Hi, I am using Linux Mint 17 + FriendlyARM Mini 2440 development board. I am referring the following link for setting the cross compiler https://alselectro.wordpress.com/2013/01/05/cross-compiler-installation-... I have successfully installed the cross-compiler and export its path. I have also configured the codeblocks compiler arm-gcc settings to execute files for FriendlyARM2440. Now, when i try to make the examples (provided alongwith the FriendlyARM CD) make hello I get permission denied error. I have attached a picture of the error. Why doesn't the arm-gcc "make" the hello.c even when it is correctly installed?? Thank you in advance, Abhishek Ekhare.
Linux Mint+FriendlyARM Mini2440. Cannot make hello.c
http://www.friendlyarm.net/forum/topic/26 6 1/2 years ago, probably not much help Stopped using CodeBlocks after that.
Hi davef, Thank you for replying. Actually, i have configured codeblocks correctly and have mentioned that in my question. My problem is executing "make hello.c" in the Linux terminal. And sudo make hello.c doesn't help either.
If you are not using CodeBlocks then where is your makefile for this project? It might be easier to just cross-compile it on the command line.
I have not installed build-essentials etc on my host. I have only followed whatever is given in the link:- https://alselectro.wordpress.com/category/friendly-arm-mini2440/ There is no mention of build-essential etc.
Most tutorials make many assumptions about the skill and experience of the user, as well as the tools they are using. Try: sudo apt-get install build-essential sudo apt-get install automake sudo apt-get install autoconf Also, is your host 32 or 64 bits?
Hi, I am still unable to use the command "make hello". So, instead of that i have configured codeblocks to build the files using arm-none-linux-gnueabi toolschain. I generate the binary file and load it into the FriendlyARM through pen-drive. Atleast it got my stuff going, for now!! Cheers!!
You are possibly a lucky guy. Eventually you will face new problems unless you use the same toolchain to built your libraries (in your root filesystem) and your kernel. BTW, on the FriendlyARM Wiki and the NanoPi page you will see a list of tools needed, but it is a special case. Did you export the path to your compiler in .bashrc when you were trying to do it from the command line?
Hi, Actually after much searching, i found out that you need to export the path in .profiles file, not .bashrc !!
And i didn't type anything in the command line. I just installed and configured codeblocks as given in the link:- https://alselectro.wordpress.com/category/friendly-arm-mini2440/ Then i created a new project to print Hello World. I compiled it in codeblocks using the toolschain and generated a hello.bin file. Then i copied hello.bin into pen drive and connected the pen drive to FriendlyARM and ran the commands cd /udisk and ./hello in putty terminal and saw Hello World being printed in putty terminal. P.S: Still getting Permission Denied (as seen in the attached snapshot) when doing make hello or arm-linux-gcc -o hello hello.c
Sorry I thought this: P.S: Still getting Permission Denied (as seen in the attached snapshot) when doing make hello or arm-linux-gcc -o hello hello.c meant you were doing it on the command line Correct .bashrc or .profile depending which host distribution you are using.
No no, while compiling my code in codeblocks, i didn't use command line at all, and generated hello.bin and loaded into FriendlyARM via pen-drive. I used command line only to check if i can build my hello.c from command line (which i eventually couldn't).
I think it would be a good exercise to use the FriendlyArm toolchain and cross-compile your hello.c on the command line. Then have CodeBlocks build your project pointing to the same toolchain. Did you try: arm-linux-gcc -v on the command line? > I am still unable to use the command "make hello". Are you sure <make hello> is a valid command?
Thought I would refresh my memory and compile a test program. On the command line: arm-linux-gcc hello.c -o hello
Hi Davef, I think you got to the crux of my problem!! :-) Actually, when i install the cross compiler for the first time and try >arm-none-linux-gnueabi-cc –v I do not get any error. But after i restart my laptop and try >arm-none-linux-gnueabi-cc –v I get error "no such directory" and "Permissions Denied". I have done all the procedure in /opt directory. But i can still see the toolschain configured in codeblocks, so i proceeded with codeblocks. Yes, i have the makefile provided with the examples with FriendlyARM dvd. I am trying to make the same example (hello.c). Am i following the right procedures (as explained in the link https://alselectro.wordpress.com/2013/01/05/cross-compiler-installation-...) ??????
