Recently I bought the mini2440 board with 128MB. I've downloaded u-boo from git repository (git://repo.or.cz/u-boot-openmoko/mini2440.git) and compiled it. I've tried to install it: ##### FriendlyARM BIOS 2.0 for 2440 ##### [x] format NAND FLASH for Linux [v] Download vivi [k] Download linux kernel [y] Download root_yaffs image [a] Absolute User Application [n] Download Nboot for WinCE [l] Download WinCE boot-logo [w] Download WinCE NK.bin [d] Download & Run [z] Download zImage into RAM [g] Boot linux from RAM [f] Format the nand flash [b] Boot the system [s] Set the boot parameters [u] Backup NAND Flash to HOST through USB(upload) [r] Restore NAND Flash from HOST through USB [q] Goto shell of vivi Supervivi> load flash 0 233472 u USB host is connected. Waiting a download. Now, Downloading [ADDRESS:30000000h,TOTAL:233482] RECEIVED FILE SIZE: 233482 (76KB/S, 3S) Downloaded file at 0x30000000, size = 233472 bytes Found block size = 0x00040000 Erasing... ... done Writing... ... done Written 233472 bytes Supervivi> go 0x30000000 go to 0x30000000 argument 0 = 0x00000000 argument 1 = 0x00000000 argument 2 = 0x00000000 á argument 3 = 0x00000000 U-Boot 1.3.2-mini2440 (Sep 12 2009 - 16:17:01) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: Bad block table not found for chip 0 Bad block table not found for chip 0 128 MiB *** Warning - bad CRC or NAND, using default environment USB: S3C2410 USB Deviced In: serial Out: serial Err: serial MAC: 08:08:11:18:12:27 Hit any key to stop autoboot: 0 MINI2440 # nand scrub NAND scrub: device 0 whole chip Warning: scrub option will erase all factory set bad blocks! There is no reliable way to recover them. Use this command only for testing purposes if you are sure of what you are doing! Really scrub this NAND flash? <y/N> Erasing at 0x3c0000 -- 3% complete. NAND 128MiB 3,3V 8-bit: MTD Erase failure: -5 Erasing at 0x3fe0000 -- 50% complete. NAND 128MiB 3,3V 8-bit: MTD Erase failure: -5 Erasing at 0x7fe0000 -- 100% complete. Bad block table not found for chip 0 Bad block table not found for chip 0 OK MINI2440 # nand createbbt Create BBT and erase everything ? <y/N> Skipping bad block at 0x00440000 Skipping bad block at 0x04100000 Skipping bad block at 0x07f80000 Skipping bad block at 0x07fa0000 Skipping bad block at 0x07fc0000 Skipping bad block at 0x07fe0000 Creating BBT. Please wait ...Bad block table not found for chip 0 Bad block table not found for chip 0 Bad block table written to 0x07fe0000, version 0x01 Bad block table written to 0x07fc0000, version 0x01 MINI2440 # nand write 0x30000000 u-boot NAND write: device 0 offset 0x0, size 0x40000 262144 bytes written: OK MINI2440 # saveenv Now if I turn off the board, switch to nand boot and turn it on again u-boot doesn't start. I've also tried different methods to install u-boot but no one of them work for me. Loading u-boot directly with "v" option from vivi I can boot just one time u-boot (the second time looks likes it disappears) with the following error: U-Boot 1.3.2-mini2440 (Sep 12 2009 - 16:17:01) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: nand_scan(): Cannot allocate oob_buf 0 MiB Anybody can help me? Thanks Renzo
u-boot
Hi i was also facing the same problem as you are facing. but after getting the solution from the following link it has been solved. Please refer the following link . very useful http://code.google.com/p/mini2440/wiki/MiniBringup Thanks & Regards Dhaval
So what was the solution? I've tried everything described at the URLs above and still get the oob error. Can you go into a little more detail? Thanks!
