hello i am facing issue last 2 days.. df -h Filesystem Size Used Avail Use% Mounted on /dev/sda6 285G 285G 0 100% / udev 2.0G 12K 2.0G 1% /dev tmpfs 392M 864K 391M 1% /run none 5.0M 0 5.0M 0% /run/lock none 2.0G 48M 1.9G 3% /run/shm it shows disk space is full but i am using less space out of 285GB? how it can be fix? plz anyone tell me... thanks
No space left on device
i am using ubuntu 12.04 32 bit when i start my pc and login to my user it shows following window ==> "the system is running in low-graphics mode" ==> your screen,graphics card and input device setting could not be detected correctly.you will need to configure these yourself. in my pc there are 2 os first windows 7 and second ubuntu 12.04..my windows is properly running but when i login to ubuntu it shows above message i cant access to it cant be fix....
Would be better to ask on ubuntuforums. Are you able to check trash? Do you have gparted on your Ubuuntu distro and can you access it? Were you ever able to run Ubuntu after installing it?
hello i assembled the new pc and work. but i cant access data in my old pc because of error but when i type ctrl+alt+F2 then i got terminal when i type command df -h it show fullspace /dev/sda6 285G 285G 0 100% / udev 2.0G 12K 2.0G 1% /dev tmpfs 392M 864K 391M 1% /run none 5.0M 0 5.0M 0% /run/lock none 2.0G 48M 1.9G 3% /run/shm and when i update or upgrade pc sudo apt-get install or sudo apt-get upgrade it cant update.
Seeing as you have access to the command line, maybe try: cd / ls -la then you will see all the directories in root, maybe /home has too much on it. Maybe /var/log has become LARGE, although I thought logs were automatically pruned to keep them under control. So, have you got some extremely large directories? Also, you didn't answer my questions ... which will limit my ability to figure out what could be wrong.
now automatic i have login to my user account but when i execute the command it shoe more space to occupied instead it is free.. sometime error show and some time not sachin@Atishay:~/ltib$ df -h Filesystem Size Used Avail Use% Mounted on /dev/sda6 285G 253G 30G 90% / udev 2.0G 4.0K 2.0G 1% /dev tmpfs 392M 864K 391M 1% /run none 5.0M 0 5.0M 0% /run/lock none 2.0G 17M 1.9G 1% /run/shm
sachin@Atishay:/$ ls -la total 104 drwxr-xr-x 24 root root 4096 Dec 25 12:49 . drwxr-xr-x 24 root root 4096 Dec 25 12:49 .. drwxr-xr-x 2 root root 4096 Nov 3 15:53 bin drwxr-xr-x 3 root root 4096 Nov 3 15:56 boot drwxr-xr-x 2 root root 4096 Sep 23 16:58 cdrom drwxr-xr-x 15 root root 4420 Dec 31 12:31 dev brw-r----- 1 root root 8, 6 Dec 23 15:06 devsda3 drwxr-xr-x 145 root root 12288 Dec 31 12:30 etc drwxrwxrwx 3 root root 4096 Nov 18 17:12 home lrwxrwxrwx 1 root root 33 Sep 23 17:06 initrd.img -> boot/initrd.img-3.11.0-15-generic lrwxrwxrwx 1 root root 34 Sep 23 16:56 initrd.img.old -> /boot/initrd.img-3.11.0-15-generic drwxr-xr-x 22 root root 4096 Nov 3 15:53 lib drwxr-xr-x 2 root root 4096 Nov 26 12:17 lib64 drwxr-xr-x 11 root root 4096 Dec 21 15:20 media drwxr-xr-x 3 root root 4096 Oct 15 18:17 mnt drwxr-xr-x 4 root root 4096 Dec 23 13:00 opt dr-xr-xr-x 186 root root 0 Dec 31 2015 proc drwx------ 13 root root 4096 Nov 24 13:23 root drwxr-xr-x 19 root root 680 Dec 31 12:30 run drwxr-xr-x 2 root root 12288 Dec 25 10:25 sbin drwxr-xr-x 2 root root 4096 Mar 5 2012 selinux drwxr-xr-x 2 root root 4096 Feb 4 2014 srv dr-xr-xr-x 13 root root 0 Dec 31 2015 sys drwxrwxrwt 11 root root 12288 Dec 31 12:40 tmp drwxr-xr-x 3 root root 4096 Dec 18 16:49 tools drwxrwxrwx 17 root root 4096 Nov 18 11:37 usr drwxr-xr-x 13 root root 4096 Dec 25 13:15 var lrwxrwxrwx 1 root root 30 Sep 23 17:06 vmlinuz -> boot/vmlinuz-3.11.0-15-generic
after entering via ctrl+alt+f2 i clean some unnecessary data and files. which create some temporary empty space so that i can login as normal user then i removed all data on trash. but again in doing sudo apt-get update or upgrade same issue appears. also on my system i am using windows 7 along with ubuntu 12.04 in my case when i log in using windows it works perfectly. i am not sure is it issue regarding disk partition where my ubuntu tooks some extra space as required
On 2nd thought looking at the size of directories is going to be a long painful process. Try: sudo apt-get install minicom (which you probably already have) does it say you have it? apt-get uses a list in/etc/apt called sources.list (I think) Can you ping www.google.com ? What is the error message you get when you apt-get update ?
now when i enter command from net ->sudo apt-get install --reinstall ubuntu-desktop ->sudo reboot ->sudo apt-get update ->sudo apt-get upgrade it execute succesfull and now i am check ->df -h sachin@Atishay:~$ df -h Filesystem Size Used Avail Use% Mounted on /dev/sda6 285G 200G 83G 71% / udev 2.0G 4.0K 2.0G 1% /dev tmpfs 392M 864K 391M 1% /run none 5.0M 0 5.0M 0% /run/lock none 2.0G 44M 1.9G 3% /run/shm
but now space is automatic full again slowly==> sachin@Atishay:~$ df -h Filesystem Size Used Avail Use% Mounted on /dev/sda6 285G 221G 62G 79% / udev 2.0G 4.0K 2.0G 1% /dev tmpfs 392M 864K 391M 1% /run none 5.0M 0 5.0M 0% /run/lock none 2.0G 83M 1.9G 5% /run/shm
1) Try your install again 2) Disconnect yourself from the net and observe /dev/sda6 3) There is a good chance this has happened to someone else, so again search the Ubuntu forums
> erase old and install new one ubuntu, what ... desktop? and it didn't work the previous time ->sudo apt-get install --reinstall ubuntu-desktop Or, did you do a complete ubuntu install?
yes i have completely remove old one and install new... this command "sudo apt-get install --reinstall ubuntu-desktop" solved the error of "the system running in low graphics mode" only but the space issue remains same thats why i install new....now it works properly.
