Bluetooth compatibility
Mingxuan
I have bought a NanoPi2 Fire board and want to do some streaming through
this to another device. I am wondering if it is possible to install a
bluetooth component onto the board?
The Bluetooth component is a rather large WiFi/Bluetooth IC so if it is not
installed then the answer would be NO.
If you want Bluetooth then what about trying one of the other models?
NanoPi M3.  Watch out for heatsinking issues.
I use the NanoPi for WiFi and disable the Bluetooth, but you can probably
only get these older units from andahammer.com in the USA.
Mingxuan
Thanks for the reply!
Is it possible to attach the bluetooth component externally through usb on
NanoPi 2 then?
