Dear Sir I have a device with USB interface. When it attached to Raspberry Pi, Raspberry identify it and open /dev/ttyacm0 successfully. -------------- dmesg | tail [ 263.469323] usb 1-1.4: new full-speed USB device number 5 using dwc_otg [ 263.574846] usb 1-1.4: New USB device found, idVendor=2008, idProduct=1004 [ 263.574867] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 263.574880] usb 1-1.4: Product: M6EM0714347028953018 [ 263.574893] usb 1-1.4: Manufacturer: ThingMagic, Inc. [ 263.603336] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device [ 263.604324] usbcore: registered new interface driver cdc_acm [ 263.604335] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters ------------ But it is not working when it attached to nanopi M1. dmesg message as follows ------------ [ 601.504464] ehci_irq: highspeed device disconnect [ 668.494785] ehci_irq: highspeed device connect [ 668.700136] ehci_irq: highspeed device disconnect [ 668.700186] ohci_irq: fullspeed or lowspeed device connect [ 669.120158] usb 6-1: new full-speed USB device number 3 using sunxi-ohci ------------ Could you help to solve this problem and open ttyacm0 . Thanks!
Can't open ttyacm0
When I wanted to use a Teensy USB board on my mini2440 (as ttyacm0) I had enable in the kernel: CONFIG_USB_ACM=y and re-compile. Might be your problem.
Hey thank you for the hint. Can you elaborate a bit more on how to do that? I have the same problem with the NanoPi
Keywords < kernel compilation >
On the command line in your linux-4.x.y directory that you are using for
the NanoPi type:
make menuconfig
search for the entry CONFIG_USB_ACM
say "y"
then
make or sudo make
Find your new uImage and fuse that to the microSD card.
Hope your host is set up for cross-compiling.
