Kernel Panic error
Trafic
Hello i`am new to the forum ... and in linux and I have a problem with a
AverMedia DVR 8ch(surveillance standalone) model SEB5108Lite.
It is connected via RS232 cabble to a laptop(old one with serial interface)
with PuTTY and via tftp cabble to a another laptop with tftpd32 (server).
I managed to upload partial, but an error occurs.... log file next->
˙#NAND bootstrap
         __  __                      _ _
        |  \/  | __ _ _ ____   _____| | |
        | |\/| |/ _` | '__\ \ / / _ \ | |
        | |  | | (_| | |   \ V /  __/ | |
        |_|  |_|\__,_|_|    \_/ \___|_|_|
 _   _     ____              _
| | | |   | __ )  ___   ___ | |_
| | | |___|  _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
 \___/    |____/ \___/ \___/ \__|  ** LOADER ** ,modify by scott
 ** MARVELL BOARD: RD-88F5182-NAS-3 LE
U-Boot 1.1.1 (Aug 21 2009 - 17:14:33) C2A9 B version: 1.1.0.8
Vic Size = 0x8000000
DRAM CS[0] base 0x00000000   size 128MB
DRAM CS[1] base 0x08000000   size 128MB
DRAM Total size 256MB
Addresses 20M - 0M are saved for the U-Boot usage.
Mem malloc Initialization (20M - 16M): Done
NAND:devNum=3,mvBoardGetDeviceBaseAddr
/home/users/vicye/C2A9/uboot_c2a9/board/mv88fxx81/Board/boardEnv/mvBoardEnvLib.c
1191
 scott test NAND ADDRESS =
f6000000,/home/users/vicye/C2A9/uboot_c2a9/board/mv88fxx81/USP/mv_main.c
894
 enter nand_probe cmd_nand.c 1658
NAND mfr id ec at cmd_nand.c 678
NAND id id 75 at cmd_nand.c 679
1 flash chips found. Total nand_chip size: 32 MB
0xf6000000:   32 MB
devNum=1,mvBoardGetDeviceBaseAddr
1191
f8000000,/home/users/vicye/C2A9/uboot_c2a9/board/mv88fxx81/USP/mv_main.c
900
0xf8000000:   32 MB
Soc: 88F5182 A2
CPU: ARM926 (Rev 0) running @ 500Mhz
Orion 1 streaming disabled
SysClock = 166Mhz , TClock = 166Mhz
USB 0: host mode
USB 1: host mode
pciIfNum:2,/home/users/vicye/C2A9/uboot_c2a9/board/mv88fxx81/USP/mv_pci.c
628
PCI 0: PCI Express Root Complex Interface
vendor id:0x11ab header_type:0x0, pci.c 471
PCI Scan: Found Bus 0, Device 0, Function 0
device id:0x5182, pci.c 479
CONFIG_PCI_PNP
PCI Scan: Found Bus 0, Device 1, Function 0
device id:0x6121, pci.c 479
CONFIG_PCI_PNP
 end at 502 in pci_hose_scan_bus
PCI 1: Conventional PCI, speed = 33000000
vendor id:0x11ab header_type:0x80, pci.c 471
PCI Scan: Found Bus 1, Device 0, Function 0
CONFIG_PCI_PNP
PCI Scan: Found Bus 1, Device 0, Function 1
CONFIG_PCI_PNP
PCI Scan: Found Bus 1, Device 0, Function 2
CONFIG_PCI_PNP
PCI Scan: Found Bus 1, Device 0, Function 3
CONFIG_PCI_PNP
PCI Scan: Found Bus 1, Device 0, Function 4
CONFIG_PCI_PNP
PCI Scan: Found Bus 1, Device 0, Function 5
CONFIG_PCI_PNP
PCI Scan: Found Bus 1, Device 0, Function 6
CONFIG_PCI_PNP
PCI Scan: Found Bus 1, Device 0, Function 7
CONFIG_PCI_PNP
vendor id:0x9413 header_type:0x0, pci.c 471
PCI Scan: Found Bus 1, Device 9, Function 0
device id:0x6010, pci.c 479
=pci.c 492
i = 0
@@value = 243
i = 1
@@value = 243
i = 2
@@value = 243
i = 3
@@value = 243
i = 4
@@value = 243
i = 5
@@value = 243
i = 6
@@value = 243
i = 7
@@value = 243
i = 8
@@value = 255
i = 9
@@value = 255
i = 10
@@value = 255
i = 11
@@value = 255
i = 12
@@value = 255
i = 13
@@value = 255
i = 14
@@value = 255
i = 15
@@value = 255
 video type = 1
Net:   eth.c 133
egiga0 [PRIME]
USB:   scanning bus for devices... 1 USB Device(s) found
       scanning bus for storage devices... i=0
usb_get_dev_index i=0
usb_get_dev_index dev!=NULL
iVendor 0 iProduct 0
devClass=9  IFClass=9 IFSubClass=0
i=1
usb_get_dev_index i=1
0 Storage Device(s) found
Erasing Nand...Writing to Nand... done
Hit any key to stop autoboot:  0
Using egiga0 device
TFTP from server 10.4.50.5; our IP address is 10.4.50.165
Filename 'uImage'.
