Hi, I have nanopi neo and I want to get analogue audio to work. 'aplay -l' lists the soundcard (analouge and hdmi), so it seems that the linux driver is loaded properly. Also the audio_used flag is turned on in the fex script.bin Turning of the 'audio0_used' in the fex file results in 'aplay -l' showing no card anymore ... so this is ok. But for some reason there's no sound output on lineout l/r. https://imagebin.ca/v/385h3CzmZY3H I have tried official friendlyARM image and Armbian => Same situation. I had a look to the H3 Datasheet and lineout l/r needs to be connected to AA3 and Y3 but I can not verify this. Any ideas? Best regards, Pascal