Regarding the tutorial ... unless I actually try to go through it I can't comment. I notice <extract> was spelled wrong! Also: arm-none-linux-gnueabi-cc is a link to arm-none-linux-gnueabi-gcc. I don't know what is special about arm-none-linux-gnueabi-cc Check around for other mini2440 tutorials. mini2440vietnam has some good stuff.
Hi Davef, " Does: arm-linux-gcc hello.c -o hello work for you? " No it doesn't work for me. I am attaching a screenshot about this...
But you are not typing: arm-linux-gcc hello.c -o hello Also type: arm-linux-gcc -v Until you can do this there is not much point in me looking at your CodeBlocks setup. (I am on a quite limited data package which renews Sunday()
Another thought in your toolchain /bin directory do: ls -la so we can see who owns the files in that directory.
Forget my two previous comments. I notice my export statement is in .bashrc on Ubuntu 14.04LTS arm-linux-gcc -v works for me because that is what I have in my export statement. I am looking at the toolchain for NanoPi, as I don't have FriendlyARM mini2440 toolchain on this machine anymore. Also, I tried changing it to arm-none-linux-gnueabi and I get: command not found Sorry, it has been about 5 years since I cross-compiled my own programs on the mini2440 and obviously I have forgotten a few things! The arm-none-linux-gnueabi directory is there but I can't access it either. All my FriendlyARM notes are about 75kms away, so I can't help further. Also, try <printenv> on the command line and check you have the export path correct. Good luck!
Hi Davef, When i type echo $PATH on the command line, i get the PATH correctly. " The arm-none-linux-gnueabi directory is there but I can't access it either. All my FriendlyARM notes are about 75kms away, so I can't help further. " No worries, I'll find a way out. Thank you for your help!! :-)
Just for fun ... In your toolchain directory is there a folder that is called bin at the same level as your arm-none-linux-gnueabi folder? And in that bin folder a link to arm-linux-gcc? If so, change your export path to that /bin folder and then run arm-linux-gcc -v and if successful then arm-linux-gcc hello,c -o hello and see if that runs on the mini2440.
Yes, will surely try this. On the other hand, since i am getting "Permissions Denied", i will change the permissions of the cd/opt/FriendlyARM/ itself.
From: OSELAS.BSP-Pengutronix-Mini2440-Quickstart.pdf 3.3.4 Protecting the Toolchain All toolchain components are built with regular user permissions. In order to avoid accidential changes in the toolchain, the files should be set to read-only permissions after the installation has finished successfully. It is also possible to set the file ownership to root. This is an important step for reliability, so it is highly recommended. If you get "Permissions Denied" you should be able to just preface your command with: sudo
Hi Davef, Yes you are right with the "sudo" part. Actually my FriendlyARM folder was not having permissions. So i executed cd /opt sudo chmod -R 777 FriendlyARM Now i can execute "make hello" or "arm-linux-gcc hello.c -o hello", generate hello.bin and load it into FriendlyARM development board and execute it. Thank you very much for you valuable time and help :-)
I'd be surprised that your FriendlyARM folder had no permissions, ie 000 In the FA 4.4.3 for the NanoPi the top level directories are 755 and the 4.4.3 directory is 555. From my understanding making the directory with the tools that you use, ie arm-linux-gcc, writeable is not a good idea. In my other toolchain everything is 755. (At least only root can write to these files!) It is difficult to know whether or not you have everything setup in a safe manner until things stop working and you spend days trying to figure out the problem. As, well as permissions, don't forget there is the owner and group descriptions for each file and directory. Happy programming!
"As, well as permissions, don't forget there is the owner and group descriptions for each file and directory." Does it mean that sudo chmod -R 777 FriendlyARM has imparted permissions to only the FriendlyARM folder and not its sub-folders?? Then how did the "make hello" command start working ?? I also tested the led-player and leds programs by using make command and generating and loading their respective binary files into the development board. "It is difficult to know whether or not you have everything setup in a safe manner until things stop working..." Can you give me a sample program to test ?? I will make its binary and load it into my board and check...
chmod -R does every directory under FriendlyARM What I mean is that someday you might accidentally write to a tool or file and change it and then you might end up with a broken system. It appears to be work now so no point in giving you a program. I have never had to change permissions on a toolchain from FriendlyARM. Can you install another toolchain and check the permissions again?
