Hello All, [precedent post = 'GPIO driver'] To use mini2440 to interface with real world, I intend using all GPIO's pins available on mini2440 CON4 connector. 1) Available IO on mini2440, Side effects/Conflicts The following IOs are available on CON4 connector: GPB[0..1], GPE[11,13..15],GPF[0..6], GPG[0..3,5..7,9..11],GPH[9..10] - The leds device handles GPIO pins GPB[5..8]. - The buttons device handles GPIO pins GPG[0,3,5..7,11]. - All others GPIO pins are used to interface TSP, LCDDATA, LCDCTRL, UART, SDIO, NANDCTRL. Is there risks of side effects or conflicts using GPIO free bits available on CON4, the way 'leds' driver does ? 2) modifying leds driver using include/mach/regs-gpio.h leds driver source code in linux-2.6.29/drivers/char/mini2440_leds.c , refers to /arch/arm/mach-s3c2410/include/mach/regs-gpio.h where all GPIO's IO port are defined. Does setting led_table[] and led_cfg_tabl[] arrays in mini2440_leds.c with appropriate new GPIO pins references from regs-gpio.h allows to handle extra GPIO pins available on CON4 ? Is modifying leds driver that simple ? :-( beside compiling and rebuilding the kernel) 3) Camera interface The Camera IF connector CON20 gives access to GPIO GPE[[14,15], GPG[12], GPJ[0..12]. Does anybody develop a device driver to fully handle GPJ port ? Is there conflict with the BIOS using CON20 for private use ? Thanks for Help-Best Regards -nico-
modifying GPIO drivers 'leds' and 'buttons'
Would be interested in the outcomes. Working out how to drive GPIO has been the main focus of my learning experience on this platform. My direction was to use 2.6.30.5, or whatever is the most recent, and just compile that. The file on buserrors site seems to enable this functionality (sys/class/gpio?) Just out of interest where is mini2440_leds.c? Good luck Dave
I also want to use as many GPIOs as possible. My linux 2.6.29 build only supports up to GPIOG in the /sys/class/gpio so I don't know how to access GPIOH and GPIOJ. Has anybody figured out anything useful?
I don't see any sys/class/gpio on my factory build of 2.6.29 My understanding is that you need one of the later kernels (which have gpio enabled) or rebuild 2.6.29 with gpio enabled. Your request prompted me to search for mini2440_led.c as mentioned in a previous post. I found a Mini2440Essentials.pdf produced by Industrial ARMworks and I see there is a <Linux‐2.6.29/drivers/char/mini2440_leds.c>, just where is it located is still a mystery. Can't find it on the factory DVD. Perhaps addahammer include it on their distribution. I am still working on this, just real slowly. Good luck and report back if you find out.
Hi guys, To see sys/class/gpio Iīd to recompile my kernel. So, I just followed the steps described on micro2440 user manual. Itīs in chinese, so use the google translator. Read chapters 5, 6 and 7. Itīs all described there. Davef, try to download other kernel source for mini. I modified the linux-2.6.29/drivers/char/mini2440_leds.c to a "mini2440_gpio". Compiled as a module (dont know if this is rigth) and put it into my mini2440. But now I'll try to enable the /dev/gpio device to use the gpio pins. I dont have any idea how to do that... Should i use /dev/leds, /dev/buttons and others devices to use the gpio pins? Or someone know if there's a way to create this damn /dev/gpio? best regards
You can also use the GPIOs directly by writing to the control and data registers for the various ports/ios. If some ar einterested I can post an example. Patrick
Patrick, An example is always welcomed! I assume this method directly accesses the kernel. As a beginner to the ARM/Linux world I was told it was safer working with sys/class/gpio, however how much can go wrong? Thanks, Dave
An explanation on the ADC ports would be nice too, the adc driver in the kernel only gives you access to ONE pin, what is this?! Any Ideas getting to read every adc channel?
