hello everyone, i have starting the cross compile opencv via LTIB but i m stuck for following error ==> checking for X... no configure: error: X development libraries not found error: Bad exit status from /home/surekha/Documents/SACHIN/LTIB/L3.0.35_4.1.0_130816_source/yes/ltib/tmp/rpm -tmp.98927 These packages failed to build: gtk2 can anyone know how to resolved this issue??
hello, gtk2 issue was solved by "sudo apt-get install libgtk2.0-dev" and remove the package in ltib folder /ltib/rpm/BUILD/gtk now i am facing new error ==> ./arm-fsl-linux-gnueabi/bin/ld: cannot find -lgssapi_krb5 /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro -toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux- gnueabi/bin/ld: cannot find -lkrb5 /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro -toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux- gnueabi/bin/ld: cannot find -lk5crypto /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro -toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux- gnueabi/bin/ld: cannot find -lcom_err collect2: ld returned 1 exit status make[2]: *** [libftp.la] Error 1 These packages failed to build: gnome-vfs
solve this issue by sudo apt-get remove krb5-multidev package and run ./ltib again solved the problem and gnome-vfs build successfully now...