It is quit possible that you should use 'nand write.e' instead of 'nand write' as write.e "will write the error-correction bytes, and skip any bad blocks" (http://code.google.com/p/mini2440/wiki/MiniBringup). Here are my algorithm for flashing u-boot (please note that my u-boot size is equal to 242332 bytes or 0x3b29c in hex): 0. Set NOR switch to NOR and power on your board 1. picocom -b 115200 /dev/ttyUSB0 --send-cmd "sx -vv" 2. param set xmodem_timeout 100000000 3. load ram 0x32000000 242332 x 4. ctrl-a, ctrl-s and type path to your u-boot.bin for example '/tftpboot/u-boot.bin' 5. go 0x32000000 6. nand scrub 7. nand createbbt 8. nand write.e 0x32000000 0x0 0x3b29c 9. dynpart 10. dynenv set u-boot_env 11. saveenv 12. reset I hope this example will be useful. Thanks. P.S. I can't understand, you want to load 233472 bytes of u-boot.bin, but you loaded 233482 bytes.
Hi can you email me the u-boot image you used for successfully bootloading the 128MB Flash .My email is maheshkuruganti@gmail.com Thanks.
Hi mgalemin I have the same problem with u-boot and almost give-up. Would you mind to share with me also your u-boot image to my email: hecsanhk@hotmail.com. Thanks, Puma
hi i have also a 128 MB board having the same problem. can you please send me the u-boot.bin file thank you Ethem
Hello, i've also had the same problem. I've downloaded the u-boot source at the git tree and compiled it. But it happens the same as renzo. Can you please e-mail me the u-boot source for the 128Mb Flash? Best regards, Luís Silva
Please use next link to download u-boot.bin: http://depositfiles.com/files/xeayrz0hm Thanks.
Plz refer to link:- http://narnia.cs.ttu.edu/drupal/node/131 It worked perfectly for me.
mgalemin, Thank you for the file, the board now boots u-boot. But it still gives the nand warning ".... Bad CRC or NAND using default environment" Would it be too much to ask for the source code? Neo, Thank you for your help, but it didn't worked. Does files are for the 64MB flash.
Luís, Did you scrub your flash? Try to use next commands in u-boot command line: nand scrub nand createbbt dynpart dynenv set u-boot_env saveenv reset And please post a traces dump from your console with the "Bad CRC or NAND using default environment" error with traces before and after it. Thanks.
Yes, i did the scrub. The problem was i didn't do the "dynenv set u-boot_env" part. Now, following this tutorial http://narnia.cs.ttu.edu/drupal/node/131 i wrote in the flash both a kernel and a filesystem (the ones here http://labs.kernelconcepts.de/Projects/Micro2440/#Downloads), then booted the board, after the kernel starts to load the modules, a whole bunch of errors starts to appear saying "uncorrectable error: <4>mtd->read(xxx bytes from xxx) returned ECC error. After all the errors it goes into "kernel panic - not syncing: Attempted to kill init!". Do you have any idea what this might be? Could it be from the images that are made for a 64mb flash? In the cd that came with the board, there are no files uImage and filesystem.jffs2, only zImage_T35 file and filesystem in a img format. How can i load this into the board using the sdcard? Thank you for your help. Best Regards, Luís Silva
"... returned ECC error" - this error can appear because of invalid settings for mounting your rootfs (u-boot settings, image format etc.). Try to flash some verified rootfs (for example try to compile your own).
In the cd that came with the mini2440, there are only images in .img format. I cannot load these with u-boot. How can i convert them to jffs2 to work in my 128MB NAND? Yes, that is probably the best idea. I'll try that right away. As soon as i make some progress i'll post it. About the u-boot source code, is it possible for you to make the source available? I already tried to compile it, but it didn't worked. Best regards, Luís Silva
Well, to build your own rootfs is a not so big issue. Just use buildroot from here http://buildroot.uclibc.org and make a couple of things: 1. Untar it and execute 'make menuconfig' 2. Change these settings: Target Architecture [*] arm Target Architecture Variant [*] arm920t Target ABI: [*] EABI Toolchain [*] Enable RPC // need for NFS support in busybox [*] Use software floating point // need for for busybox Package Selection for the target [*] <choose software you want to use in your system> Target filesystem options [ ] ext2 [*] jffs2 Flash Type (x) NAND flash with 2kB Page and 128 kB erasesize 3. Save these settings and execute 'make'. You'll find ready to flash rootfs.arm.jffs2 rootfs image in ./binaries/uclibc/ folder. Buildroot will download and build all necessary packages (toolchain, binutils, uclibc, busybox etc.) For building u-boot I used sources from Buserror repo, you can download it from this git repo http://repo.or.cz/w/u-boot-openmoko/mini2440.git.