Hi Davef, You suggest me a toolschain. I will install it and check. Also, under which scenarios would i write to a tool or file to change it ??
> Actually my FriendlyARM folder was not having permissions. When you installed this toolchain are you sure the permissions were wrong? Re-install that toolchain and then tell me what the file permissions are in the various directories. > Also, under which scenarios would i write to a tool or file to change it ?? By making a mistake, by something crashing ... all I was suggesting that some methods help to reduce potential errors. I can recall when I started learning Linux, it felt like a million things had to be done correctly OR what I was trying to do would fail. It gets better after you have made several thousand mistakes :) Actually, over the last few years the tools and procedures have become more streamlined, so it is easier to get the desired results. For example, running Debian Jessie on the NanoPi, using the procedure on the FA Wiki page only took a few days to set it up the way I wanted. So, back to your toolchan\in and hello.c
>When you installed this toolchain are you sure the permissions were wrong? Actually, to be true, i really didn't knew what permissions are during installation. I just put my stuff together and started following:- https://alselectro.wordpress.com/category/friendly-arm-mini2440/ (blindly, as you may say!!) >Re-install that toolchain and then tell me what the file permissions are in the various directories. Ok, i will take that risk for the sake of learning. Will get back with results by Monday. One question, do i need to "uninstall" the currently installed toolchain in order to "re-install" it ??? If yes, how do i do that ??
For now rename your folder FriendlyARM to FriendlyARM_modified_permissions and go through the process of installing a new toolchain. When you are confident that the new toolchain is working properly just delete the old one. Just so I know ... where are you downloading the toolchain from and tell me if it has a specific file name?
I used the toolschain from the DVD provided with FriendlyARM development board. I didn't download it from anywhere. Its filename is "arm-linux-gcc-4.4.3.tar.gz"
Hi Davef, Sorry for replying late. I just finished-off some exercises on the FriendlyARM before renaming the folder "FriendlyARM_OLD", and installing the toolchain again in the new folder "FriendlyARM". This toolchain seems to be working fine as well !!
Hi Davef, Thank you very much for your help and support. I really appreciate it. Can you suggest some material which i can refer to, to start programming the FriendlyARM. I have run the sample codes by generating and loading their respective binaries into the FriendlyARM. However, 1]Should i continue with codeblocks ?? 2]How can i write some programs to configure and use the 3.5'display, serial port, usb etc ??
If CodeBlocks is still currently supported, I guess it is worth sticking with as you have some experience. Maybe, have a look at Eclipse. I used it for awhile when I first starting with the mini2440, mainly as a learning exercise. The C code I have written for the mini2440, which is very little, I just used the command line instructions. All my C programming is on the AVR ATmega series. I talk to all the GPIO, ADCs, etc I want using Teensy ATmega32u4 boards as using the SPI, I2C, GPIO, and ADCs on the mini2440 was overly-complicated. I blame many years of experience using the AVR! Search for <mini2440vietnam> he has several good tutorials. Configuring the display will be quite a big challenge. There is a recent thread on C programming the serial port.
Hi Davef, I spent a considerable amount of time learning and understanding Linux and writing some shell scripts. I also practiced some tutorials with Mini2440. I have come to a point wherein i need to install and run QT. Now, QT installation is quite complex and confusing (especially when doing it for the first time). I referred some links on regarding installing Qt on Linux Mint:- https://forum.qt.io/topic/24693/how-to-install-qt-5-0-x-in-linux-mint/2 https://importgeek.wordpress.com/2012/04/09/compiling-qt-and-tslib-for-m... Can you please suggest which one to follow and move ahead with ?? Regards, Abhishek. (Apologies for not opening a new thread for small suggestion).
Pop <mini2440vietnam> into Google. He has a good tutorial on running Qt on the mini2440. Also, search for <sereno-on-line> Paulo has written some good tutorials.
