Hi, In order to learn Linux and an embedded system, I started with Linux Mint and FriendlyARM Mini2440 development board. I got a lot of support and guidance from forums in this FriendlyARM community. I studied the basics of Linux from the book, Beginning Linux Programming by Neil Matthew and Richard Stones. I cross compiled the toolschain for Mini2440 and compiled and ran simple applications on the Mini2440:- https://alselectro.wordpress.com/2013/01/05/cross-compiler-installation-... I also implemented tutorials by mini2440vietnam:- http://mini2440vietnam.blogspot.in/2011/04/upgrade-qt462-in-mini2440.html But the tutorials by minivietnam2440 are all Qt based. Although i have successfully compiled Qt on my Mini2440, my need is to learn programming the Mini2440 in Linux environment(without Qt). I am trying to find tutorials to control the touchscreen and tft display, but couldn't find anything that shows how to control the touchscreen and tft without Qt. I referred to the example codes provided with the Mini2440 and modified them to toggle leds, use switches etc. I need to write some programs to detect touch on the touchscreen, plot some figures on the tft etc. Please share some links which would guide to start programming the touchscreen and tft.
Proceeding with Mini2440 in Linux environment
https://en.wikipedia.org/wiki/Linux_framebuffer https://www.opengl.org/wiki/Framebuffer RRDtools for graphs PHPplot (PHPlot)
Hi davef, I went through the links. While searching for some help, i found this link:- http://www.pengutronix.com/oselas/bsp/pengutronix/mini2440_bsp_en.html I have downloaded the OSELAS.BSP-Pengutronix-Mini2440-Quickstart.pdf and am reading it. Should i go ahead with Pengutronix ??? How much will Pengutronix help me with Mini2440 ??
I used the Pengutronix BSP for years. If you are going to stick with the mini2440 then it was a useful distro. For a free package the support was excellent. Unfortunately, it hasn't been updated for over a year. http://git-public.pengutronix.de/?p=OSELAS.BSP-Pengutronix-Mini2440.git;... http://blog.gmane.org/gmane.comp.embedded.ptxdist.oselas.community When compared with trying to do all the cross-compiling using your own scripts and then trying to debug them it was a quantum-leap forward. About a 9 months ago I got some NanoPi, which uses a newer chip similar to the mini2440, but is now also EOL. The real plus with the NanoPi is that it comes with Debian Jessie and so just about any Linux program you want is just a apt-get install "away". The NanoPi2 has an Ubuntu-Core with embedded QT image, which I am going to try out next week. And then there is the NanoPC-T2, which I would consider buying next. Except I see there is a proposed NanoPC-T3. The Quickstart guide is a very useful document. What are your future plans? To work in the field or just "play".
What are your future plans? To work in the field or just "play". I have been working as an embedded systems engineer in biomedical field for the past 8 years. All these years i have worked in Windows environment with 8051,PIC,AVR,MSP and ARM processors. I have designed many biomedical equipments using these tools and deployed them on-site. Recently i designed an Electrocardiogram(ECG) Holter device which collects ECG data from patient and hosts it to server, and plots the same on PC and Android/IOS based mobile applications. But all these years i never got a chance to work in Linux environment, so i started learning it. This forums helped me a lot to get going!! :-) Regarding my future plans, i want to replicate the same holter on an embedded system with Linux environment. So i got myself a FriendlyARM Mini2440 which has good processor speed, memory, ARM controller to do ECG filtering operations, WEB server, decent price, etc...just suitable for my project. My aim is to read ECG from SPI-based Analog Front-end and plot it on the Mini2440's display. I would also like to add some touch screen functionalities like "Start ECG Plotting", Stop ECG Plotting" etc... I have already done the ECG acquisition and filtering part in my Windows based project. So for Mini2440 project, i need to read the SPI and plot the ECG on Mini2440's display. So basically i want to work in the field rather than just "play". I am extremely grateful to you for asking me this question. It allowed me to express my exact requirement and expectation from the Linux+Mini2440. Thanks a ton!!
A simple step on my side would be to just connect a simple temperature sensor to the Mini2440, and display and plot the temperature values on the Mini2440's display. But i got so much jumbled, trying lot of things like Qt etc that now i don't understand how to proceed. And this forum is the only help i got coz there's no one around proficient enough with embedded systems in Linux environment. Leaving the development simply because i cannot find anything, is not an option. I want to complete what i have started. I really appreciate your help. This simple temperature sensor project is sufficient for me to get going.
