Hi, I installed VLC on Nano-Pi M3(debian-jessie) and run fa@NanoPi3:~$ vlc v4l2:///dev/video0 and met below errors. Do you know why it is trying to find "libvdpau_nvidia.so" ? Are you sure VLC is working on -M3 ? VLC media player 2.2.1 Terry Pratchett (Weatherwax) (revision 2.2.1-0-ga425c42) [0018ca88] pulse audio output error: PulseAudio server connection failure: Connection refused [000238f8] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface. Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory [aed00c78] xcb_xv vout display error: no available XVideo adaptor [b4800648] core input error: ES_OUT_SET_(GROUP_)PCR is called too late (pts_delay increased to 300 ms) [b4800648] core input error: ES_OUT_RESET_PCR called
VLC on NanoPi-M3
Hi, The driver of the video decoder is not present in the NanoPi-M3 debian image, alternatively you may play videos with smplayer using x11 output, but it is really slow.
