S2 Switch to Nand
The LCD only starts with white Sreen
The 4 LED Counts up.
Nothing else more works.
Trying to backup the nand flash to file dosnīt works (S2 to Nor)
=============== USB Backup Start ==============
Nand Flash Information:
type : 0x4
flags : 0xc5
erasesize : 128KB
oobblock : 2048
oobsize : 64
ecctype : 0x2
eccsize : 256
Backup Information:
Start Addr : 0x4
End Addr : 0xc5
bBackupOOB : 1073741824
bCheckBad : 131072
dwBackupTotalLen : 0x800
dwReservedBlks : 64
dwEPInPktSize : 2
dnw.exe read data 2048 bytes a time, has to read 1 times
Error: success = 0, rxLength = 4192, nBytesRead = 0, err = 0x3e6
=============== USB Backup Failed err:998 ============
I need held ;)
Startup Problem
Perherps this is usefull? ===== USB DEVICE STATUS ===== USB_CONFIGURATION_DESCRIPTOR bLength = 0x9, decimal 9 bDescriptorType = 0x2 ( USB_CONFIGURATION_DESCRIPTOR_TYPE ) wTotalLength = 0x20, decimal 32 bNumInterfaces = 0x1, decimal 1 bConfigurationValue = 0x1, decimal 1 iConfiguration = 0x0, decimal 0 bmAttributes = 0xc0 ( ??? UNKNOWN!! ) MaxPower = 0x19, decimal 25 ----------------------------- USB_INTERFACE_DESCRIPTOR #0 bLength = 0x9 bDescriptorType = 0x4 ( USB_INTERFACE_DESCRIPTOR_TYPE ) bInterfaceNumber = 0x0 bAlternateSetting = 0x0 bNumEndpoints = 0x2 bInterfaceClass = 0xff bInterfaceSubClass = 0x0 bInterfaceProtocol = 0x0 bInterface = 0x0 ----------------------------- USB_ENDPOINT_DESCRIPTOR for Pipe00 bLength = 0x7 bDescriptorType = 0x5 ( USB_ENDPOINT_DESCRIPTOR_TYPE ) bEndpointAddress= 0x81 ( INPUT ) bmAttributes= 0x2 ( USB_ENDPOINT_TYPE_BULK ) wMaxPacketSize= 0x20, decimal 32 bInterval = 0x0, decimal 0 ----------------------------- USB_ENDPOINT_DESCRIPTOR for Pipe01 bLength = 0x7 bDescriptorType = 0x5 ( USB_ENDPOINT_DESCRIPTOR_TYPE ) bEndpointAddress= 0x3 ( OUTPUT ) bmAttributes= 0x2 ( USB_ENDPOINT_TYPE_BULK ) wMaxPacketSize= 0x20, decimal 32 bInterval = 0x0, decimal 0 -----------------------------
Have you tried to restore the factory default image? http://www.friendlyarm.net/dl.php?file=download.pdf
You can change the language in Qtopia: http://code.google.com/p/friendlyarm/wiki/Qt
Thank You thats works. how can I adjust the screen? at the left side are a black stripe witch is missing on the left side
Maybe a screen problem : This occurs when you use a NEC 3,5" image (N35) with a Topoly 3,5" screen or vice versa, a T35 image with a Nec screen.
