Hiiii guys. I am working with Nano Pi M1. I want to set static ip to the Pi. But when I am setting it, Pi is being connected with 2 ips. dynamic ip and static ip. When checking ifocnfig it is showing static ip but when i am pinging and opening with ssh it is working for both ips. And after few hours of time static ip is disappearing with an error showing eth0: must be stopped to change its MTU and dynamic ip is displaying in ifconfig. So I want to know how can I maintain only static IP to my Nano Pi even though it was connected to DHCP server.
static ip is not working properly
Are you running Debian Jessie on the M1? I have noticed that: hostname -I gives 192.168.1.200 192.168.1.103 The first is my static IP found in /etc/network/interfaces for wlan0. The second ... I don't know where it came from. Like you I could ping the target at both IPs. Before I did that the target could not ping my router. After I could ping the router. At one stage the 192.168.1.130 disappeared, but has re-appeared. Maybe showing your interfaces file might help someone explain to the both of us what is going on. If you are running Jessie then a search of the Raspberry Pi forums might be more helpful.
http://superuser.com/questions/764143/how-can-i-ensure-that-my-static-ip... Where he talks about editing /etc/dhcp/dhclient.conf and commenting out the request ... Check out the other suggestions.
Ah, what about: route -n For me there are two lines with the same router gateway address, except Metric for one is 0 and the other 303. http://serverfault.com/questions/730918/how-to-delete-gateway-from-defau... route del default gw 192.168.1.1 got rid of the line with Metric 303 and now hostname -I gives only one Gateway entry. Still don't know how the spurious gateway entry got there.
Darn ... came back after a re-boot. I know on the NanoPi there is a comment about having to remove a file called /etc/udev/rules.d/70-persistent-net.rules ... I wonder if there is some rules.d file that needs deleting or changing. Good luck and report back. Good night.
I am going to work through this tutorial: http://www.lhsspirit.com/linux/ I see he too modifies dhcpcd.conf "to statically assign a IP Address to our RPi".
Did it for me. Just make sure the static IP address you have in /etc/network/interfaces is in the range of IP addresses in dhcpcd.conf Maybe use wpa_supplicant.conf like he does.