Much can go wrong by writing to the ports directly. Reading is no problem. When writing, you have to make sure you are not corrupting other pins in the same register. In some cases, it may be impossible without a driver. It depends what else is shared/used in that 32 bit IO register. Patrick
"An explanation on the ADC ports would be nice too, the adc driver in the kernel only gives you access to ONE pin, what is this?! Any Ideas getting to read every adc channel?" Look at the user guide for the processor. That user guide is on the DVD and describes all IOs as well as their register addresses and functions. you can memmap the register to user space and read it Patrick Robin
This code will read the LED register adress (0x56000014) and print it. Same code can be used to read any register. Register addresses are described in the processor user guide on the DVD Patrick #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <string.h> #include <errno.h> #include <signal.h> #include <fcntl.h> #include <ctype.h> #include <termios.h> #include <sys/types.h> #include <sys/mman.h> #define FATAL do { fprintf(stderr, "Error at line %d, file %s (%d) [%s]\n", \ __LINE__, __FILE__, errno, strerror(errno)); exit(1); } while(0) #define MAP_SIZE 4096UL #define MAP_MASK (MAP_SIZE - 1) int main(int argc, char **argv) { int fd; void *map_base, *virt_addr; unsigned long read_result, writeval; off_t target,control; int access_type = 'w'; control=0x56000014; if((fd = open("/dev/mem", O_RDWR | O_SYNC)) == -1) FATAL; printf("/dev/mem opened.\n"); fflush(stdout); /* Map one page */ map_base = mmap(0, MAP_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, fd, control & ~MAP_MASK); if(map_base == (void *) -1) FATAL; printf("Memory mapped at address %p.\n", map_base); fflush(stdout); virt_addr = map_base + (control & MAP_MASK); switch(access_type) { case 'b': read_result = *((unsigned char *) virt_addr); break; case 'h': read_result = *((unsigned short *) virt_addr); break; case 'w': read_result = *((unsigned long *) virt_addr); break; default: fprintf(stderr, "Illegal data type '%c'.\n", access_type); exit(2); } printf("Value at address 0x%X (%p): 0x%X\n", control, virt_addr, read_result); fflush(stdout); if(munmap(map_base, MAP_SIZE) == -1) FATAL; close(fd); return 0; }
It's also on the download site: http://www.friendlyarm.net/downloads#datasheets
Patrick, Thank you for the example. My comment, "how much can go wrong?" was a bit "tougue-in-cheek". I was told direct access could be problematic. Being able to read them using your example will be an interesting exercise. Cheers, Dave
I was able to compile 2.6.29 with the GPIO enabled. However, i still don't see entries in /sys/class/gpio for GPIOH and GPIOJ. It stops at gpiochip192, which is GPIOG. I was reading a little code and found that there isn't a GPIOJ defined in regs-gpio.h linux-2.6.29/arch/arm/mach-s3c2410/include/mach/regs-gpio.h There's a cryptic comment regarding GPIOJ but I don't get it. /* The S3C2412 and S3C2413 move the GPJ register set to after * GPH, which means all registers after 0x80 are now offset by 0x10 * for the 2412/2413 from the 2410/2440/2442 */ Also, in gpiolib.c, there are only entries up to GPIOG in the array: s3c24xx_gpios. Maybe I'll try adding in the GPIOH entry but how will I get GPIOJ to work?
