Hi, I downloaded the supervivi-128 e uboot-128 for my mini2440 256MB. I tried to flash the nor memory with supervivi-128 using the guide in the Downloads section but when I turned on the board with the S2 in nor position the hyperterminal said "NAND NOT SUPPORTED". I tried than to flash the nor with uboot-128 loader, alwais following exactly the guide, but nothing happened. Now I'd like to return to the first loader but I can't flash the nor because H-JTAG program says "can't programm the destination address". I didn't change the settings during the two flashing... What should I do now??? Please help me I don't now what to do. Regards, Marco.
NOR flashing problem
Hi Marco, You need to disable the target MMU when flashing the NOR. The most likely problem is with the Init Script settings. Here is a possible solution: 1. Start H-Jtag and launch H-Flasher utility. 2. Choose the correct NOR part in step 1 - Flash Selection. (SST-39VF1601 in my case. Check yours.) 3. In step 2, enter correct addresses (Flash = 0x00000000 and RAM= 0x30000000) 4. In step 3, ensure that correct init script file (*.hfc from your FriendlyARM DVD) is selected. 5. In the same step, use the arrow buttons on the right to add a Flash command (Left arrow). Enter the command by double-clicking the "Cmd" column. Choose "Disable MMU" command. Move this command to the top of the script command list using the Up arrow. 6. Now proceed to step 4 and Flash your NOR as usual. That should do it. Good luck! Gautam
I'm sorry..i also have this problem now.. And I have tried the solution as mentioned by Gautam but I can't find the cmd function "Disable MMU" in step 5. Can you tell me where this function is ?? I'm using H-JTAG V1.0 Release ... Thank you very much~
Hi yuensli! You need to use H-Jtag v0.4.4. You can download it from here: http://www.friendlyarm.net/downloads Then follow the steps mentioned earlier. Good luck! Gautam
hi Gautam please help me...same problem here... I having programming the SST39VF1601 , erasing and blank the chip, but then i lost my electricity and computer shut-down instantly, apter power recovery i found the mini2440 hang cannot reset , lcd screen full blank with white colour, pressing reset not respond , when i try to program i see "flash error" on H-flash software: i think the the SST39VF1601 cannot be detect when i press reset and check facility in H-Flash software "Can't download driver to specified address ...!!!" what should i do..?? please help me...
Hi, I had a different problem when trying to reprogram FLASH worked first couple of times then gave a 0x120B0000 error. Seems the MMU is a pain in the ****, I am trying to load and run another Bootloader/ROM monitor RedBoot. This runs when I load it into RAM from supervivi but does nothing when I load it into ROM and reboot, probably also caused by me not configuring the MMU properly though there is code in RedBoot to do this. However at least I am back to a working system, wonder why the DisMMU command wasn't in the script to begin with. Thanks again for that thought I would have to figure out how to do this manually.
Hi Dodi, The H-Flash software ha a button to detect the NOR flash device. Make sure that the .hfc and .his files are loaded in H-Jtag before proceeding. Also ensure that the "Disable MMU" (DisMMU) command is added to the top of the script. Then click on the button to check the NOR flash chip. Sorry for the delay in replying as I was busy with my day job! ;( HTH! Regards, Gautam
dear friends, we have a S3C2440 development board named SDK2440v2. we have also a NOR programming problem just as you share here. Most probably :) I understood the solution but I don't have the files you mentioned above as *.hfc and *.his files. can anyone send these files to my e mail? fatihkeser@yahoo.com 256M nand 2M nor thanks for assist...
Hi All I have same problem on mini2440 board J-tag.I did all upper steps exactly.but the H-Jtag program detect my board and the flasher program can not detect my board yet! and issue this error message consecutively : can't halt target and make it enter debug state. also I did mr.Gautam commands step by step exactly. but that message issue again! and I can not flash my nor
Hi mohamad, >>>>>>>>>>>>> .but the H-Jtag program detect my board and the flasher program can not detect my board yet! >>>>>>>>>>>>> When you connect your JTAG cable to the mini2440 board, does it show the Processor ID correctly in blue letters in the H-JTAG software? If it shows 0x00000000 or 0xFFFFFFFF in red colour, it means that the board is not detected correctly. This is most likely caused by incorrect parallel port pin settings in the H-JTAG software. For correct settings, refer to the Mini2440 User Manual or the document called "Jtagging the NOR". Both these are available in the Download section on the FriandlyARM web site. HTH! Gautam
I have the same issue described here. I tried to follow the step and it comminicate ok with H-JTAG but as soon as i try to program it, i have error: "can't halt target and make it enter DEBUG state". I used H-JTAG v0.4.4 and v2.1 with same results. Other question i have is about TAP Configuration in H-JTAG. What to set and where to get those settings? Any guidance is appreciated.
Hi Vishad, Sorry for the late reply. 1. You need to ensure that the .hfc script file is correct for your Flash part number. Different lots of the board ship with different part numbers for NOR and NAND Flash. So, unfortunately there's no guarantee which one will be present on yours. Your best bet is to write down the **exact** NOR no. on a piece of paper. (Look on the FA Downloads page for example part numbers) Then you can google for a .hfc file with the same name as your part number and you should likely find it. 2. Download the PDF: http://www.andahammer.com/assets/Uploads/All2440/Firmware/JTAGingTheNOR.pdf It contains the settings you need on page 2. :) HTH, Gautam
Hello Gautam, I have done exactly the same steps as discussed here as well as in pdf file, but I am still getting this erorr. I have also downloaded H-Jtag version 0.4.4. can't halt target and make it enter DEBUG state" Can you please tell me what could be wrong over there? Also I have tried download .his and .hfc file to the board and also disable MMU, still I am not able to get the board running well. I have followed exactly same steps. Look forward to hear from you soon. can you please share info about how to detect NOR chip?
@miniarm: Are you sure you loaded the correct .hfc and .his files for your NOR Flash part number? Do a double check after loading the .his file and see if the script commands are loaded in the right hand side view of H-Flasher. Make sure that the DisMMU command (Disable MMU) is the first one in the list. If the target still does not halt, insert a Delay command with a delay value of 100 or 150 ms. and try again. Good luck! Gautam
@Gautam, @davef, Can you please help me out on this link. http://www.friendlyarm.net/forum/topic/4824
The bootloader that comes factory installed on the Micro2440 and the Mini2440 board is called Supervivi. I don't personally like it. It has very limited support and requires a YAFFS filesystem for the root filesystem. So when I bought my board I began to immediately search out an alternative. The bootloader by choice, it seems, is a modified version of U-Boot with modifications for the Mini2440 board's hardware http://www.downloaddriver.ga driver and software download http://www.printer-driver.ga printer driver download http://www.eprinterdriver.ga epson printer driver http://www.drivers-hp.net/ HP Printer Driver Download http://aboutdrivers.blogdetik.com/ Hp Printer Review http://printer-review.weebly.com Visit