I went through the pain of getting a SPI kernel driver to perform a loop-back test and then moved all my data acquisition to a ATmega32U4 dev board from Adafruit. A DS18B20 was easy to interface to the ATmega32U4 using Teensy USB serial code and some I2C libs by Martin Thomas. Paolo at sereno-on-line did a Qt app on a mini6410. I can find some of the threads but not his site. Have you considered the NanoPi2 with a matrix kit? A current and much better learning environment.
RRDtools is a real-time graphing program. Think it would be ideal for an ECG printout. How to integrate it with some touch buttons? Maybe, Qt http://www.friendlyarm.net/forum/topic/1068 is the oscilloscope Paolo started. I am not trying to discourage you from trying to do it on a mini2440, just that is a fairly big job. How about Qt Creator and see if you can develop your GUI. (mini2440vietnam) There is a bit of information on SPI for the mini2440 around. Are you comfortable re-compiling kernels?
Actually i couldn't get my touchscreen to work in Qt. I had discussed that with you in the thread:- http://www.friendlyarm.net/forum/topic/6602 So i left Qt altogether to focus on learning Linux and Mini2440. Should i switch back to Qt for developing my application ?? But then, for Qt, the touchscreen problem remains !!
All the links in http://www.friendlyarm.net/forum/topic/1068 lead to bad request. I have used the DS18S20 temperature sensor before. "Are you comfortable re-compiling kernels?" No, i am not. I think i need to learn this first. Any sources for learning kernel development and compiling ??
Hi Dave, I will learn the kernel compiling part. I need to get my touchscreen working with Qt first. I tried everything given by <mini2440vietnam> for Qt compilation on Mini2440, but my touchscreen doesn't seem to work with Qt. How do i get my touchscreen to work ??
I posted a touchscreen response on the other thread. Google for <Building Embedded Linux Systems.pdf> The 3rd edition might be available for download.
Hi Davef, https://importgeek.wordpress.com/2012/04/09/compiling-qt-and-tslib-for-m... is exactly what is used for compiling Qt on my Mini2440. I have followed all the steps mentioned in this link. billforums.station51.net/viewtopic.php?f=8&t=15 advises to run a script to calibrate the tft and run a demo, which i will try. I will go through the <Building Embedded Linux Systems.pdf> straightaway.
Further, in https://importgeek.wordpress.com/2012/04/09/compiling-qt-and-tslib-for-m... , export TSLIB_TSDEVICE=/usr/local/tslib/lib/ts while in http://billforums.station51.net/viewtopic.php?f=8&t=15 , export TSLIB_TSDEVICE=/dev/input/touchscreen0 I have tried the first one and it doesn't work. Will try the next one...
I think I mentioned this recently in another thread, tell me all the entries that you have in /dev/input/
Doesn't look like many /dev entries! Did you check what event0 as described recently? I will check my Pengutronix BSP
On my mini2440:
event0 stylus
event1 is a link from buttons
event2 keyboard
event3 mouse
mice mouse
mouse0 stylus
mouse1 mouse
touchscreen is a link to event0
I'd be surprised if your event0 was not the stylus input.
My Pengutronix Qt related settings in profile.environment
# Mini2440 related settings
MINI2440_FBDEV=/dev/fb0
MINI2440_KEYEVENT=/dev/input/event2
MINI2440_TOUCHEVENT=/dev/input/touchscreen
# touchscreen relevant settings
export TSLIB_TSDEVICE=${MINI2440_TOUCHEVENT}
export TSLIB_CONSOLEDEVICE=none
export TSLIB_FBDEVICE=${MINI2440_FBDEV}
#export TSLIB_CALIBFILE
#export TSLIB_CONFFILE
#export TSLIB_PLUGINDIR
# Qt relevant settings
#export QWS_MOUSE_PROTO=Tslib:${MINI2440_TOUCHEVENT}
export QWS_MOUSE_PROTO="MouseMan:/dev/input/mice
Tslib:${MINI2440_TOUCHEVENT}"
I don't know how the relevant dev nodes are made. I do know how to create
them but do not have a clue from to connect them to the relevant bit of
hardware.
