Hello everyone, I'm having some problems to use the GPIO from my NanoPCT2 component, I would like to know if there is any basic example of how this works with Android Studio. I was trying the examples provided in Github but I was having some errors when integrating the library. Best Regards
Example for GPIO Nano PC T2, with Android Studio
Hello, T2 Android4.4 and Android5 system has increased the hardware access library, you need to download the latest firmware to Wikipedia to go back to use, specific reference:http://wiki.friendlyarm.com/wiki/index.php/Android_Hardware_Access
Hi, thanks a lot for your answer, I was using that version of the sample code in the documentation. My problem is that when I change the package name I get the error "HardwareControler: libfriendlyarm-hardware library not found!". I could not find where this error occurs in the refence with the library.
"Hi, i solve the problem changing the version of Android, i was using 5.1, and change it to 4.4" hi John, how can you cahnge it? can you explain ? i wrote a program that use gpio. but when i send program to the 4412, it gives an error like this " INSTALL FAILED. SHARED USER INCOMPLETABLE " so we decided to change it to and. 4.4 but we failed. many thanks for your help...
Hi, you should control if you have the latest version of Android 4.4 released by Friendlyarm. I didn't have to make any changes for the program to work. Im using the Nano PC T2, i'm not sure if this fix works for all the models of boards
