Hi every one.I want to connect RFID reader to mini 2440 as USB serial port. But when it connected to mini2440, always has beep sound and the led on it is red then green , then red then green and ..... When I open the "Serial Port Assistant" on mini2440 and connect to /dev/ttyUSB0 on 9600 baud rate. then after each beep it sends (0000000000) to mini2440each beep after 1 second occurred. How can i solve this problem. why this device say beeps and send data 000... repeatedly?( when i put the card on it it sends data correct but when no card on it, it again says beep after each second and send 000000 to mini2440)
connect RFID card reader to mini2440
hello, If you want to use RFID , you can use the RFID serial module ,and then you can read values of RFID.
