Hello, I'm trying to install the OS for the NanoPi M3, but at the moment im not having much luck. It starts to work and then turns its self off after a while. I've not got a USB keyboard, only a Bluetooth one and was wondering if this is the issue ? also do I have to have it connected to the network the first time you try and install it ? Mark
NanoPi M3 OS
Typical issues with other product: - power supply can't supply the required current - the NanoPC-T2 needed a rootwait in bootargs to boot successfully from an SD card. - the brand of SD card seems to be critical Check out the new forum for details
