Hi, I am using mini2440 board. I want to reduce the rootfs image size of Qtopia. Is python and kde related files are optional or mandatory? On carefully removing all files related to kde and python and making rootfs image and porting will the board boot up without errors or crash? Please reply!
Is python, kde related mandatory or optional in Qtopia rootfs
Hi, In the Qtopia root file system content in the directory /usr/lib i see python 2.7 directory,libpython2.7.a static library and pkgconfig all having python libraries and it's related stuff. I guess those will be used to interpret files in /usr/include/python2.7. Is there are any other dependencies exists with the python related files residing in /usr/lib ? I have extracted kernel headers from the mini2440 kernel source using the following command: make headers_install ARCH=arm INSTALL_HDR_PATH=path_to_store_header_files Are these files I extracted if replaced with python related files in /usr/lib and /usr/include will it work fine? My questions are easy to reply by the people who developed Qtopia rootfs content of mini2440 or who has expert knowledge in Qtopia root filesystem content of mini2440. So please reply!
Hi, In the qtopia rootfs folder downloaded from download section of mini2440 in the path rootfs_qtopia_qt4\usr\bin I see python and python2.7 binaries. Is python2.7 binary itself enough or is there any dependencies with other python binary? I see both are same of size. This is the easiest question for the rootfs content developers I have asked in this thread. Can I expect answer atleast for this latest question?
