HI guys, I'm working with the nanopi2 with android OS. i need to control the GPIO pins of nanopi2 in android application. as well led!!, i.e need to get access to the leds through android . any help is appreciated. thanks ..
Nanopi2 with android
Hello, You can use the lastest android image,the lastest image added iTest program, and it internal the serial grogram. You can download the source code: git clone https://github.com/friendlyarm/android_SerialPortDemo.git
Serial ports are using libfriendlyarm-hardware.so library and Android Studio. Build enough programming done by the parties but not Run.