Hi, yes, i've already done that and it worked, but thank you for your tips anyway. Now i need to compile a kernel otherwise it will be impossible for me to try the filesystem. About the u-boot, yesterday i downloaded the latest version from the git tree, and compiled it by typing "make". After a while i got the "u-boot.bin" file, but when i rebooted the board, it froze. I don't know what it might be. Please tell me if i could be of any assistance to you. Best regards, Luís Silva
Luís, Have you executed 'make mini2440_config' command before 'make'? You also need to export CROSS_COMPILE env variable before compiling u-boot, for example 'export CROSS_COMPILE=arm-linux-'. It is quit possible that you got u-boot.bin for i386 platform. What about the kernel - you may try kernel from Buserror repo. Try these commands: 1. git clone git://repo.or.cz/linux-2.6/mini2440.git 2. mkdir -p ../kernel-bin 3. CROSS_COMPILE=arm-linux- ARCH=arm make O=../kernel-bin/ mini2440_defconfig 4. CROSS_COMPILE=arm-linux- ARCH=arm make O=../kernel-bin/ 5. Export path to the 'mkimage' binary (it should be in your u-boot sources directory in ./tools/ folder) or type full path in the next command. 6. mkimage -A arm -O linux -T kernel -C none -a 0x30008000 -e 0x30008000 -d ../kernel-bin/arch/arm/boot/zImage ../kernel-bin/uImage You'll find uImage in ../kernel-bin/ folder. Of course you should export path to your toolchain in your PATH variable or just use full path in 'CROSS_COMPILE=' part. If you want to add some extra modules to the kernel try this command: CROSS_COMPILE=arm-linux- ARCH=arm make O=../kernel-bin/ menuconfig Sincerely, Maksim.
Hi, this is what i've done. "luis@luis-desktop:~/Desktop/mini2440-u-boot$ make clean luis@luis-desktop:~/Desktop/mini2440-u-boot$ make mini2440_config Configuring for mini2440 board... luis@luis-desktop:~/Desktop/mini2440-u-boot$ echo $CROSS_COMPILE luis@luis-desktop:~/Desktop/mini2440-u-boot$ export CROSS_COMPILE=arm-linux- luis@luis-desktop:~/Desktop/mini2440-u-boot$ echo $CROSS_COMPILE arm-linux- luis@luis-desktop:~/Desktop/mini2440-u-boot$ make for dir in tools examples api_examples ; do make -C $dir _depend ; done make[1]: Entering directory `/home/luis/Desktop/mini2440-u-boot/tools' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/home/luis/Desktop/mini2440-u-boot/tools' make[1]: Entering directory `/home/luis/Desktop/mini2440-u-boot/examples' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/home/luis/Desktop/mini2440-u-boot/examples' make[1]: Entering directory `/home/luis/Desktop/mini2440-u-boot/api_examples' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/home/luis/Desktop/mini2440-u-boot/api_examples' Generating include/autoconf.mk make -C tools all make[1]: Entering directory `/home/luis/Desktop/mini2440-u-boot/tools' gcc -Wall -pedantic -idirafter /home/luis/Desktop/mini2440-u-boot/include -idirafter /home/luis/Desktop/mini2440-u-boot/include2 -idirafter /home/luis/Desktop/mini2440-u-boot/include -DTEXT_BASE=0x33F80000 -DUSE_HOSTCC -O -c -o img2srec.o img2srec.c gcc -Wall -pedantic -idirafter /home/luis/Desktop/mini2440-u-boot/include -idirafter /home/luis/Desktop/mini2440-u-boot/include2 -idirafter /home/luis/Desktop/mini2440-u-boot/include -DTEXT_BASE=0x33F80000 -DUSE_HOSTCC -O -o img2srec img2srec.o strip img2srec make[1]: *** No rule to make target `/home/luis/Desktop/mini2440/include/sha1.h', needed by `mkimage.o'. Stop. make[1]: Leaving directory `/home/luis/Desktop/mini2440-u-boot/tools' make: *** [tools] Error 2 luis@luis-desktop:~/Desktop/mini2440-u-boot$" This is the error i get. Bit strange isn't it? Still working on the kernel. Best regards, Luís Silva
As I can see you have sources with old object files: make[1]: Entering directory `/home/luis/Desktop/mini2440-u-boot/tools' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/home/luis/Desktop/mini2440-u-boot/tools' Please try to download clean sources from the repo and compile it again. Sincerely, Maksim.
