Error when cross compiling mini2440 kernel
Ayyappan mk
I am using mini2440 1GB Nand board.
While I am cross compiling the kernel I get the following error.
ayyappan-muthu@ayyappanmuthu-Inspiron-5559:/DATA/linux-2.6.32.2$ make
zImage
  CHK     include/linux/version.h
make[1]: `include/asm-arm/mach-types.h' is up to date.
  CHK     include/linux/utsrelease.h
  SYMLINK include/asm -> include/asm-arm
  CC      kernel/bounds.s
/opt/FriendlyARM/toolschain/4.4.3/libexec/gcc/arm-none-linux-gnueabi/4.4.3/cc1:
error while loading shared libraries: libstdc++.so.6: cannot open shared
object file: No such file or directory
make[1]: *** [kernel/bounds.s] Error 1
make: *** [prepare0] Error 2
I am using 14.04 ubuntu OS.
I have already installed equivalent of ia32-libs as ia32-libs showed as
obsolete. libstdc++6 was already installed.
For ur confirmation when I execute the following command I get output as
follows:
ayyappan-muthu@ayyappanmuthu-Inspiron-5559:/DATA/linux-2.6.32.2$ sudo
apt-get install libstdc++6
Reading package lists... Done
Building dependency tree
Reading state information... Done
libstdc++6 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 101 not upgraded.
Please help to what I have to do.
Ayyappan mk
Additional information when I execute file /sbin/init I get following
output.
ayyappan-muthu@ayyappanmuthu-Inspiron-5559:/DATA/linux-2.6.32.2$ file
/sbin/init
/sbin/init: ELF 64-bit LSB  shared object, x86-64, version 1 (SYSV),
dynamically linked (uses shared libs), for GNU/Linux 2.6.24,
BuildID[sha1]=7a4c688d009fc1f06ffc692f5f42ab09e68582b2, stripped
Doesn't look like your file is being cross-compiled for the mini2440.
Do a:
   readelf -A <your_cross-compiled_file_on_the_host>
Also 4.4.3 is a new toolchain used for NanoPi development.
I think you will have problems using a much newer toolchain with an old
kernel.
Check what toolchain was used with the mini2440.  I think it was 4.3.2
Ayyappan mk
No davef. This was the same toolchain I used in my old PC for mini2440.In
my new laptop it is not cross compiling. I dont understand how I can do
readelf -A elffile
as cross compilation failed at starting itself.
Take any file that you intended to cross-compile to run on the mini2440, ie
/sbin/init and
change directories on the host to where you think your cross-compiled files
are, ie /sbin do a ls to check that init is there and type
   readelf -A init
If this doesn't work then go to your cross-compiled /bin directory and do
the same on one of the files in there.
... and post the results.