"event0 stylus event1 is a link from buttons event2 keyboard event3 mouse mice mouse mouse0 stylus mouse1 mouse touchscreen is a link to event0" How do we determine these parameters ?? Further, in export QWS_MOUSE_PROTO="MouseMan:/dev/input/mice, what is "MouseMan" ?? I am using export QWS_MOUSE_PROTO=tslib:/dev/input/event0. If i determine parameters of my Mini2440, i will change them to appropriate ones...
"Doesn't look like many /dev entries!" No, there are lots of entries in my /dev. Check attachment. But just two entries in /dev/input...
Sorry, I did mean /dev/input > MouseMan Good question. I was told to try it and it worked. cd /dev/input cat event0 and move your finger over the touchscreen. You should see a stream of characters on your display. Or move the mouse or type characters on the keyboard. After the rubbish you may have to reboot or type cd/home and enter might get you back to a normal screen.
Pengutronix mini2440 quick start.pdf A functional touchscreen depends on some external configurations and parameters. Firstly, the touchscreen driver for the S3C2440 CPU must be enabled in the kernel. If it is supported, it can be checked at run-time with the following command: # ls /sys/bus/platform/drivers A samsung-ts must be listed in this directory. If not, the kernel must be re-configured to support this device. Secondly, a functional touchscreen depends on is the registered touchscreen device. If it is registered, this can be checked at run-time with this command: # ls /sys/bus/platform/devices A s3c2440-ts must be listed in this directory. If not, something is preventing the kernel from registering this device.
"Or move the mouse or type characters on the keyboard." I have never connected mouse or keyboard to my Mini2440. I have always communicated with Mini2440 through putty terminal. But will do cd /dev/input cat event0 and get back. Btw, where can i find the "standard" list of environment variables for Qt and Mini2440 ?? Also how can i find my "event0 event1 event2 event3 mice mouse0 mouse1 touchscreen" ??
I am not aware of any standard list. You will not have all those entries unless you use the Pengutronix mini2440BSP and have Qt set up the same way as me. ADDED INFO: the entries in /dev/input are called <event nodes> I am doing all these tests not using minicom/putty. I will connect up the system and do it your way.
Using minicom I get the same behaviour. I am at a remote location (daily data allowance 16MB) and haven't got all my LINUX docs. In one of the long QT threads on this site I posted a doc called something like QT browser Pengutronix. Search around and see if you find it.
Read some of your discussions in the forums:- http://www.friendlyarm.net/forum/topic/6417 http://www.friendlyarm.net/forum/topic/6328 http://www.friendlyarm.net/forum/topic/3086 The OP in http://www.friendlyarm.net/forum/topic/6328 seems to have solved the touchscreen issue. Lets see if he has some inputs for us... I will search the QT browser Pengutronix doc and get back.
I re-checked the other thread and see I posted the document! I need to establish what you mean by the touchscreen does not work. I might be going down a detour talking about the stylus input. Is the the actual display doesn't work or the stylus?
"If it is the touchscreen display that is not working ,,, have you got a /dev/fb0" Yes, i have /dev/fb0. I am attaching its screenshot. My touch screen works when i un-comment Qtopia from /etc/init.d/rcS. "Is the the actual display doesn't work or the stylus?" Sorry, I didn't understand this question.
The touchscreen has two functions: - display stuff using the framebuffer - the touch function, ie either using your finger or a stylus
For some reason Xubuntu will not display your screenshots. When you comment out the lines in rcS what is your next step in trying to see something on the display?
I directly used http://mini2440vietnam.blogspot.in/2012/06/control-leds-on-mini2440-by-q... for application. I think Qt uses the framebuffer internally, i haven't used the framebuffer directly (although it is on my todo list once i get my touchscreen working!!) In the above link, if you see the OP's video in which he has shown his working system, he is using the stylus. And i get the display i.e. i can see the buttons and graphics on the screen, but i cannot use them as the touchscreen is not working. So i think that the display stuff is working but the stylus touch is not working...
When you comment out the lines in rcS what is your next step in trying to see something on the display? I paste the export variables in bith rcS and profile file. After that i run:- $cd /mnt/demos/embedded/fluidlauncher/ $./fluidlauncher -qws which runs correctly. After that i referred to mini2440 vietnam's tutorial to display simple Hello World on the screen: http://mini2440vietnam.blogspot.in/2011/05/programming-application-for-m... this one also runs perfectly. And lastly, i refer this tutorial by mini2440 vietnam to control leds using touch screen:- http://mini2440vietnam.blogspot.in/2012/06/control-leds-on-mini2440-by-q... wherein i can see the graphics in the display, butthe touchscreen doesn't work.
