Hi, I built the kernel from http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO /build.sh -p sun8iw7p1 -b nanopi-h3 -m kernel I got the rtl drivers from: https://github.com/pvaret/rtl8192cu-fixes I am trying to build the driver against the kernel above, and I tried both SUN* configurations: CONFIG_PLATFORM_ARM_SUNxI = n CONFIG_PLATFORM_ARM_SUN6I = y error: #error "Can't define CONFIG_IOCTL_CFG80211 because neither CONFIG_CFG80211 nor CONFIG_CFG80211_MODULE is defined in kernel" and CONFIG_PLATFORM_ARM_SUNxI = y CONFIG_PLATFORM_ARM_SUN6I = n home/marius/APPS/BOARDS/NANOPI-NEO/rtl8192cu-fixes/os_dep/linux/usb_intf.c:1556: 2: error: implicit declaration of function ‘script_parser_fetch’ [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors Any ideas. Thak you
Building rt8192cu driver against lichee/ilnux-3.4 kernel
If I hack the error in Makfile for SUNxI config, when sudo insmod -f ./8192cu.ko I get pi@FriendlyARM:/home/cocam$ sudo dmesg -c [ 2530.348359] 8192cu: Unknown symbol script_parser_fetch (err 0) [ 2530.348468] 8192cu: Unknown symbol sw_usb_enable_hcd (err 0) [ 2530.348492] 8192cu: Unknown symbol sw_usb_disable_hcd (err 0) ....
