Hi, I purchased a NanoPi NEO AIR recently, and I've been trying to get gstreamer1.0 to run and encode h264. I've installed the gst-plugin-cedar but get the following logs: GST_PLUGIN_PATH=/usr/local/lib/gstreamer-1.0/ gst-launch-1.0 -ve videotestsrc ! cedar_h264enc ! h264parse ! matroskamux ! filesink location="cedar.mkv" Setting pipeline to PAUSED ... [VDPAU SUNXI] VE version 0x0000 opened. Pipeline is PREROLLING ... /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)NV12\,\ width\=\(int\)320\,\ height\=\(int\)240\,\ framerate\=\(fraction\)30/1\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive" /GstPipeline:pipeline0/GstCedarH264Enc:cedarh264enc0.GstPad:src: caps = "video/x-h264\,\ stream-format\=\(string\)byte-stream\,\ alignment\=\(string\)nal\,\ profile\=\(string\)main\,\ width\=\(int\)320\,\ height\=\(int\)240\,\ framerate\=\(fraction\)30/1" /GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = "video/x-h264\,\ stream-format\=\(string\)byte-stream\,\ alignment\=\(string\)nal\,\ profile\=\(string\)main\,\ width\=\(int\)320\,\ height\=\(int\)240\,\ framerate\=\(fraction\)30/1" /GstPipeline:pipeline0/GstCedarH264Enc:cedarh264enc0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)NV12\,\ width\=\(int\)320\,\ height\=\(int\)240\,\ framerate\=\(fraction\)30/1\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive" h264enc: can't allocate VE memory ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data flow error. Additional debug info: gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming task paused, reason error (-5) /GstPipeline:pipeline0/GstMatroskaMux:matroskamux0.GstPad:src: caps = video/x-matroska ERROR: pipeline doesn't want to preroll. Setting pipeline to NULL ... /GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/x-matroska /GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = "NULL" /GstPipeline:pipeline0/GstMatroskaMux:matroskamux0.GstPad:src: caps = "video/x-matroska\,\ streamheader\=\(buffer\)\<\ 1a45dfa301000000000000144282896d6174726f736b610042878102428581021853806701ffffff ffffffff114d9b74010000000000008c4dbb010000000000001253ab841549a96653ac88ffffffff ffffffff4dbb010000000000001253ab841654ae6b53ac88ffffffffffffffff4dbb010000000000 001253ab841043a77053ac88ffffffffffffffff4dbb010000000000001253ab841c53bb6b53ac88 ffffffffffffffff4dbb010000000000001253ab841254c36753ac88ffffffffffffffff1549a966 010000000000007373a49091d949e91750e43e20961bccdd50238b2ad7b1830f4240448988000000 00000000004d80a44753747265616d6572206d6174726f736b616d75782076657273696f6e20312e 382e33005741994753747265616d6572204d6174726f736b61206d757865720044618807209ad102 7068001654ae6b0100000000000000\ \>" /GstPipeline:pipeline0/GstMatroskaMux:matroskamux0.GstPad:src: caps = "NULL" /GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = "NULL" /GstPipeline:pipeline0/GstCedarH264Enc:cedarh264enc0.GstPad:src: caps = "NULL" /GstPipeline:pipeline0/GstCedarH264Enc:cedarh264enc0.GstPad:sink: caps = "NULL" Caught SIGSEGV It looks like the interesting part is "h264enc: can't allocate VE memory" - how can I remedy this?
