Hi guys, I wanted to know how i can resolve permission specifications for my application. I have developed a file browser application in Qtopia 2.2.0. I am using Red hat enterprise edition 5.3.(to run x86-qtopia) My code compiles fine. Also i can access all files and folders in /root/... or any user allowed areas. but when i come to file system, I can't access system folders or files. Initially i thought i had bugs in my code or i have mistaken in setting paths. But soon i realised that this happens only with system folders/files. I read a linux programming book in which i read about initial permissions which can be changed by setting flags such as S_IRUSR | S_IWGRP |S_XOTH etc. or i can use $chmod or $chown commands etc.. But i am confused as how i can use these flags or commands. As in where should i write them so that my application can access all the files and folders including system files and folders.... do i have to set these flags/permissions in the main of my application or constructor?? If yes then do i have to keep on setting file permissions for each and every file and folder??? Please guide!!!!
giving access permission 2 system folders/files in my Qtopia app
On the folder you want to copy to, do: ls -l And if you don't have write permission to the folder, do this: chmod 777 your/folder/name 777 means permission to write, read and execute. If you want to tune it better, search for it and choose a more appropriated number. Sérgio
