I cannot run the command I get error: $ arm-linux-gcc -v -bash: /opt/FriendlyARM/toolchain/4.9.3/bin/arm-linux-gcc: cannot execute binary file: Exec format error Im running the command in the nanopi2fire. So is it that the cross compiler is not made for arm only for x64?
Error running command arm-linux-gcc
Hi am at this point also, the toolchain has some links which are not defined properly. I get : root@NanoPi2:/opt/FriendlyARM/toolschain/4.4.3/bin# arm-linux-gcc -v /opt/FriendlyARM/toolschain/4.4.3/bin/.arm-none-linux-gnueabi-gcc: 1: /opt/FriendlyARM/toolschain/4.4.3/bin/.arm-none-linux-gnueabi-gcc: Syntax error: "(" unexpected
