Hi, I successfully ported Uboot to NAND of mini2440 1GB. I converted the zImage_W35 supplied with DVD to uImage using mkimage utility of Uboot. I created jffs2 rootfs using rootfs_qtopia_qt4-20141223.tar.gz downloaded from mini2440 download section. And then I followed Forrest's Blog to port kernel and rootfs and final setup. I showed up as completed successfully. But after reset and booting it stuck up with logo screen. the Uboot messages in minicom are as follows: U-Boot 1.3.2-mini2440 (Aug 18 2010 - 16:23:28) I2C: ready DRAM: 64 MB NOR Flash not found. Use hardware switch and 'flinit' Flash: 0 kB NAND: 1024 MiB Found Environment offset in OOB.. USB: S3C2410 USB Deviced In: serial Out: serial Err: serial MAC: 08:08:11:18:12:27 Hit any key to stop autoboot: 0 Loading from NAND 1GiB 3,3V 8-bit, offset 0x60000 Image Name: Created: 2016-05-28 6:49:42 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2332516 Bytes = 2.2 MB Load Address: 30008000 Entry Point: 30008000 ## Booting kernel from Legacy Image at 32000000 ... Image Name: Created: 2016-05-28 6:49:42 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2332516 Bytes = 2.2 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux............................................................. Linux version 2.6.32.2-FriendlyARM (root@wwd-ubuntu) (gcc version 4.4.3 (ctng-15 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 CPU: VIVT data cache, VIVT instruction cache Machine: FriendlyARM Mini2440 development board Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C24XX Clocks, (c) 2004 Simtec Electronics S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: root=/dev/mtdblock3 rootfstype=jffs2 console=ttySAC0,115200 PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 59968KB available (4292K code, 455K data, 156K init, 0K highmem) SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Hierarchical RCU implementation. NR_IRQS:85 irq: clearing pending status 02000000 irq: clearing subpending status 00000007 irq: clearing subpending status 00000002 Console: colour dummy device 80x30 console [ttySAC0] enabled Calibrating delay loop... 201.93 BogoMIPS (lpj=504832) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics DMA channel 0 at c4808000, irq 33 DMA channel 1 at c4808040, irq 34 DMA channel 2 at c4808080, irq 35 DMA channel 3 at c48080c0, irq 36 S3C244X: Clock Support, DVS off bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c-i2c s3c2440-i2c: slave address 0x10 s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (double precision) yaffs Dec 31 2015 13:59:58 Installing. msgmni has been set to 117 alg: No test for stdrng (krng) io scheduler noop registered (default) Console: switching to colour frame buffer device 40x15 fb0: s3c2410fb frame buffer device backlight initialized leds initialized buttons initialized pwm initialized adc initialized s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440 loop: module loaded S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns s3c24xx-nand s3c2440-nand: NAND soft ECC NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Scanning device for bad blocks Creating 5 MTD partitions on "NAND 1GiB 3,3V 8-bit": 0x000000000000-0x000000040000 : "supervivi" 0x000000040000-0x000000060000 : "param" 0x000000060000-0x000000560000 : "Kernel" 0x000000560000-0x000040560000 : "root" mtd: partition "root" extends beyond the end of device "NAND 1GiB 3,3V 8-bit" -0 0x000000000000-0x000040000000 : "nand" PPP generic driver version 2.4.2 PPP Deflate Compression module registered PPP BSD Compress...stripped-down
Linux on booting stuck up with logo screen
I am Ayyappan Mk posted in the previous post.Sorry the message body was stripped.So attaching the minicom messages as file attachment. And the output of mtdparts and print env commands are as follows. U-Boot 1.3.2-mini2440 (Aug 18 2010 - 16:23:28) I2C: ready DRAM: 64 MB NOR Flash not found. Use hardware switch and 'flinit' Flash: 0 kB NAND: 1024 MiB Found Environment offset in OOB.. USB: S3C2410 USB Deviced In: serial Out: serial Err: serial MAC: 08:08:11:18:12:27 Hit any key to stop autoboot: 0 MINI2440 # mtdparts device nand0 <mini2440-nand>, # parts = 4 #: name size offset mask_flags 0: u-boot 0x00040000 0x00000000 0 1: u-boot_env 0x00020000 0x00040000 0 2: kernel 0x00500000 0x00060000 0 3: rootfs 0x3faa0000 0x00560000 0 active partition: nand0,0 - (u-boot) 0x00040000 @ 0x00000000 defaults: mtdids : nand0=mini2440-nand mtdparts: <NULL> MINI2440 # MINI2440 # MINI2440 # MINI2440 # printenv bootargs=root=/dev/mtdblock3 rootfstype=jffs2 console=ttySAC0,115200 bootdelay=3 baudrate=115200 ethaddr=08:08:11:18:12:27 ipaddr=10.0.0.111 serverip=10.0.0.4 netmask=255.255.255.0 usbtty=cdc_acm mini2440=mini2440=0tb bootargs_base=console=ttySAC0,115200 noinitrd bootargs_init=init=/sbin/init root_nand=root=/dev/mtdblock3 rootfstype=jffs2 root_mmc=root=/dev/mmcblk0p2 rootdelay=2 root_nfs=/mnt/nfs set_root_nfs=setenv root_nfs root=/dev/nfs rw nfsroot=${serverip}:${root_nfs} ifconfig_static=run setenv ifconfig ip=${ipaddr}:${serverip}::${netmask}:mini240 ifconfig_dhcp=run setenv ifconfig ip=dhcp ifconfig=ip=dhcp set_bootargs_mmc=setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} } set_bootargs_nand=setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440}} set_bootargs_nfs=run set_root_nfs; setenv bootargs ${bootargs_base} ${bootargs_} mtdids=nand0=mini2440-nand mtdparts=mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x005) filesize=649AEA4 bootcmd=nboot.e kernel ; bootm partition=nand0,0 mtddevnum=0 mtddevname=u-boot Environment size: 1164/131068 bytes MINI2440 # =========================================================================== the size of rootfs is 105 MB approx. Please help to fix this. Regards, Ayyappan
Hi, I doubt that the static partitioning done in kernel code mini2440.c must be commented and rebuild the kernel image or enable command line mtdparts args accepting should be enabled in the kernel and rebuild the kernel image or enable jffs2 rootfs option in the kernel and rebuild the kernel image not sure which I have to do. But if in any case to rebuild I could not setup toolchain with arm-Linux-gcc-4.4.3 tar downloaded from the download section of mini2440 page. after downloading I gave the command sudo tar xvzf Downloaded_tar_filename -C It extracted the toolchain to /opt/FriendlyARM/ folder. And I added that path to PATH environment variable by editing /root/.bashrc and adding the line "export PATH=$PATH:/opt/FriendlyARM/path to bin folder/" at the end and saved the file. And restarted to get effective. Now I typed arm-Linux-gcc -v in terminal to check whether toolchain was installed properly. but that command showed as "command not found". Even I tried by changing the mode of the toolchain by "sudo chmod 777 /path_to_toolchain/" in the doubt it had not got executable permissions by default. still the command arm-Linux-gcc -v did not show the expected messages that toolchain was installed successfully. Please help me to fix this also.
