IO PORT CE 6.0
Nack
as I can use GPIO (I/O PORT) with CE 6.0. Does it exist some drivers?
Best regards
Edje11
Did you used the forum search function?
http://www.friendlyarm.net/forum/topic/143
nack
Best regards
nack
I thank you for the answer, but since I am not very good with c++ net, I
use vb net smart device, you don't know where I can unload I2CDLL already
compiled.
Best regards
Andreas
http://www.friendlyarm.net/forum/topic/848
nack
thanks for the answer but OpenNETCF_S3C2440.IO n on works with ce 6.0. My
problem is to use the  gpio port  with ce 6.0. with ce 5.0 don't have
problems !
Regards
andrés barré
Windows CE 6.0 has a different security model and VirtualAlloc to a
physical address is no longer allowed.  Since this is what the
PhysicalAddressPointer class relies on to work, it causes the class to
fail.  The only workaround is to create an actual driver for the device
that exposes a method to do the memory-mapping for you.
alex
Hi Nack,
I am developing in VB 2008 and have the same problem, please add my mail to
msn so we can help each other!
alex_houben AT hotmail dot com
Alex
Nack
Hi Alex
following the present posts on the forum I am trying to write a driver for
the management of the doors I/O, as soon as my tests will give result ok I
send you the driver.
regards
Nack
alex
@ Nack thanks in advance! It will help me a lot!!!!!!
Lars Thörnqvist
Best Nack,
Please send it to me as well if ok.
lt20@hotmail.com
Many thanks in advance.
// Lars
Edje11
With thanks to Domodom;
http://www.domodom.fr/spip/Writing-a-VB-Net-application-to.html
Cecep Sujana
Is there someone who know to access GPIO Mini 2451 via visual basic
Nitin
Please help me to read button state using .Net ( VB or C# ) VS2008
