Will a netinstall image from debian.org work on a NanoPi M2?
Stock Debian?
I believe they modify the kernel configuration to work with their boards. For example, when I look at: make menuconfig in linux-4.x.y supplied for the NanoPi I find USB_G_FRIENDLYARM I searched for "Friendly" and only found that .. I expected to find more. Do you see that in mainline? Also, for the mini2440 the contents of /arm/arm/mach-s3c24xx/ was modified. Check that file for your processor type and see if it has been changed, both in their kernel and mainline. Try searching for *.ini as I believe some product had a friendlyarm.ini
...rather than Linux, so I should pull down the sources from both repositories and do a recursive diff.
Sounds like a plan. I have used diff once on Linux source code, so won't be of much help. When you find the different files maybe list them for us.
