I'm using a standard build kernel from http://code.google.com/p/mini2440/wiki/OpenEmbedded The kernel is booting fine and inside a qemu test it is detecting the SD card image fine. But when i try to use an SD card on a real board the partition isn't recognised so it kernel panics. VFS: Cannot open root device "mmcblk0p1" or unknown-block(2,0) Please append a correct "root=" boot option; here are the available partitions: 1f00 256 mtdblock0 (driver?) 1f01 128 mtdblock1 (driver?) 1f02 5120 mtdblock2 (driver?) 1f03 125568 mtdblock3 (driver?) Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) I would expect to see the mmc partitions listed here as well. Further up the output from the kernel i have this message sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman s3c-sdi s3c2440-sdi: powered down. s3c-sdi s3c2440-sdi: mmc0 - using pio, sw SDIO IRQ But its not picking up the card at all. In qemu (both are running exactly the same kernels, so i know that SD support and ext3 are in there) i get this mmc0: new SD card at address 4567 mmcblk0: mmc0:4567 QEMU! 256 MiB mmcblk0: p1 But no such luck on the real board. Anyone else had this problem?
mmc rootfs not detected
I should add that my kernel command line is console=ttySAC0,115200 noinitrd init=/sbin/init mini2440=1tb root=/dev/mmcblk0p1 rootfs=ext3 I'm aware that i shouldn't need the rootfs parameter but it also shouldn't hurt (tried with/without anyway)
I can also add that if i run > mmcinit > ext2ls mmc 0:1 I get to see all the files, so i know that SD card is inserted and the slot is working fine! So now i'm really stuck. I can't think of anything to persuade the kernel to pick up the card.
OK so to continue the conversation with myself it turns out its the type of card. I tried a 2GB kingston a 1GB corsair both of which didn't work. Next 1 tried a 256MB kingston and that worked fine, so i'm guessing there's something up with using SDHC cards? I thought i'd read that other people have used these successfully? If so could someone point out what modifications i need to make because i'd really like the extra space.
Andrew, A long shot . . . from my experience getting SD cards working with FatFS on the AVR ATmega32 there was quite a bit of traffic on: www.avrfreaks.net about 2GB Kingston cards. They didn't appear to work (initialise) the same way as many other cards. You could go to that site and drop <Kingston> in search. Good luck.
I just noticed that if I use a usb card reader I instantly get sda working, but if I use the card reader on the board I get nothing.
Hi Andrew Gatt, I have the same issue as yours. Looks like 2 years don't change stuff much. Were you able to resolve the issue. Regards, Yogik
