don't understand you. I think that an USB hub can't solve the problem. I have two cams - and I need two mjpg_streamer processes running and there is a limitation ...
No space left on device, can be solve plugin the second cam over a different usb "bus",check it with lsusb command. two webcam canīt be work over the same usb 1.1 "bus".
/MJPG Streamer Version.: 2.0 i: Using V4L2 device.: /dev/video0 i: Desired Resolution: 640 x 480 i: Frames Per Second.: 5 i: Format............: YUV i: JPEG Quality......: 80 Unable to map buffer: Invalid argument Init v4L2 failed !! exit fatal i: init_VideoIn failed [1] + Done(127) AT S7=45 S0=0 L1 V1 X4 how to solve this error, please, help as soon as possible
could anyone tell me how to write html code to view streams of 2 cameras in a single webpage. plz reply as soon as possible. thanks in advance
Hi Vladimir, i am srinivas,how you managed two webcams stream at a time. I have connected two webcam to ubuntu 12.04.
I know this is a few months old but in case anyone is still wondering ... I managed to get 2 webcams streaming both as MJPG format. There are several forums saying it can't be done. It can. You have to specify both webcams in 2 separate lines within a script (just Google "livestream.sh"). Each line must include the "-d" switch to specify which webcam, in my case these are "/dev/video0" and "/dev/video1". Also, each webcam must be assigned its own port. In my case it is "8080" and "8090". I have my resolution quite low, and left the frame rate and quality to default. But it works fine, stutter free and no delay. mjpg_streamer -i "/usr/lib/input_uvc.so -n -r 640x320 -d /dev/video0" -o "/usr/lib/output_http.so -p 8080 -w ./www" mjpg_streamer -i "/usr/lib/input_uvc.so -n -r 640x320 -d /dev/video1" -o "/usr/lib/output_http.so -p 8090 -w ./www" Hope this helps someone. Cheers Chris.
