I don't know why the mini2440 use both NOR and NAND Flash for Bootloader, which increase the board cost, while at a time, we can use one of the two for booting the system. I tried to find some information about the NAND Flash bootloader from Google and couldn't find any manual, guide doccument disscus about this problem. Can we use the u-boot (with NAND Flash)instead using supervivi (NOR) for booting the mini2440 board ?
2440 NAND BootLoader
NOR is for recovery if the boot loader in NAND is damamged. NOR is also to transfer images into NAND. NAND is for OS and OS's own bootloader. Yes, you should be able to use u-boot in NAND altough Linux isn't my area. Use Superviv to load u-boot into NAND. If NOR wasn't there then you would need J-TAG every time to change bootloader, now you just switch to NOR and update the bootloader in NAND
Hi Mr Errol, Thanks in advance. You're right, using NOR is the fastest way to recovery the damaged NAND boot. Because I plan to build my own S3C2440 CPU module based on mini2440 development kit. And I'll remove the NOR Flash to reduce hardware cost. Maybe some comercial products do not need NOR Flash that job. I tried to learn how to port u-boot into the mini2440 (without using NOR Flash), follow the steps below: (1) Install HJTAG (2) Erase all the NAND and load u-boot.bin into the NAND at block0 (3) Reset the board to run the u-boot (4) Run the command : u-boot> nand scrub (5) Run the command : u-boot> nand createbbt At this time, The NAND FLash is erased, we need to load u-boot again (Use TFTP server in order to share the u-boot.bin) (6) tftp 0x32000000 u-boot.bin (7) nand write.e 0x32000000 0x0 <u-boot.bin size in hex> (8) Run the command : u-boot> dynpart (9) Run the command : u-boot> dynenv set u-boot_env (10) Run the command : u-boot> saveenv OK, my mini2440 can run the u-boot bootloader, but I don't understand where is the location of the 2440's steppingstone image after loading u-boot.bin (use HJTAG) at the step (2) above ? Thanks in advance Best regard.
Hi everyone. I am trying to do as above the procedure. I made u-boot.bin file and done step (2) but My board is not working since step (3) I try to download same u-boot image file to NOR flash. Board is working. I wonder about image file. May I modify file before makeing image file? Could you tell me how in detail? thaks you for reading.
Hi, Firstly you should try the u-boot images from friendlyarm.net. What type of NAND Flash on your board ? If using K9F2G08U0M you must remove the NR5 resistor on the board so the iROM can dectect NAND Flash and execute bootloader.
@ kamejoko80 : i hav 1gb nand flash ( K9F8G08 ) on my board . u-boot is only available for 128M and 256M . i tried with both of them and it got flashed but on restart it shows the following text : U-Boot 1.3.2-mini2440 (May 25 2010 - 19:15:21) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: Bad block table not found for chip 0 Bad block table not found for chip 0 1024 MiB *** Warning - bad CRC or NAND, using default environment USB: S3C2410 USB Deviced In: serial Out: serial Err: serial MAC: 08:08:11:18:12:27 So, wat could be the reason for this : "NAND: Bad block table not found for chip 0 Bad block table not found for chip 0" message ??? Also, do you have any documents about u-boot commands ????
Bad block table: http://www.linux-mtd.infradead.org/tech/mtdnand/x144.html U-Boot: http://www.denx.de/wiki/DULG
After that i proceed to next step and it fails : Following is the response received on serial window : ********************************************************************** * MINI2440 # nand scrub * * * * NAND scrub: device 0 whole chip * * * * Warning: scrub option will erase all factory set bad blocks! * * * * There is no reliable way to recover them. * * * * Use this command only for testing purposes if you * * * * are sure of what you are doing! * * * * Really scrub this NAND flash? <y/N> * * * * scrub aborted * * * * MINI2440 # * **********************************************************************
I installed all the image via nor as per the manual..after that the OS is getting run..now i switch of my mini2440 kit then i select nand flash..this time i can see only the boot logo is coming and its not going inside the OS.. Whats the problem...my terminal says"load windows CE image"..
hi am not able to install the linux into mini2440, i have attached the log. please go through it hope the needful is done thanks in advance thanks & regards chetan
