Is there any way to power the NanoPi2 by another way than micro-usb plug ? I have kbd/mouse on usb-A and power supply on micro-usb, I would like to free micro-usb to use with USB Ethernet Gadget ... Best regards, M1larepa
NanoPi2 Fire power supply ?
I have a similar problem. Mine started with a strong-arm assistant ripping the micro USB connector from the PC board trying to disconnect. Now I need an alternative place to inject the 5VDC. I have a nanoPi M1 so my initial thought is to use the power and ground pins on the debug UART connector. Is this a bad idea? If it is, what would you recommend? Thx for the help.
Looking at the schematic and on page 11 it seems to me that 5V could be introduced via USB connector and on Pins 2 and 4 on the GPIO connector. The way I do it on the NanoPi is via the Vdd pins on the GPIO. I have a 1 Amp fast blow fuse in series with the external supply as the NanoPi has a 5v6 zener clamp on these pins. The safest way to do this would be to have a suitable fuse in series with your external 5V supply then a 5v6 say 5W zener to ground before connecting the positive to pins 2 and/or 4. Doing this via the debug UART connector looks to be the same deal. Be careful not to exceed 5V or get the polarity incorrect. Good luck
Thanks davef. My supply will be from a DC regulator so I hadn't intended to use any other form of limiting. The zener diode is good advice though.
