Hi all . root@NanoPi3:/home/fa# touch /SWAP root@NanoPi3:/home/fa# dd if=/dev/zero of=/SWAP bs=1M count=128 128+0 records in 128+0 records out 134217728 bytes (134 MB) copied, 23.1655 s, 5.8 MB/s root@NanoPi3:/home/fa# mkswap /SWAP Setting up swapspace version 1, size = 131068 KiB no label, UUID=15a0107d-f2a1-4ecd-ad91-8a76e7e92e4c root@NanoPi3:/home/fa# swapon /SWAP swapon: /SWAP: swapon failed: Function not implemented how to conquer ' swapon failed: Function not implemented ' ? ------------- regards
nano pi M3 ; cannot swap
from http://forum.odroid.com/viewtopic.php?f=22&t=871 enable CONFIG_SWAP on the kernel. but for amature like me , iti is hard to do . please update linux image . --- regards
Beat me to it. Have a look for sway on this forum: http://billforums.station51.net/
thanks for advice . but i cannot find sway in http://billforums.station51.net/. --------- i follow http://wiki.friendlyarm.com/wiki/index.php/NanoPi_M3#Compile_Linux_Kernel. and after make menuconfig, fa@NanoPi3:~/Kernel/linux-3.4.y$ diff .config .config-ori 53c53 < CONFIG_SWAP=y --- > # CONFIG_SWAP is not set 96d95 < # CONFIG_CGROUP_MEM_RES_CTLR_SWAP is not set by wget -c http://www.dragonwake.com/download/arm9-download/linux-toolchain/arm-lin... but i cannot prepare to use arm-linux-gcc . how to prepare arm-linux-gcc ? ----- regards
acoording your advice , i found https://github.com/friendlyarm/prebuilts/tree/master/gcc . and follow http://wiki.friendlyarm.com/wiki/index.php/How_to_build_the_Compiling_En... but fa@NanoPi3:~$ echo $PATH /opt/FriendlyARM/toolschain/4.4.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/ga mes:/usr/games: but fa@NanoPi3:~$ arm-linux-gcc -v /opt/FriendlyARM/toolschain/4.4.3/bin/.arm-none-linux-gnueabi-gcc: 1: /opt/FriendlyARM/toolschain/4.4.3/bin/.arm-none-linux-gnueabi-gcc: Syntax error: "(" unexpected how to cope with this ? --- regards
i may download the wrong file . it is hard to download arm-linux-gcc-4.4.3.tar.gz of friendlyarm . i must do some effort .
Seen that mentioned before, search the specific error message.
Does the M3 require a 64 bit development environment?
i did git clone https://github.com/friendlyarm/prebuilts.git now md5sum arm-linux-gcc-4.4.3.tar.gz 1be8415ee80ba0746baedce41a4b04ba arm-linux-gcc-4.4.3.tar.gz and ls /opt/FriendlyARM/toolschain/4.4.3/ arm-none-linux-gnueabi bin include lib libexec share and echo $PATH /usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/opt/FriendlyARM/toolsc hain/4.4.3/bin arm-linux-gcc -v /opt/FriendlyARM/toolschain/4.4.3/bin/.arm-none-linux-gnueabi-gcc: 1: /opt/FriendlyARM/toolschain/4.4.3/bin/.arm-none-linux-gnueabi-gcc: Syntax error: "(" unexpected too hard ! i give up .
Well, it might help if you answered my question. You are running on a 64bit platform? Also, why 4.4.3, when according to the wiki page you need 4.9.3
default nano pi M3 , perhaps 64 bit . i follow http://wiki.friendlyarm.com/wiki/index.php/NanoPi_M3#Install_Cross_Compiler but but arm-linux-gcc -v -bash: /opt/FriendlyARM/toolchain/4.9.3/bin/arm-linux-gcc: cannot execute binary file: Exec format error this is also hard wall to climb . ----- regards
i make mistakes . this is a cross compiler ! i did i on debiandog 64 linux . --- Download the compiler package: git clone https://github.com/friendlyarm/prebuilts.git sudo mkdir -p /opt/FriendlyARM/toolchain sudo tar xf prebuilts/gcc-x64/arm-cortexa9-linux-gnueabihf-4.9.3.tar.xz -C /opt/FriendlyARM/toolchain/ Then add the compiler's directory to "PATH" by appending the following lines in "~/.bashrc": export PATH=/opt/FriendlyARM/toolchain/4.9.3/bin:$PATH export GCC_COLORS=auto Execute "~/.bashrc" to make the changes take effect. Note that there is a space after the first ".": . ~/.bashrc ---- then arm-linux-gcc -v 組み込み spec を使用しています。 COLLECT_GCC=arm-linux-gcc COLLECT_LTO_WRAPPER=/opt/FriendlyARM/toolchain/4.9.3/libexec/gcc/arm-cortexa9-li nux-gnueabihf/4.9.3/lto-wrapper ターゲット: arm-cortexa9-linux-gnueabihf configure 設定: /work/toolchain/build/src/gcc-4.9.3/configure --build=x86_64-build_pc-linux-gnu --host=x86_64-build_pc-linux-gnu --target=arm-cortexa9-linux-gnueabihf --prefix=/opt/FriendlyARM/toolchain/4.9.3 --with-sysroot=/opt/FriendlyARM/toolchain/4.9.3/arm-cortexa9-linux-gnueabihf/sys -root --enable-languages=c,c++ --with-arch=armv7-a --with-tune=cortex-a9 --with-fpu=vfpv3 --with-float=hard --with-pkgversion=ctng-1.21.0-229g-FA --with-bugurl=http://www.friendlyarm.com/ --enable-__cxa_atexit --disable-libmudflap --disable-libgomp --disable-libssp --disable-libquadmath --disable-libquadmath-support --disable-libsanitizer --with-gmp=/work/toolchain/build/arm-cortexa9-linux-gnueabihf/buildtools --with-mpfr=/work/toolchain/build/arm-cortexa9-linux-gnueabihf/buildtools --with-mpc=/work/toolchain/build/arm-cortexa9-linux-gnueabihf/buildtools --with-isl=/work/toolchain/build/arm-cortexa9-linux-gnueabihf/buildtools --with-cloog=/work/toolchain/build/arm-cortexa9-linux-gnueabihf/buildtools --with-libelf=/work/toolchain/build/arm-cortexa9-linux-gnueabihf/buildtools --enable-lto --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --enable-threads=posix --enable-linker-build-id --with-linker-hash-style=gnu --enable-plugin --enable-gold --disable-multilib --with-local-prefix=/opt/FriendlyARM/toolchain/4.9.3/arm-cortexa9-linux-gnueabih f/sys-root --enable-long-long スレッドモデル: posix gcc バージョン 4.9.3 (ctng-1.21.0-229g-FA) OK
continued ! using debiandog 64 ( **not** nano pi M3) git clone https://github.com/friendlyarm/linux-3.4.y.git cd linux-3.4.y $ ls COPYING MAINTAINERS arch fs lib security CREDITS Makefile block include mm sound Documentation README crypto init net tools Kbuild REPORTING-BUGS drivers ipc samples usr Kconfig android firmware kernel scripts virt git checkout nanopi2-lollipop-mr1 touch .scmversion make nanopi3_linux_defconfig but 'make menuconfig' cannot be done . so directly cp .config .config-ori do `vi .config ' ## puppy@debian:~/linux-3.4.y$ make uImage scripts/kconfig/conf --silentoldconfig Kconfig .config:54:warning: override: reassigning to symbol SWAP * * Restart config... * * * Control Group support * Control Group support (CGROUPS) [Y/n/?] y Example debug cgroup subsystem (CGROUP_DEBUG) [N/y/?] n Freezer cgroup subsystem (CGROUP_FREEZER) [Y/n/?] y Device controller for cgroups (CGROUP_DEVICE) [Y/n/?] y Cpuset support (CPUSETS) [Y/n/?] y Include legacy /proc/<pid>/cpuset file (PROC_PID_CPUSET) [Y/n] y Simple CPU accounting cgroup subsystem (CGROUP_CPUACCT) [Y/n/?] y Resource counters (RESOURCE_COUNTERS) [Y/n/?] y Memory Resource Controller for Control Groups (CGROUP_MEM_RES_CTLR) [Y/n/?] y Memory Resource Controller Swap Extension (CGROUP_MEM_RES_CTLR_SWAP) [N/y/?] (NEW) ^C/home/puppy/linux-3.4.y/scripts/kconfig/Makefile:33: recipe for target 'silentoldconfig' failed ## make uImage but Kernel: arch/arm/boot/zImage is ready UIMAGE arch/arm/boot/uImage "mkimage" command not found - U-Boot images will not be built /home/puppy/linux-3.4.y/arch/arm/boot/Makefile:101: recipe for target 'arch/arm/boot/uImage' failed make[1]: *** [arch/arm/boot/uImage] Error 1 /home/puppy/linux-3.4.y/arch/arm/Makefile:291: recipe for target 'uImage' failed make: *** [uImage] Error 2 failed !! ----------------- regards
continued SUCSESS! 1) diff .config .config-ori 53c53 < CONFIG_SWAP=y --- > # CONFIG_SWAP is not set 96,97d95 < CONFIG_CGROUP_MEM_RES_CTLR_SWAP=y < CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED=y 2) aptitude install u-boot-tools then make uImage CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: 'include/generated/mach-types.h' is up to date. CALL scripts/checksyscalls.sh CHK include/generated/compile.h Kernel: arch/arm/boot/Image is ready Kernel: arch/arm/boot/zImage is ready UIMAGE arch/arm/boot/uImage Image Name: Linux-3.4.39-s5p6818 Created: Sun Jul 3 05:17:04 2016 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4395712 Bytes = 4292.69 kB = 4.19 MB Load Address: 40008000 Entry Point: 40008000 Image arch/arm/boot/uImage is ready puppy@debian:~/linux-3.4.y$ ls -l arch/arm/boot/uImage -rw-r--r-- 1 puppy puppy 4395776 7月 3 05:17 arch/arm/boot/uImage puppy@debian:~/linux-3.4.y$ md5sum arch/arm/boot/uImage 6c33f23d631cea0e0ad5ae58ada02183 arch/arm/boot/uImage --- regards
all is written in http://akita-8core.blogspot.jp/2016/06/nano-pi-m3.html
this morning , i try to boot nano pi M3 by rebuilded uIimage . nano pi M3 can boot , but swapon /SWAP swapon: /SWAP: swapon failed: Function not implemented --- regards
1.The following commands can create a 128MB file to be for virtual memory (swap),of courses,you can modify the first command to change size yourself. dd if=/dev/zero of=/var/swapfile bs=1M count=128 chmod 0600 /var/swapfile mkswap /var/swapfile swapon -f /var/swapfile 2. You need to compile kernel to open swap partition,after using supports open swap partition kernel to instead of old kernel that you can excuse the above commands.
