Hi, just for information I have used Ptxdist to build tools chain and linux 3.16 and roofs including QT 4.8.6 library (see OSELAS.BSP-Pengutronix-Mini2440-Quickstart.pdf ) in order to cross-compile qt applications from my host pc using QtCreator I have used the Qt and tslib library aleady built by ptxdist. In QtCreator / tools / option: - compiler: use the Olesas compiler, make of our host PS (ex: usr/bin/make) ABI: arm / linux / generic / elf - Qt version use qmake found in [OSELAS BSP path]/platform-mini2440/sysroot-cross/bin/qmake - define your device (mini2440 board / IP LOGIN, ...) - define your kit using all that. during the first compil you have to add some manualy each missing lib to your *.pro (libts, libpng, libz, libfreetype, ..) for that, edit (under Qtcreator) your *.pro, rigth mouse click "add lib", external lib, enter path and name of the lib (find the lib in the [platform-mini2440/sysroot-target/usr/lib or other directory]. Repeat this operation for each missing lib. that's all (I hope :-) )
