hi, my laptop doesn't have parallel is i buy adaptator usb parallel the jtag it work ? its 25 pin prallel. thanks in advance.
JTAG parallel and usb
No, normal USB to LPT adapter will not work. They are only for printers. You will need a special one like http://www-user.tu-chemnitz.de/~heha/bastelecke/Rund%20um%20den%20PC/USB... Or a USB-JTAG adapter: Amontec, Signalyzer... But they dont have the right connector and you cannot use them with H-JTAG. Or H-JTAG USB Emulator: http://www.hjtag.com/product_intro.html
Hi, I was able to work with Jtag to flash files using my old pc which came with parallel port by default. The old PC became unusable, and in my new PC parallel port is not available. So I tried first with USB to Parallel Port converter and found that it will work for printers alone. So I bought PCI express parallel port card and connected to the PC. Now also the Jtag server is showing the same message what it prompted for usb to parallel port converter. that message is "Can't open the H-Jtag Usb Hardware.Please check the connection." So far I have spent above 1000 INR to make it work. Please tell me the exact accessory or solution so that I can make the 7500 INR worth mini2440 board work.If it is not possible then this is a product of hell. Atleast the product should have supported by any accessories to adapt the new trend I hope, otherwise I have the only option to dispose the mini2440 board and waste the 7500 INR.
Dear abcdefghij klmnopqrstuvwxyz, This product and processors are already very old. I am using these boards for more than four years. I used old pc to flash bootloader on NOR 5-6 times only because i never faced any problem with NOR bootloader. New boards come with Superboot, It has functionality to flash NOR it self from SD Card. (GREAT feature). Similar functionality not found on SuperVivi. Only One Occasion when i need to use Jtag is when i want Superboot on my SuperVivi board. If you don't Understand all these than you are just a piece of shit as board is for you. Have Nice Day, Sunny Leone.
Dear Sunny Leone, I bought this board before two years. If this board is not having support even for this short term, support like providing any low cost accessories to carry over the product for some more time, Do I have to keep on buying the new products whenever published to build Friendly Arm business? I am not sure you are the authorized person to say that product is old /obsolete or saying the words like "If you don't Understand all these than you are just a piece of shit " and take care to mind your words, as my words came out as I am feeling the pain of loss. Take Care!
Hi Ayyappan, You can try one of the Chinese JLink clones. You can find them on Alibaba.com. Make sure you buy the JTAG multi-connector adapter board (very low cost). Both will not cost you more than 15-20 USD in all. I have been successfully using these tools from the ADS 1.2 IDE (via ARM JTAG-RDI interface DLL) to debug bootloader issues. So I guess you needn't worry too much about H-JTAG and parallel port JTAG adapters any more! Good luck!
Hi Ayyappan, The H-JTAG of Friendlyarm is parallel port turn JTAG . If your boards were two year ago , you can use supervivi or superboot , but I suggest you using superboot beacuse of its more powerful functions . If you have any problem , you can send email to me , I can give you some idea and the newest file of image . If you can send me a video of your steps , it is best . jiameijaing@friendlyarm.com Good luck !
