I tested the below guideline found on wiki but I can't get link up. (no ipaddr from ipconfig wlan0) ========================================================================== Insert a TF card with eflasher to a PC running Ubuntu and make the following changes in the etc/wpa_supplicant/wpa_supplicant.conf file under the rootfs section: ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 network={ ssid="YOUR-WIFI-ESSID" psk="YOUR-WIFI-PASSWORD" } Note: the "YOUR-WIFI-ESSID" and "YOUR-WIFI-PASSWORD" need to be replaced with your actual ESSID and password. Save, exit and insert the TF card to your AIR. After power on your AIR and the blue LED is blinking for one minute you will be able to check AIR's IP address. =========================================================================== I think that wifi driver is working because I can scan wifi networks like below.. but.. it is strange why the network link is not going up. if you have any reason, pls let me know.. ============================================= root@FriendlyARM:~# sudo iwlist wlan0 scan sudo: unable to resolve host FriendlyARM wlan0 Scan completed : Cell 01 - Address: 20:C0:6D:98:A2:F0 Channel:11 Frequency:2.462 GHz (Channel 11) Quality=15/70 Signal level=-95 dBm Encryption key:on ESSID:"SC Pub 2.4G" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s 18 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s Mode:Master Extra:tsf=00000000c098dac1 Extra: Last beacon: 10880ms ago IE: Unknown: 000B53432050756220322E3447 IE: Unknown: 010882848B961224486C IE: Unknown: 03010B IE: Unknown: 32040C183060 IE: Unknown: 33082001020304050607 IE: Unknown: 33082105060708090A0B IE: Unknown: 0505000100000A IE: Unknown: DD310050F204104A0001101044000102104700102880280 IE: Unknown: 2A0100 IE: Unknown: 2D1AEE1117FFFF0000010000000000000000000000000C0 IE: Unknown: 3D160B07050000000000000000000000000000000000000 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: Unknown: DD180050F2020101000003A4000027A4000042435E00620 IE: Unknown: 0B0507003F127A IE: Unknown: DD07000C4307000000 Cell 02 - Address: 00:26:66:D4:39:FC Channel:2 Frequency:2.417 GHz (Channel 2) Quality=13/70 Signal level=-97 dBm Encryption key:on ESSID:"core" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s 9 Mb/s; 12 Mb/s; 18 Mb/s Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s Mode:Master Extra:tsf=00000000c13dc575 Extra: Last beacon: 70ms ago IE: Unknown: 0004636F7265 IE: Unknown: 010882848B960C121824 IE: Unknown: 030102 IE: Unknown: 050400030000 IE: Unknown: 2A0104 IE: Unknown: 32043048606C IE: Unknown: 2D1A6E181EFFFF000000000000000000000000000000000 IE: Unknown: 3D160205000000000000000000000000000000000000000 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: Unknown: DD180050F2020101800003A4000027A4000042435E00620 IE: Unknown: DD1E00904C336E181EFFFF0000000000000000000000000 IE: Unknown: DD1A00904C3402050000000000000000000000000000000 IE: Unknown: DD0600E04C020160 IE: Unknown: DD0E0050F204104A0001101044000102 Cell 03 - Address: 20:C0:6D:98:A2:F1 Channel:11 Frequency:2.462 GHz (Channel 11) Quality=14/70 Signal level=-96 dBm Encryption key:on ESSID:"SC Pub 2.4G Free" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s 18 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s Mode:Master Extra:tsf=00000000bfdd20ff Extra: Last beacon: 23180ms ago IE: Unknown: 001053432050756220322E34472046726565 IE: Unknown: 010882848B961224486C IE: Unknown: 03010B IE: Unknown: 32040C183060 IE: Unknown: 33082001020304050607 IE: Unknown: 33082105060708090A0B IE: Unknown: 050400010010 IE: Unknown: 2A0100 IE: Unknown: 2D1AEE1117FFFF0000010000000000000000000000000C0 IE: Unknown: 3D160B07050000000000000000000000000000000000000 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: Unknown: DD180050F2020101000003A4000027A4000042435E00620 IE: Unknown: 0B05070049127A IE: Unknown: DD07000C4307000000 root@FriendlyARM:~#
NANOPI NEO-AIR WIFI IS NOT WORKING
I've had the same issue as mentioned by user: hj park I booted up a ubuntu computer, touched/edited the wpa_supplicant.conf in the correct folder. Nothing, wont connect. The wifi is also working since: sudo iwlist wlan0 scan command lists all nearby ssids. Whats the solution to this? Why are the docs for this board on the FriendlyArm wiki not correct?
The culprit/fix for this issue, is that following the directions found here: http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO_Air#Get_Started to get the wifi running by altering the wpa_supplicant.conf from within an Ubuntu environment, you have to be running off FriendlyArm's nanopi-air-eflasher-sd8g.img NOT the base image, nanopi-air-core-qte-sd4g.img To be fair it does mention this in the provided wiki link, however only briefly and not enough to make it seem required and limited to the eflasher image.