The last step is the first time you want the touch input to work on the display. The result to my last request?
Yes stylus works well in Qtopia. Will post the results cd /dev/input cat event0 soon...please gimme some time.
Hi Davef, I tried doing cd /dev/input cat event0, but nothing happens in the terminal or on the screen !!
I just used framebuffer(/dev/fb0) to print some red color shades on the display. I also connected mouse to the USB port of the Mini2440. The putty terminal shows "Optical mouse connected", but the cursor doesn't move...
I developed some more apps involving touchscreen and display in Qt. I can see the from on the tft, but touch doesn't work...
> I tried doing cd /dev/input > cat event0, but nothing happens in the terminal or on the screen !! Now, I think we are getting somewhere. 8 hours after I first asked you to do it. Re-enable Qtopia and do the same thing.
As for the mouse ... notice I have 3 mouse event nodes in /dev/input/ When you plug the mouse in and boot up the mini2440 what do you have in /dev/input ?
Another thought ... when you are setup to run your Qt application find out what event0 is really connected to. Plug in a mouse and keyboard and fire the board up and cat event0 and move the mouse and type on the keyboard.
Hi Dave, Sorry for replying late. "Re-enable Qtopia and do the same thing." In this case, the touch screen works, but shows the Qtopia screen when touched. It appears like both screens overlap each other. Qtopia screen at the bottom and Qt app screen on the top. Once touched, the Qtopia screen appears partially where touched. Please see the attachment, you will understand what i am trying to say !!
"When you plug the mouse in and boot up the mini2440 what do you have in /dev/input ?" In this case, in dev/input/ event0 event1 mice mouse0
"Plug in a mouse and keyboard and fire the board up and cat event0 and move the mouse and type on the keyboard." cat event0 doesn't show anything whereas cat event1, cat mice, cat mouse0 show wayward data in the putty terminal when mouse is moved...
Sorry 3.4M I won't download. Can you resize it? I see you are getting more /dev/input entries now, instead of just event0 and mice. In Qtopia and checking each /dev/input entry should show a response to touching the screen. If not I don't understand how the touch feature of the display is working. Are you saying that you get similar "wayward" data in all 3 /dev/input entries, event1, mice and mouse when moving the mouse? I'll check event1 on my system.
"Sorry 3.4M I won't download. Can you resize it?" Sorry, attaching a smaller resized image. See how the screen behaves when Qtopia is enabled and Qt application is executed. "I see you are getting more /dev/input entries now, instead of just event0 and mice." That's right. I get only 2 entries(viz. event0 and mice) when mouse is not connected and 4 entries(viz. event0 event1 mice mouse0) when mouse is connected. "In Qtopia and checking each /dev/input entry should show a response to touching the screen. If not I don't understand how the touch feature of the display is working." Except for event0, rest all cat entries(cat event1, cat mice, cat mouse) show wayward data on the terminal when mouse is moved, not when screen is touched !! "Are you saying that you get similar "wayward" data in all 3 /dev/input entries, event1, mice and mouse when moving the mouse? " Yes, only when mouse is moved. Not when screen is touched.
Something is wrong I can't see the image. Could you check it works for you? Ah, you appear to have hotplugging enabled. Which images are you running on the unit? I was reading through some threads and 1-wire was mentioned. I thought 1-wire was on the mini6410 and not the mini2440, but I could be wrong. One way to check is to see which adc entries there are in /dev and also in a /sys folder. I'll check mine and get back. Something you could try is commenting out one of the entries in your rcS file, ie the mouse, reboot and see if that changes the number of entries in /dev/input. I think it is udev that manages the /dev event nodes.
/sys/devices/platform/s3c24xx-adc/s3c-hwmon/ ADC channels 4,5,6 and 7 are used for the touch feature. In this directory do: cat in4_input cat in5_input cat in6_input cat in7_input Also, copy paste the contents of your /etc/pointercal file By the way you were able to do a ts_calibrate in Qtopia, but not when you "disabled" Qtopia". Section 8.10 in the Oselas Quickstart guide talks about touchscreen problems
"1-wire was on the mini6410 and not the mini2440, but I could be wrong." I can see touchscreen-1wire in my /dev directory. "copy paste the contents of your /etc/pointercal file" Give me sometime for this. "By the way you were able to do a ts_calibrate in Qtopia, but not when you "disabled" Qtopia"." I was able to use touchscreen when i enabled Qtopia, but i didn't do tc_calibrate. Will do that as well and get back. "Section 8.10 in the Oselas Quickstart guide talks about touchscreen problems." Will go through this.