Hello again. I still haven't had the time to compile the new u-boot from the git tree. I'll do it this weekend, and report to you as soon as i can. I've compiled the kernel, just like you told me. Created a uImage file, loaded it to the Mini2440's 128MB NAND flash, but as soon as is starting the kernel is freezes. Do you have any idea what it might be? "Hit any key to stop autoboot: 0 Loading from NAND 128MiB 3,3V 8-bit, offset 0x60000 Image Name: Linux-2.6.31 Created: 2009-11-05 11:50:49 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2833752 Bytes = 2.7 MB Load Address: 30008000 Entry Point: 30008000 ## Booting kernel from Legacy Image at 32000000 ... Image Name: Linux-2.6.31 Created: 2009-11-05 11:50:49 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2833752 Bytes = 2.7 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ..." Yours sincerely, Luís Silva
The only thing I can note is that your uImage file has strange size. I have next traces: Loading from NAND 128MiB 3,3V 8-bit, offset 0x60000 Image Name: Created: 2009-10-28 18:56:50 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2027436 Bytes = 1.9 MB Load Address: 30008000 Entry Point: 30008000 I have built my kernel from the repo without any additional modules (with sound patch only). Please check your cross toolchain. Sincerely, Maksim.
Hi, I just got a 128M version to work with. i'm a newbie and i flashed the nand to load other kernel and rootfs provided in the cd. now the problem is that those files are for 64M as pointed out and are not working at all..i've got all sorts of problems as discussed before - kernel freexing in the end. original problem on this thread (renzo's prob) where can i get the bootloader for 128M and the kernel images for the same.shoud the procedure on kernelconcepts be followed with the new bootloader? which toolchain would work? is there a need to modify the toolchain? can anybody point out a link which demonstrated how to compile the same if the source is provided. @mgalemin : kindly send me the uboot 128M file. depositfiles is blocked in my college. i'll definitely create a manual if m able to revive my board... Thanks
Hello, i've built the kernel exacty as you told me. the reason the kernel is so big probably has to do with the fact that when i made the mini2424_config the program asked me for the options i wanted in the kernel, driver support, the board, etc. So the kernel grew. The thing that may be in the way is the compiler. Which toolchain do you use? One of those that came with the board? Which version? I'm still working on the u-boot porting to ARM. Thank you for your attention. Luís Silva
Hi Luís, I use cross toolchain from buildroot after compiling rootfs. I have already told how to build everything using buildroot. When you configure kernel using mini2424_config config file program can't ask you anything. Try to compile clean kernel from the repo, you shouldn't execute 'menuconfig' command. Actually u-boot have already been ported to ARM by Buserror so you just need to compile it. It is an _extremely_ easy operation just get normal cross toolchain. Sincerely, Maksim.
Hello, sorry for the absence but i didn't wanted to come talk to you without doing something. Still haven't tried the new u-boot but it compiled. I'm using your bin file. I was able to compile the kernel successfully. :) By mistake i deleted the Buildroot with the already built filesystem. It had problems, so i wasn't very worried. But the problem is now i can't build it again. It keeps giving me a fakeroot error. I make exactly like you said, and it worked the first time. Now it doesn't even compile correctly. Well i'll keep trying and when i have progress i will show you. Also, i've made a guide on how to compile u-boot for the mini2440 with 128 MB. If possible, i'd like you to take a look at it later and correct any errors you find. I'll make it available either here or in my blog. What's your opinion on this? (Or any one else's opinion?) Best regards, Luís Silva
I have same problem here with 128M NAND. Can you send me the binary file? my email ananyot_dd(at)hotmail.com thanks very much.
