Hello. Will 64 GB MicroSD cards work with the NanoPi 2? Thanks!
NanoPi 2 64 GB SD
TF Card We Tested3 To make your NanoPi 2 boot and run fast we highly recommand you use a Class10 8GB SDHC TF card or a better one. The following cards are what we used in all our test cases presented here: SanDisk TF 8G Class10 Micro/SD TF card: SanDisk MicroSD 8G; SanDisk TF128G MicroSDXC TF 128G Class10 48MB/S; so ,of course ,you can use 64GB MicroSD card work with NanoPi 2 .
I try'ed it. No any problem After boot procedure you can resize disk - increase free space by this command == Extend NanoPi 2's TF Card Section For Debian Please run the following commands on a PC host's terminal: sudo umount /dev/sdx sudo parted /dev/sdx unit % resizepart 2 100 unit MB print sudo resize2fs -f /dev/sdx2 For Android Please run the following commands on a PC host's terminal: sudo umount /dev/sdx sudo parted /dev/sdx unit % resizepart 4 100 resizepart 7 100 unit MB print sudo resize2fs -f /dev/sdx7 (Note: you need to replace "/dev/sdx" with the device name in your system) ==