I found some excellent examples here:- https://github.com/Wingie/mini2440_Examples And the same thing again, display works well but no touch !! From the link, i compiled the Mini2440 applications as well the Qt applications, and both compiled and ran on the Mini. So i think i have cross-compiled and set the qmake and used it in Qt creator correctly. Something's wrong with the touchscreen though.
Dave, One think to notice is that both the tutorials suggest:- export TSLIB_TSDEVICE=/usr/local/tslib/lib/ts Whereas i checked all my stuff by using:- export TSLIB_TSDEVICE=/dev/input/event0 And there are people in both the tutorials who have said that they got the system working. Mini2440vietnam has even uploaded a video of his working system in one of his tutorials(which even i followed!!). How come nobody is facing the same problem as mine in both the tutorials ??
> I can see touchscreen-1wire in my /dev directory. On the mini2440? Isn't doing a ts_calibrate in the tutorial? > How come nobody is facing the same problem as mine in both the tutorials ?? When we find out what is wrong on your system ...
Mine is: export TSLIB_TSDEVICE=/dev/input/touchscreen From memory you were asked to do a ts_calibrate the first time you ran Qtopia on the board. I have done it many times since to get the touch to run properly. The resolution is quite fine and to operate a button requires fairly careful calibration. I asked for your pointercal file about 2 hours ago.
Well, I wonder if anyone has tried to run 4.6.2 Qt apps on a 1-wire mini2440. Again searching on the forum might turn up something.
Hi Dave, "Mine is: export TSLIB_TSDEVICE=/dev/input/touchscreen" Do you have touchscreen-1wire in your /dev directory ?? "I asked for your pointercal file about 2 hours ago." Sorry, i am not having my Mini2440 with me right now to give the details of /etc/pointercal. Will give them by evening. "From memory you were asked to do a ts_calibrate the first time you ran Qtopia on the board." Yes, i had done a ts_calibrate in Qtopia wherein it prompts to touch the screen at various points. It had worked then.
"Again searching on the forum might turn up something." I was going through some links and it struck me that since i have /dev/touchscreen-1wire, i need to do export TSLIB_TSDEVICE=/dev/input/touchscreen-1wire instead of export TSLIB_TSDEVICE=/usr/local/tslib/lib/ts or export TSLIB_TSDEVICE=/dev/input/event0 and export QWS_MOUSE_PROTO="tslib:/dev/input/touchscreen-1wire instead of export QWS_MOUSE_PROTO=tslib:/dev/input/event0 Maybe this is the thing !!
In the forum:- http://www.friendlyarm.net/forum/topic/5609 the OP suggests this:- Configure the environment in mini2440: $cd /etc/ $vi profile add those lines at the end of file. please verify that you have these files at the locations specified. otherwise change location as per your system export USER LOGNAME PS1 PATH export LD_LIBRARY_PATH=/usr/local/tslib/lib export QTDIR=/usr/local/Qt export QWS_MOUSE_PROTO="tslib:/dev/touchscreen-1wire IntelliMouse:/dev/input/mic export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_PLUGINDIR=/usr/lib/ts export TSLIB_TSDEVICE=/dev/touchscreen-1wire export TSLIB_TSEVENTTYPE=INPUT export QWS_DISPLAY=LinuxFB:mmWidth=105:mmHeight=140 go to friendly arm forum given at end of following link http://www.friendlyarm.net/downloads go to /src file name: one-wire-ts-input-src-20111026.tar.gz ===================================== an open source tslib for FriendlyARM one wire touch screen, only for Linux, not Android How to use ===================================== by FriendlyARM, 2011-10-26 step1: unzip the source code tarball #make you will get one-wire-ts-input.so, put it into the tiny6410 board: /usr/lib/ts/ Step2: vertify the first line in file "/etc/ts.conf" to: module_raw one-wire-ts-input 5. Run Qt example program: Now we can test Qt example programs $cd /mnt/demos/embedded/fluidlauncher/ $./fluidlauncher -qws use touch now :-) Please note his TSLIB_TSDEVICE and QWS_MOUSE_PROTO parameters !! Are we moving towards a solution!! ??
export QWS_MOUSE_PROTO="tslib:/dev/touchscreen-1wire export TSLIB_TSDEVICE=/dev/touchscreen-1wire After this when i run the Qt applications and touch the screen , it prompts "selected device is not a touchscreen, i understand"
cd /usr/local/bin ./ts_calibrate yields:- Couldn't load module input No raw modules loaded ts_config: Success
Also, i couldn't find one-wire-ts-input-src-20111026.tar.gz. /dev has adc. How to determine which touchscreen i am having on my mini2440 ??