Hi Luís, I got a mini2440 with 128MB flash and the "Cannot allocate oob_buf " problem as other people for the u-boot.bin compiled the code from git://repo.or.cz/u-boot-openmoko/mini2440.git . although the u-boot.bin provided by mgalemin at http://depositfiles.com/files/xeayrz0hm (on the above post) solved that problem, but could you please show us the code and guide on how to compile u-boot ? Thanks a million, Paul,
Hi, I have big problem with mini2440 cards. It doesn't star the linux. So I have installed the u-boot(version 1.3.2-mini2440 (Oct 6 2009 - 12:51:09)) and it seems to work. But when I instakked uImage and try to start it then next error: 'VFS: Cannot open root device "mtdblock3" or unknown-block(31,3) Please append a correct "root=" boot option; here are the available partitions: 1f00 256 mtdblock0 (driver?) 1f01 128 mtdblock1 (driver?) 1f02 5120 mtdblock2 (driver?) 1f03 125568 mtdblock3 (driver?) b300 123008 mmcblk0 driver: mmcblk b301 122959 mmcblk0p1 Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)' What this mean and what I will be able to try?
Hi, I have solved some problems. I built git://repo.or.cz/linux-2.6/mini2440.git package and converted zImage to the uImage. I installed the uImage and after that I installed gpe-image-micro2440.jffs2( http://narnia.cs.ttu.edu/drupal/node/131). So now it seems to work but I don't know what is correct login/password. Does anyone know what it correct login and password? (And why this is so complicated?). And how I can install the root_qtopia? Now I have image file and source code but it not include any makefile. How I can build it?
@paul follow the instruction here to build u-boot from git repository http://wiki.linuxmce.org/index.php/Mini2440 if you do not have ARM cross-tools then yet then it is not bad idea to start with compiling openembedded first because you will get all those cross-tools you will ever need, good description is here http://www.electronics.diycinema.co.uk/?p=109 For recent mini2440 with 128MB Flash/2K you should use generated image called u-boot-nand2k.bin regards ufon
Hello, I've got a couple of problems. I've got a working u-boot.bin from this thread and it works fine. None of the others I've compiled following any directions above have worked. they start loading, I see it showing the RAM and flash, and then there are a couple of odd characters and it crashes and I get thrown back to vivi. Thats using buserrors code and compiling is exactly that way his wiki page says. I'm using my openembedded arm toolchain as well which I know works because I've compiled several things for this already which have all worked. I'm trying to find a NEWER version of u-boot because I think the one buserror has used has some problems with the SD reader on my Micro2440. I always get mmc_block_read: err SDIDSTA=0x00000020, after a bunch of Time Outs. Other people have had the same problem, yet nobody seems to address it. If buserror's version of u-boot cannot handle SD/SDHC then I cant boot from SD. Any help would be appreciated. Thanks Bill
Just struggling with a similar problem. Did you read the blogger comments on buserror's site. You have to go through some juggling to get his u-boot image to work. Best to read his comments.
Well I fixed my own problem.I got tired of following all these directions. So I just went in to supervivi and hit [v] Download vivi, and I uploaded u-boot that I compiled myself to that. And I switched back to Nand and reset the board. The U-Boot I compiled dated Jan 7, 22:31:01, popped right up. No more weird errors. When i followed the directions from buserrors page, when I would "go" to the address and run u-boot, it would load twice and then crash back to supervivi spitting out a few weird characters and saying something about oob_buf... For me, this seems so far, to have worked. SD cards work now too
Nevermind, I realised how stupid that was after I wrote it. If you write it to nand and then boot it up and scrub the nand, and create a bad block table, you end up wiping out u-boot which is why it need sto be running from ram first ... lol... So much for my quick answer... Now back to finding out why I cant load it the correct way. :D
I ended up using the u-boot that Forrest Bao used in his tutorial, which uses the download package off KernelKoncepts. Possibly the same u-boot as you can get off the Downloads page on this site.
