hello, I want use my 'old' mini2440 for a new project and I think it's good moment to update firmware. I use ptxdist for first time. I follow the 'OSELAS.BSP-Pengutronix-Mini2440-Quickstart.pdf' I build toolchain OSELAS.Toolchain-2014.12.0 , clean, rm select... -> ok, no error. I run ptxdist (ptxdist-2015.01.0) for roofs, I execute several step before 'go', -> ok I launch ptxdist go, and I have an error message: /usr/local/lib/ptxdist-2015.01.0/rules/post/ptxd_make_world_get.make:26: recipe for target '/home/alain/03_dev/20_2440/kernel/OSELAS.BSP-Pengutronix-Mini2440/src/acl-2.2.4 9.src.tar.gz' failed I download this archive and place it in src dir (in the same idea of dl dir of buildroot) , but I have always the same error. Could you help me? Thanks
mini2440 pyxdist acl download problem
Which version of the BSP are you using? OSELAS.BSP-Pengutronix-Mini2440-2015.01.0 ? Is acl something you have enabled in ptxdist menuconfig? Did it build properly before you started to make changes in menuconfig? Early on in setting up PTXdist you tell it where the src files are located.
p13 of the latest Quickstart guide and Source Archive Location ptxdist setup Source directories --->
Hi davef, big thanks about your speedy answer ;-) yes for OSELAS.BSP-Pengutronix-Mini2440-2015.01.0 . I've download/copied again the acl file in src dir, and the ptxdist process runs correctly -- for information -- until the same problem with 'u-boot-2014.07.tar.bz2'. I follow the same idea, download/copy in src dir. Re-launch 'ptxdist go'. It's ok until u-boot compilation -> missing openssl/evp.h. resolved with some 'apt-get install' about openssl (libssl-dev, libcurl4-openssl-dev, pkg-config)... ------------------------- New pb with 'dosfstools-3.0.26.tar.xz'... I keep you in touch! thanks
Davef, I don't found dosfstools-3.0.26.tar.xz, just dosfstools-3.0.26.orig.tar.xz. I take it, rename it ... but I have a md5sum error (normal!) I don't know how ptxdist manage md5sum? an idea? thanks
Davef, I found the file! it's OK finished target world.targetinstall This step is finished next step now... Thanks again
Any files I manually downloaded I never did anything with the md5sum. Probably not a professional approach? I just trusted that the file was not corrupted. There is another guide for PTXdist on their website that should tell you how to do it. "How to become a PTXdist Guru" http://www.pengutronix.de/software/ptxdist/appnotes_en.html
davef, I've done a basic image (without qt, ..) with ext2 fs type->ok Now I add QT, I2C tools, openssh,... alway in ext2 -> KO genext2fs: couldn't allocate a block (no free space) It seems that is a space problem but I don't find how increase the size of romfs, for tests. I'm searching again... some idea? ;-) thanks
Beware that adding Qt seemed to create an number of issues. Every time you change something involved with Qt it goes through the compete build process. Cleaning Qt projects seemed difficult. I had the /demo/web browser using Qt working but it was not an easy task. I used Pengutronix for a number of years as there was poor or no mainline support for the mini2440. And cross-compiling stuff always seemed to a difficult process. There was excellent support for Pengutronix issues. If using the mini2440 is NOT an "educational" task I suggest moving to something else. I use the Nanopi as a mini2440 replacement and life has become so much easier. Good luck
Hi Davef, I have do a rootfs with QT, i2ctools, openssh in jfs filesystem, mounted on an ext2 partition and an 3.16 kernel. It's ok, i have a good example of Qt launched at start! It's perfect for my need. I will see how manage a group of ds18b120, may be with i2c/1-wire bridge. Thanks for your help! and thanks for pengutronic/Oselas very good work!
Good work, that didn't take long! I use a ATmega32U4 dev board running Teensy code for my DS18B120 temp sensors. I am also running the Matrix 1wire code on the NanoPi. Might be useful to look at their code.
Ok, I will see the Matrix code, have you a link? I see 'owfs', but I don' have idea of the portage effort. I think i'll use the DS2482-800 which is a bridge 1-wire to I2C, I have to use others I2C devices, so...
http://wiki.friendlyarm.com/wiki/index.php/Main_Page Matrix and then temperature sensor You seemed to get on top of using the Pengutronix package quite quickly, so maybe another day or two to sort I2C. With help I got SPI working with Pengutronix. I'd suggest searching the forum for I2C and see what sort of problems people had.
