I followed instructions on: http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO_Air#Flash_Image_to... but when I run eflasher the only thing that it shows is the following: Welcome to NanoPi-Air ---------------------------------------------------------------------- No image files found on SD card or USB Disk, you can: 1) Visit the product page on wiki.friendlyarm.com and locate the link to the cloud storage of your needed image files. 2) Visit the cloud storage and locate the "images-for-eflasher" directory and download the image files(usually a tar ball or a zip ball) you need. 3) Create a new directory in your SD card or USB disk, and uncompress the image files you downloaded to this directory.
nanopi neo air - eflasher no image files found
if I type "flash_eMMC.sh -d /mnt/sdcard/ubuntu-core-qte/" I get the following output: root@FriendlyARM:~# flash_eMMC.sh -d /mnt/sdcard/ubuntu-core-qte/ INFO: ==> Executing: 'sd_update -d /dev/mmcblk1 -p partmap.txt' cannot access file (/dev/mmcblk1). fail device open /dev/mmcblk1 ... usage: options -d device node default : none -p partmap file default : ./partmap.txt -i images path : default path is "partmap.txt" directory -r raw image file -s show device partitioin -h print this help text usage: partmap.txt flash= <device>.<dev no>:<partition>:<fstype>:<start>,<length>:<file name>; device : disk device name, not use dev no : disk device number, not use partition : partition name, not use fstype : file system type, MBR = raw, fat, ext4 start : disk partition start address (hex) length : disk partition length (hex) file name : write file name to partition so there is no /dev/mmcblk1 !!! root@FriendlyARM:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT mmcblk0 179:0 0 7.4G 0 disk |-mmcblk0p1 179:1 0 40M 0 part |-mmcblk0p2 179:2 0 1.5G 0 part / `-mmcblk0p3 179:3 0 5.9G 0 part /mnt/sdcard