Well if anyone has any information on compiling u-boot to work with the 128MB board, I'd be very interested. The u-boot.bin that mgalemin posted does work, however the SD card reader does not work with it. I think the u-boot ssource that mgalemin used is older. I need the SD card to work. And I need a compilable u-boot that is made to work for the device I have, and not the 64MB one. And so far, everyone's got all these instructions, apparently nobody who is writing these instructions actually own a modern mini2440. On Buserror's google code page, he even has a script that downloads a toolchain, and uboot from the repository, and compiles it for the mini2440 and even the uboot code produced from that doesnt work corretly for me. I don't know if its the fact that I'm using a 64bit system to compile but im beginning to suspect it. Does anyone have any ideas? Bill
Did you sign in to look at his blog comments? *** The new u-boot doesn't work in RAM. Somehow the interupt code that I added to get USB working makes it crash when launched at an arbitrary address. To make it work anyway, edit include/configs/mini2440.h and disable the interupt #define. That will build you a u-boot that works in ram, but without usb. Once that is in RAM and runs, build another u-boot to flash to NAND... ***
Bill, when you have compiled both versions, can you please post them here for download? I have a new board with 256 MB. U-Boot from the link above stops with: U-Boot 1.3.2-mini2440 (Oct 6 2009 - 12:51:09) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: nand_scan(): Cannot allocate oob_buf 0 MiB
Try my blog for now. Try to follow the directions for compiling U-Boot that I give which shows how to alter the u-boot source to run from RAM. http://bill.station51.net please feel free, anyone, to comment if you see something rediculously stupid that I might be doing. This is all just my notes and rants but I'm also trying to be helpful. So please be sure to pass on corrections.
It probably won't work until Buserror adds support for that to it. He supposedly has autodetect support for 64 and 128, but I dont know about 256.
Hi Maksim, I am using u-boot128MB.bin downloaded from friendlyarm.net's download page. I am confused with dynpart. after dynapart it shows: 0x00040000 u-boot 0x00020000 u-boot_env 0x00500000 kernel 0x07aa0000 rootfs I guess 0x00040000 is the end of u-boot. Also dynenv set command needs address. So which address i should use ?? I tried dynenv set u-boot_env, and it did not work. It requires some address there. TIA Vikas
In this tutorial http://narnia.cs.ttu.edu/drupal/node/131 he uses dynenv set 40000 Haven't heard that uboot has grown sufficiently to cause this to change. You'll soon find out! Good luck
MINI2440 # mtdparts device nand0 <mini2440-nand>, # parts = 4 #: name size offset mask_flags 0: u-boot 0x00040000 0x00000000 0 1: env 0x00020000 0x00040000 0 2: kernel 0x00500000 0x00060000 0 3: root 0x03aa0000 0x00560000 0 (For the 64M version) env offset is 0x00040000, it's size is 0x00020000 So, the end of u-boot env is 0x00060000 Don't know what dynparts is . . . I use mtdparts. Now, you got me worried as the tutorial I mentioned says to: dynenv set 40000 before putting the kernel and rootfs in. At the end you set up the environment variables. Now, if you go back in and erase from 40000 it appears to me that you would lose the environment variables. This doesn't seem to happen.
*** Now, if you go back in and erase from 40000 it appears to me that you would lose the environment variables. *** Ignore this comment. I imagine if I did say to erase from the start of u-boot env then you would have to put the environment variables back in! The next line in the tutorial says to: nand erase kernel, which starts at 0x00060000 not 0x00040000 Sorry, for any confusion
Thanks Dave, Yesterday night i found this, but was lazy to update the status here. Thanks once again. Vikas
Hi This is Babu, I am using MINI2440 with 128Mb RAM, i need u-boot for this configuration. Thanks -----
Hi, I brought mini s3c2440 recently. I need to flash U-Boot on NOR flash instead of NAND, (so that I can leave my current setting with out disturbing). Then I need to boot OS from SD Card. So that I can create different images on SD card & I can insert according to my need, When I change the boot switch on NOR. Any one tried this or any one know how to do this. Any help is appreciated
Hi folks, I've been struggling with U-boot on the Mini2440 for several days now, going through the various forums and lists that have any info on it. I can download buserror's original binary, uboot.bin, and it works. I haven't tried loading that to flash because I suspect it will fail since I have the 128 MB flash. But when I build U-boot from the GIT source, it just hangs. The IRQ line in mini2440.h is commented out. I've tried two different tool chains. I sure hope someone may have some insight into this. Thanks, Doug
Have you read through all these? https://www.blogger.com/comment.g?blogID=11320970&postID=41189769619...