Back to square one with following as my environment variables:- export LD_LIBRARY_PATH=/usr/local/tslib/lib export QTDIR=/usr/local/Qt export QWS_MOUSE_PROTO=tslib:/dev/input/event0 export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/usr/local/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_TSDEVICE=/usr/local/tslib/lib/ts export TSLIB_TSEVENTTYPE=INPUT export QWS_DISPLAY=LinuxFB:mmWidth=105:mmHeight=140 Display working, touchscreen not working !!
export TSLIB_TSDEVICE=/usr/local/tslib/lib/ts for this also, running ./ts_calibrate says:- "selected device is not a touchscreen, i understand"
I could expect that if it is 1-wire that there MIGHT not be an adc? Check that the pot reading changes values when tweaked in Qtopia, refer to the user guide. Refer to my previous post: /sys/devices/platform/s3c24xx-adc/s3c-hwmon/ ADC channels 4,5,6 and 7 are used for the touch feature. In this directory do: cat in4_input cat in5_input cat in6_input cat in7_input That is how you will find out if the ADC channels for the touchscreen are working. I do not know if ts_calibrate is used with 1-wire. I would expect that would still need to calibrate the screen.
"Refer to my previous post: /sys/devices/platform/s3c24xx-adc/s3c-hwmon/ ADC channels 4,5,6 and 7 are used for the touch feature......" From my previous post (with 112.5 KB screenshot):- /sys/devices/platform/ there is no entry for s3c24xx-adc!!
Condition-1) /dev/touchscreen-1wire. Condition-2) No adc entry for s3c24xx-adc in /sys/devices/platform/. Are both these conditions sufficient to conclude that my Mini2440 has a 1-wire touchscreen ??
I'd say so. You must have one of the later units. I have no 1-wire experience on the mini2440. ATmega32U4 yes. Mine are 4-5 years old and only 64MB RAM. Yours could be 256MB or even 1GB which require special versions of uboot.
Tried searching a lot, but couldn't find anything relevant except for downloading "one-wire-ts-input-src-20111026.tar.gz" and following the instructions in http://www.friendlyarm.net/forum/topic/5609 The problem is, i cannot download "one-wire-ts-input-src-20111026.tar.gz". The OP in the link mentions to download it from /src on http://www.friendlyarm.net/downloads. But there's no such thing on the friendlyarm website.
I can execute and calibrate the touchscreen when i enable Qtopia. I ran some programs to display colors on the display. How can i plot a moving sine wave on the display ??
I referred to the link http://www.friendlyarm.net/forum/topic/2733 The last reply says: "The problem is with the new displays they are using 1-wire. For some reason the 1-wire file is not accessible when a Qt app is executing. Luckily the LCD board makes provision to switch to the analog touch screen. Modify the board: http://www.friendlyarm.net/forum/topic/6101" They have mentioned some modifications to the board for it to work with 1-wire touchscreen.
Remove the "; at the end of the link :) What a performance! Good luck with modifying the board. Do you need to persist with the mini2440 or could you move your development to one of their newer product?
The ";" was a typo though!! I don't think modifying the board is a good idea. I won't attempt it. I already displayed some text, plotted lines etc on the display. Touchscreen not working is the only issue that remains. I think i should switch to a new board, which ones do you suggest ?? P.S: I will definately complete my temperature sensor display project on the Mini2440, before the new board arrives ;-) !!
They have brought out about 5-6 new units over the last 6 months. I had a quick look at running the QT embedded image on a NanoPi2. Unfortunately, I don't how to escape the demo (fluidlauncher?), however running QT apps on it must be easy. Heatsinking is preferred on this unit and someone made a recent comment about bad RAM, so need to check mine. I would buy a NanoPC-T3 next to use as a low-power desktop. I run the NanoPi as a automation controller as the power consumption is quite low. Depends what your interests are.
