Dear All, I am replacing the old 10" LCD displays of my mini6410 boards with new 4.3" LCD displays. I ordered them from FriendlyArm and I was expecting the H43 displays, however, I received the new P43. I built my own kernel using the mini6410 source files using linux-2.6.38 kernel source and the u-boot bootloader. While kernel compilation, I used the same configuration file that is used for h43 and prepared the zImage. I also used the rootfs_qtopia_qt4-s-20xxxxx.tgz source available in the DVD to copy the ts support files to my rootfs. My configuration is as follows: export TSLIB_TSDEVICE="/dev/touchscreen-1wire" export QWS_MOUSE_PROTO="tslib: /dev/touchscreen-1wire" The display is fine as I am able to run the application developed in qtcreator. However, the touchscreen is not responding while running ts_calibrate function or while running the qt application. Anyone can help me with the problem or send me the driver for the new P43 screen with touch-screen support. If I can get the linux-2.6.38 zImage_p43 that would be great as well.
P43 touchscreen driver for Linux on mini6410
Hello, our 6410 has been supported on the P43, and now you can download the kernel link back to use, which contains the P43 driver.https://www.mediafire.com/folder/a8rx2dnxh40x6/linuxsource_code