Hi can you email me the u-boot image you used for successfully bootloading the 128MB Flash .My email is kirti.patil2386@gmail.com Thanks & Regards
hi,my name is sunil reddy and i have recntly buy the mini2440 board,but the uboot source code was not compiling,canyou give me the link where i have to download the u-boot and uboot binary file.
I need help from you guys. I have Samsung S3c2410 ARM920T board (ARM9) with 64MB NAND flash. I am getting error while cross compile U-Boot source code. Can you share Cross compiler,U-boot loader,Root file system,Kernel source code and Images for S3c2410.
I have Samsung S3c2410 ARM920T board (ARM9) with 64MB NAND flash. I am getting error while cross compile U-Boot source code. i want suitable bin file for 64MB NAND flash please help me
Hi All, I am struggling since from 6 months to boot from NAND flash on s3c2410,ARM9,smdk2410 board using Stepping stone,64 MB NAND flash,64MB SDRAM. I am NOT getting any logs on Debug Serial port on using minicom/HyperTerminal. If anybody has working U boot image (U-boot.bin file) for this board configuration Or U-boot source code ported to this board. Waiting for reply. Please help me.
Hi Nada, Is U-boot is working on your board?. Is Dm9000AEP ethernet driver is wroking?. I am getting error "Dm9000 not found at 0x18000300 id:0x46464646" in uboot 1.3.2. If any body has the solution please help me. Thanks in advance
Hi, I have mini2440 1GB board. I am trying to load u-boot from the given link it is taking me to this point and not going ahead load ram 0x32000000 239696 uboot USB host is connected. Waiting a download. Now, Downloading [ADDRESS:32000000h,TOTAL:239706] RECEIVED FILE SIZE: 239706 (234KB/S, 1S) Downloaded file at 0x32000000, size = 239696 bytes Supervivi> go 0x32000000 go to 0x32000000 argument 0 = 0x00000000 argument 1 = 0x00000000 argument 2 = 0x00000000 argument 3 = 0x00000000 Tanks in Advance
Hi guyies, I'm also working on the same but I got stuck during booting of kernel, Everything is done, after I reboot MINI2440 in NAND switch nothing is come, but when I switch NOR and press "b" or "g" it start boot but stuck at one point, here it is "sceduler anticipatory registerede registeredio scheduler cfq registered" What do you think what should be the problem, Please help me out
Hi, I am using 1GB mini2440 board. I have similar problem as of Raghu. I am following Forrest Bao's blog. My uboot.bin's size is 179444 bytes.I got that through the DVD on purchase of the board 5-6 years back. But for the size value I mentioned as 239016 in the load ram command as I thought the size mentioned being greater than actual size wont be a problem. Will it be a problem? After sudo ./s3c2410_boot_usb u-boot.bin and go 0x31000000, I got stuck like similar to Raghu. So I tried like this: 1. Switch the system to NOR and boot with supervivi. 2. hit v in supervivi 3. i uploaded the u-boot.bin file 4. switch the system to NAND With minicom connected I did not get UBoot command prompt or anything related to uboot. In terminal it showed the Junk character and stuck on the that. I followed the second method as it was mentioned in Bill's Blog last post http://bill.station51.net/index.php?post/2010/01/16/U-Boot-on-Mini2440 Please suggest me what can I do? Note:I did not configure and compile Uboot on my own. I used uboot.bin as it came from the DVD.
Guess you got to here: http://www.friendlyarm.net/forum/topic/1103 I always entered the exact size. There are enough things that can go wrong so I always follow instructions! Did the DVD come with the 1G mini2440? If not I'd be searching around every 1G thread. Good luck!
