cross compile opencv via LTIB for ARM
sachin
hello everyone,
finally after 1 month now i am reaching my target for cross compile opencv
via LTIB but following are the net connection issue cant get it...
Processing: opencv
Build path taken because: no prebuilt rpm,
Testing network connectivity
OK GPP:
Try opencv-1.1.0.tar.gz.md5 from the GPP
http://bitshrine.org/gpp/opencv-1.1.0.tar.gz.md5:
18:07:44 ERROR 404: Not Found.
Try opencv-1.1.0.tar.gz from the GPP
http://bitshrine.org/gpp/opencv-1.1.0.tar.gz:
18:07:45 ERROR 404: Not Found.
Can't get: opencv-1.1.0.tar.gz at ./ltib line 802.
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Fri Feb 19 18:07:41 2016
Ended: Fri Feb 19 18:07:45 2016
Elapsed: 4 seconds
These packages failed to build:
opencv
Build Failed
anyone know how to fix it?
What I do is download opencv-1.1.0.tar.gz from somewhere else on the
internet, drop it into the folder where all your other sources are and
presto.
Don't know about the md5 sum ... I never worried about them.
sachin
ok..i will try from other website but i want also change in
/ltib/dist/lfs-5.1/opencv/opencv.spec file for URL path....
sachin
while i burn the rootfs into board maximum commands are not working like
ls,mkdir,mount etc do u know what is the issue?
