Hi I'm trying to use the NanoPi UART.
After a bit of searching and reading I understood that I should be using
the UART 1 and 2 leaving the 0 for debug.
So I tested wiring TXD2 with RXD2 and then I tried to send something using
the python library pyserial and the minicom with no luck using the
/dev/ttySAC1, /dev/ttySAC1 and /dev/ttySAC3.
Anybody knows how to make it work?
Testing code:
python:
import serial
ser = serial.Serial("/dev/ttySAC2")
ser.write("UART the Font")
read = ser.read()
print read
ser.close()
minicom:
minicom -b 9600 -o -D /dev/ttySAC2
NanoPi UART
Sorry, re-reading it sounds like you have. Where have you set up the serial port parameters on the target? I see in here http://elinux.org/Serial_port_programming there is a line: port = serial.Serial("/dev/ttyAMA0", baudrate=115200, timeout=3.0)
Hi every one.... I'm newbie in nanopi 2 fire... I want to config pins and enable UART ability.... But i don't know how i can do this... I used qextserialport library in QT and it recognized usb2serial module perfectly but it couldn't find any built-in UART in Nanopi2 board.... In addition, i can't find any library like WIRINGPI to config and implement UART pins Please help me to fix it.... Tnx
Are you running Debian Jessie? The UART port will have a /dev/tty node associated with it. Maybe, /dev/ttySAC0 I think the process is just telling qextserialport which /dev node to look at. Or are you trying to set up a UART on GPIO, ie not the built-in UART port?
tnx 'davef' for ur quick response. I Purchased a Nanopi 2 Fire and install Jessie on a SD card.actually i'm trying to set up UART on GPIO pins... i want to create a app by QT (C/C++) and send serial data to GPIO .... after that, i want to use a RS232 module to send the received data from GPIO to PC... i have done it by USB-SERIAL module but not GPIO.... How can i config or set up UART on GPIO? i'm unable to find any useful link or source code to set up UART on GPIO... tnx so much.
in the Python the code works perfectly but in the c++ i can't any suitable library! The Matrix Library hasn't got any example about UART setting up....
Do you want a UART on GPIO so that you can still use the build-in UART for debugging? Have you searched <termios>?
Tnx davef... I was finally able to set up gpio using Qt...despite the Qextserialport library, qtserialport in qt4 works perfectly.... Tnx again bro