I never had a 1G mini2440 but I see I have a file called: u-boot-bin.tbz2 Inside are three files: u-boot.bin u-boot-nand2k.bin u-boot-nand16k.bin I see u-boot-nand16k.bin is mentioned in this thread: http://www.friendlyarm.net/forum/topic/662
Hi davef,
I used u-boot-nand16k.bin which was downloaded in the thread link you
pasted in the previous post of this thread.
When I loaded the uboot to RAM thru supervivi and tried to execute by
typing go 0x31000000 supervivi command prompt it got stuck there.
And in the Bill's blog it was mentioned that there are problems in
executing Uboot in the RAM.
So as in his blog suggested
1)I did downloaded uboot binary to NAND in NOR flash mode by hitting v in
supervivi bios menu.
2) Switched to NAND flash mode did nand scrub it completed successfully.
3) And when I tried to create bad block table using nand createbbt command
it stuck there for nearly 1 hour. I waited as in the thread link u pasted
last in this thread it was mentioned it will take more time.
4) After I could not see any result in nand createbbt I doubted that as I
did NAND scrub it had erased the nand and UBoot would be lost and so it
could not create bad block table.
5) So exited from NAND flash mode and switched to NOR flash mode and
downloaded uboot binary to NAND by hitting v in supervivi bios menu and
switched to NAND mode again.
6) this time I didnot do any nand scrub as I did already and gave nand
createbbt command it showed as below and I am not sure whether bad block
table was created. And I gave the dynpart, dynenv set command and save env
as follows and it showed like below. My doubt is I didnot get any
confirmation for bad block created success message. will it create any
problems in future while flashing kernel and rootfs and any applications
created. Please look into commands I gave and the result I got and clarify
me is it ok to proceed?
U-Boot 1.3.2-mini2440 (Aug 18 2010 - 16:23:28)
I2C: ready
DRAM: 64 MB
NOR Flash not found. Use hardware switch and 'flinit'
Flash: 0 kB
NAND: 1024 MiB
In: serial
Out: serial
Err: serial
Skipping bad block at 0x3ff80000
Skipping bad block at 0x3ffa0000
Skipping bad block at 0x3ffc0000
Skipping bad block at 0x3ffe0000
MINI2440 # dynpart
mtdparts
mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x005)
MINI2440 # dynenv set u-boot_env
device 0 offset 0x40000, size 0x20000
45 4e 56 30 - 00 00 04 00
MINI2440 # saveenv
Saving Environment to NAND...
Erasing Nand...Writing to Nand... done
MINI2440 #
MINI2440 # dynpart
Well it says it created the BBT. I do recall something about it taking one
hour or more to do a nand scrub.
Looked at Forrest Bao's tutorial to refresh my memory:
Skipping bad block at 0x03ff0000
Skipping bad block at 0x03ff4000
Skipping bad block at 0x03ff8000
Skipping bad block at 0x03ffc000
Bad block table written to 0x03ffc000, version 0x01
Bad block table written to 0x03ff8000, version 0x01
So, you don't get the last four lines?
Should you be worried ... if this ends up in a commercial product then yes.
If just for your own use then I would just proceed. If the bad blocks are
not marked hopefully problems surface soon!
BTW, I don't think any 1G mini2440 were available when Forrest wrote his
tutorial.
Thanks for sharing this nice article. I read it completely and get some interesting knowledge from this. I again thanks for sharing such a nice blog.
I read your article you shared really good knowledge with is very useful foe me.Thanks for sharing this nice post.
Great writing it is such a good and nice idea thanks for sharing your article .I like your post. Thanks.
Thanks for sharing this nice article. I read it completely and get some interesting knowledge from this.l again thanks for sharing such a nice blog.
Thanks for sharing this article.It is very useful.i read again and again.Thanks again. http://www.bluevision-technologies.com/balaji-optics-machine-vision-lens...
Hi, I cross compiled Uboot source available in the downloads section of mini2440 and when used that binary it was not working. When I used u-boot-nand16k.bin downloaded from this link http://www.friendlyarm.net/forum/topic/662 it worked. I want to have the source code for that. Where can I get that? Please reply!
