Hi everybody,
Something really strange is happening with me:
-First I tried to boot my boar either from flash or via NFS, using the
uImage kernel file given. Everything works fine.
-Now I needed to customize the kernel and I did create my uImage. But the
strange thing is that if I from flash, the board boots with no problem.
However if I try to boot from NFS, I have this error:
Uncompressing Kernel Image ... Error: inflate() returned -3
What this means?
Best regards,
Sérgio
Cannot boot through NFS
To boot from flash I use:
bootargs=noinitrd root=/dev/mtdblock2 init=/linuxrc console=tty
SAC0,115200;
bootcmd=nand read 0x31000000 60000 200000; bootm 0x31000000
And to boot from NFS I use:
bootargs=console=ttySAC0 init=/linuxrc root=/dev/nfs
nfsroot=192.168.1.1:/armLinux/SBC2440
ip=192.168.1.168:192.168.1.1:192.168.1.1:255.255.255.0:www.embedinfo.com:eth0:of
f
boocmd=nfs 30000000 192.168.1.1:/armLinux/SBC2440/uImage;bootm
When booting via NFS, this is the error:
File transfer via NFS from server 192.168.1.1; our IP address is
192.168.1.168
Filename '/armLinux/SBC2440/uImage'.
Load address: 0x30000000
Loading:
###########################################*** ERROR: Cannot umount
## Booting kernel from Legacy Image at 30000000 ...
Image Name: Linux-2.6.13-arm-linux2440
Created: 2010-03-24 2:08:15 UTC
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 1549674 Bytes = 1.5 MB
Load Address: 30008000
Entry Point: 30008000
Verifying Checksum ... OK
GUNZIP: uncompress or overwrite error - must RESET board to recover
U-Boot 2008.10 (Jun 18 2009 - 17:34:23)
Add IP address of mini2440 in /etc/hosts file e.g. 192.168.0.1 mini2440 It will fix the ERROR: Cannot umount problem. Hope it helps, Thanks, Dee
Hi Uncompressing Kernel Image ... Error: inflate() returned -3 Regarding this boocmd=nfs 30000000 192.168.1.1:/armLinux/SBC2440/uImage;bootm change to boocmd=nfs 32000000 192.168.1.1:/armLinux/SBC2440/uImage;bootm
