WinCE prolems
jazzzz
I have finally managed to successfully build NK.bin, but DNW keeps saying
"OEMVERIFYMEMORY: invalid image".
Anyone knows what that's all about???
Thanx!
themadmax
Have you install the BSP and the SDK ?
http://www.friendlyarm.org/topic.asp?TOPIC_ID=67
Masoud
i bought friendly arm9 and its os was linux .I tried to change its os to
Wince .when the Sw is in Nor mode its ok and its os was Wince but when i
change it to Nand LCD is blank.
Any body can help me . i appreciate.
Masoud
wanderer
You need to first boot into nor memory, once you are there just do the
following: format the flash memory (f), then download the proper nboot (w)
for your device and finally the windows image (w). That should do the
trick!
Nicolas
The problem with "invalid image" is due to using one of the newer WinCE
images with an older supervivi.
A few months back the WinCE bsp was changed to the newer model.
And thus the images are different.
If you get the error, you need to update your supervivi to V2.
Dragutin Stanojlovic
Hi
pls tell Me where can I download winCE 3.0 image file for my advantech ppc
105t device.
Thank You.
