internet mini2440
mike
hey guys hw yaa doin
i have a question about running internet on mini2440.i have a 128mb NAND
3.5" lcd mini. On the screen i click on the internet icon select LAN-TCP/IP
-> configure IP manually -> put IPs and when i click ok it says
"the file /etc/pcmcia/network.opts doesnot exist.please restore the
culprit" :) what am i supposed to do now!
any help will be appreciated!
mike
kevin
just make a file named network.opts and reconfigure again everythin will be
fine
enjoy!
theo
hello, i have the exact same problem, (i admit im a bit of a noob in all
this) how can i make that file in qtopia...?
theo,
Don
I have the same problem and the suggested solution didn't work.
I created the network.opts but it is as if the network setup does not work
at all.  Does anyone know how to fix this?  The address is always
192.168.1.230.  However the working dhcp server serves up addresses in the
10.10.XXX.XXX ranges -- The mini2440 never updates addresses.
Whenever I attempt to configure the address manually, it always remains at
192.168.1.230  What gives?!
Don
Erik
Also having the same issue.  I was going to attempt the suggested fix and
there is no "pcmcia" dir in the /etc
Is this a duct tape solution or is there an actual fix?
Erik
I created the dir and file and it is now on the network.
Kind of funky, but it worked.
Ben Zandstra
I did have the same problem.
However, you do not have to use the Internet Icon because that let's you
add a connection.
There is one (orange, round) icon where you can set the network settings.
Be sure to set the IP address, default gateway and so on, close the on
screen keyboard because the save button is hidden under the keyboard.
Regards,
Ben
warda
Hi...
i made the dir in etc but still didnt have any success with the internet on
my board...
also when i try to connect to a wireless router, it never gets status
'connected'...
kindly help me resolve this problem.
Regards,
Warda
egm3378
Hi..
with
ifconfig eth0 10.20.30.40
you can configure a temporary new ip address
notice that netmask is still 255.255.255.0
I have a problem : playing with file manager i deleted
ifconfig
from /sbin
can anyone send me a copy of it ?
egm3378