Load address: 0x400000
Loading: #################################################################
done
Bytes transferred = 2288400 (22eb10 hex)
## Booting image at 00400000 ...
   Image Name:   Linux-2.6.22.7
   Created:      2011-01-19   4:23:53 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2288336 Bytes =  2.2 MB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
OK
Starting kernel ...
Uncompressing
done, booting the kernel.
Linux version 2.6.22.7 (vicye@localhost.localdomain) (gcc version 3.4.4
(release) (CodeSourcery ARM 2005q3-2)) #58 Wed Jan 19 12:23:41 CST 2011
CPU: ARM926EJ-S [41069260] revision 0 (ARMv5TEJ), cr=a0053177
Machine: Feroceon
Using UBoot passing parameters structure
scott trace mac-> mvUbootVer:0x10c010f
scott trace mac-> tag->u.mv_uboot.EthAddr:0xff:df:f7:ff:ff:ff
scott trace mac->mvMacAddr:0xff:df:f7:ff:ff:ff
scott clear mac->mvMacAddr:0x0:0:0:0:0:0
BUG: not creating mapping for 0x98000000 at 0x98000000 in user region
BUG: not creating mapping for 0x40000000 at 0x40000000 in user region
CPU0: D VIVT write-back cache
CPU0: I cache: 32768 bytes, associativity 1, 32 byte lines, 1024 sets
CPU0: D cache: 32768 bytes, associativity 1, 32 byte lines, 1024 sets
Built 1 zonelists.  Total pages: 65024
Kernel command line: console=ttyS0,115200 root=/dev/nfs rw
nfsroot=10.4.50.5:/mnt/ARM_FS/
ip=10.4.50.165:10.4.50.5:::DB88FXX81:egiga0:none
PID hash table entries: 1024 (order: 10, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 128MB 128MB = 256MB total
Memory: 255104KB available (4264K code, 275K data, 112K init)
-------------------mvDevNandSet-----------------
Sys Clk = 166666667, Tclk = 166666667
CPU Interface
SDRAM_CS0 ....base 00000000, size 128MB
SDRAM_CS1 ....base 08000000, size 128MB
SDRAM_CS2 ....disable
SDRAM_CS3 ....disable
PEX0_MEM ....base 98000000, size 128MB
PEX0_IO ....base f2000000, size   1MB
PCI0_MEM ....base 40000000, size   1GB
PCI0_IO ....base f2100000, size   1MB
INTER_REGS ....base f1000000, size   1MB
DEVICE_CS0 ....no such
DEVICE_CS1 ....base f8000000, size  32MB
DEVICE_CS2 ....no such
DEV_BOOCS ....base f6000000, size  32MB
CRYPT_ENG ....base f0000000, size  64KB
  Marvell Development Board (LSP Version 3.0.5_NAS_GDP_p8)--
RD-88F5182-NAS-3  Soc: 88F5182 A2
 Detected Tclk 166666667 and SysClk 166666667
Marvell USB EHCI Host controller #0: c06ec600
Marvell USB EHCI Host controller #1: c06ec400
PCI: bus0: Fast back to back transfers disabled
PCI: bus1: Fast back to back transfers enabled
SCSI subsystem initialized
Time: orion_clocksource clocksource has been installed.
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
RTC registered
cesadev_init(c000c61c)
mvCesaInit: sessions=640, queue=64, pSram=f0000000
NTFS driver 2.1.28 [Flags: R/W].
JFFS2 version 2.2. (NAND) ĂŠ 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 3) is a 16550A
serial8250.0: ttyS1 at MMIO 0xf1012100 (irq = 4) is a 16550A
Intel(R) PRO/1000 Network Driver - version 7.3.20-k2-NAPI
Copyright (c) 1999-2006 Intel Corporation.
Marvell Ethernet Driver 'mv_ethernet':
  o Uncached descriptors in DRAM
  o DRAM SW cache-...stripped-down
Trafic
Trying to solve the problem, I installed a program named FreeNFS (It seems
to work with Windows 8.1 - my laptop OS) and it changed something.....
Looking up port of RPC 100003/2 on 10.4.50.5
 egiga0: link up, half duplex, speed 100 Mbps
call_verify: server 10.4.50.5 requires stronger authentication.
 Root-NFS: Unable to get nfsd port number from server, using default
 Looking up port of RPC 100005/1 on 10.4.50.5
 Root-NFS: Unable to get mountd port number from server, using default
mount: server 10.4.50.5 not responding, timed out
Root-NFS: Server returned error -5 while mounting /mnt/ARM_FS/
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available
partitions:
1f00       1024 mtdblock0 (driver?)
1f01       3072 mtdblock1 (driver?)
1f02      28672 mtdblock2 (driver?)
1f03      32768 mtdblock3 (driver?)
unknown-block(2,0)
 Does anyone know how I can pass the stronger authentication ?
I didn't respond before as I thought "you are in the wrong forum for your
issues".
Would not a forum that about this board be a better choice?
Is there some connection with FriendlyArm product that I don't see?