I was able to get the GPIOH registers by altering gpiolib.c and adding extra array elements. It turns out that GPIOG also had to be slightly altered to add a couple of gpios. I saw the regs-gpioj.h file (thanks, eduardo!) but adding the GPIOJ to the array didn't add anything to the /sys/class/gpio directory. So now it seems that I can access all of the GPIOs available on the board except GPIOJ (which is 13 pins on the camera connector) through the /sys/class/gpio. I haven't noticed any side effects yet. :)
dear mmm, Look for s3c2410_gpio_getpin, s3c2410_gpio_setpin and s3c2410_gpio_cfgpin functions. Download the User Manual (only chinese yet, but a google translator will help you) and read the chapter 7. The other chapters will help you too. You will have to recompile your kernel and add a new driver to use these functions. Yossarian, Now Im mapping the gpio pins to know which can i use for input/output. If you have something like this please post here. :D My driver support gpioj read/write (I created an array with mapping constants), but i didnt try to set values to it yet. regards
dear eduardo, Please can you post how did you make your driver support gpioj? I found following two gpiolib.c files. Which one to use? -rw-r--r-- 1 kailas src 3322 2009-03-24 04:42 ./arch/arm/plat-s3c24xx/gpiolib.c -rw-r--r-- 1 kailas src 31701 2009-03-24 04:42 ./drivers/gpio/gpiolib.c I guess I have to modify the first one, but not sure what to modify :(
Dear Vikas, I based my driver on two files: eduardo@eduardo-desktop:/opt/FriendlyARM/mini2440/linux-2.6.29/arch/arm/mach-s3c 2410/include/mach$ ls -la | grep regs-gpio -rw-r--r-- 1 root root 42539 2009-03-23 20:12 regs-gpio.h -rw-r--r-- 1 root root 3924 2009-03-23 20:12 regs-gpioj.h eduardo@eduardo-desktop:/opt/FriendlyARM/mini2440/linux-2.6.29/arch/arm/mach-s3c 2410/include/mach$ I built a new device driver using the gpio map available on these files. My new driver is located at: eduardo@eduardo-desktop:/opt/FriendlyARM/mini2440/linux-2.6.29/drivers/char$ You will have to use s3c2410_gpio_getpin, s3c2410_gpio_setpin and s3c2410_gpio_cfgpin functions. Take a look at mini2440_buttons.c, i built something like that, but using the functions above. To build your own kernel with the new driver, please read the chapter 7 of micro 2440 user manual (if you dont know chinese, use google translator). regards
Hi eduardo, I wrote something similar to mini2440_leds. I am trying to set GPJ0-GPJ12 as output lines. After setting 8-9 lines, the board hangs. I hv written kernel module for this. would you be able to share your code, (only if you are okay with sharing)?
Hi, i compiled the the kernel with gpio support, but in the /sys/class/gpio/ directory i am getting only these entries as show below.... [root@FriendlyARM gpio]# ls export gpiochip128 gpiochip192 gpiochip32 gpiochip96 gpiochip0 gpiochip160 gpiochip224 gpiochip64 unexport But these are only the base port gpio's, i want to use all the left gpio's like GPB[0..1], GPE[11,13..15],GPF[0..6], GPG[0..3,5..7,9..11],GPH[9..10] etc... can anybody tell me the procedure to get all the GPIO's working. Which files are to be changed. I am using micro2440. its not mini2440 board which is having 34 pin connector. my board is having 56 pin connector. please help me out. Thanks
Hi endurdo, Thanks for the reply. I gone through the files mentioned in the post. Can you give me example sample code of how and where to put changes so that other GPIO,s get enabled for me. Thanks
Hi, By changing the array i am getting The H port, but still in the /sys/class/gpio/ there is no entry for J port. it stops at 224. I gone through all the related file but unable to figure out. Please help me to get out of these problem. Thanks
Hi All, can anyone help me to get GPIOJ enabled. I tried all the mentioned file. Can any one tell me where exactly make the changes and in which file. Thanks
can anyone tell me up : if i am using the GPIO for I/O in each sec will the flash be having any problem as the /sys/class/gpio/gpioxxx/value is being written each time in flash & flash has a limited write cycles as I have configured the J port now for GPIO but will it work for long i am worried or will i hv to implement pipe if so how to do that
Hi, I have a question same as rabut. Use fopen() and fwrite() to access file in /sys/class/gpio.. , my application will write to /sys/class/gpio/gpioxxx/value about 10 times a second. So is there any problem when running for long time?
@Patric, Thanks for the example, I am also interested to access gpio pin directly from the userspace. Thanks & Regards, miniarm
mgdaubo, everything in 'sys/' is a so called 'virtual filesystem' (refer 'sysfs'). It only exist in the RAM of your target. So changing anything in "/sys/class/gpio/gpioxxx/value" does not touch your flash.
hey cn smeby xplain me... how to get sys/class/gpio??its not present in my tiny6410 android m tryin hard to get acess but its not doing...:( not only gpio but also led ,adc none of the files are available... n i ve read the forum post they say to recompile kernel... n even dont how to do dat.. if nyone could provide me the solution... thnks in advance...
Hi, Can anybody help me how to use the GPIO of tiny 6410 board . I want to use the unused header GPIO pins on the board for my application . I am using Linux platform .Please help me how to add the GPIO support in the sys/class/ .
