I am unable to connect my nanopi the Internet, set up the wifi as teaches the site, but still is not working wifi. wlan0 Link encap:Ethernet HWaddr 04:e6:76:71:52:8e inet addr:192.168.43.10 Bcast:192.168.43.255 Mask:255.255.255.0 BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:69 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:13430 (13.1 KiB)
nano does not connect on the internet.
There is a description on their other site: friendlyarm.com Basically: turn-wifi-into-ap-mode off it will tell you to reboot but it looks like you got this far. And then maybe: systemctl daemon-reload Then try: arp -a route -n wpa_cli -iwlan0 scan_result and post the results.
Results: root@nanopi:~# arp -a ? (192.168.100.207) at 36:86:f5:4c:41:48 [ether] on usb0 root@nanopi:~# route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.100.0 0.0.0.0 255.255.255.0 U 0 0 0 usb0 root@nanopi:~# wpa_cli -iwlan0 scan_result bssid / frequency / signal level / flags / ssid 00:04:df:8e:05:77 2412 -72 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS] JRG1 00:21:91:70:e9:e4 2437 -76 [WEP][ESS] JRG 1c:af:f7:5a:2a:1a 2417 -89 [WPA-PSK-TKIP][ESS] Not Found 404 I own two access points here at home, JRG1 and JRG, the configuration I did was to access the JRG1 point, but I can not. Does the setting is right? /etc/network/interfaces.d/wlan0 auto lo iface lo inet loopback auto wlan0 iface wlan0 inet dhcp wpa-driver wext wpa-ssid JRG1 wpa-ap-scan 1 wpa-proto RSN wpa-pairwise CCMP wpa-group CCMP wpa-key-mgmt WPA-PSK wpa-psk xxxxxxxx
Re-reading your original post I see that you have an IP address of 192.168.43.10 Where did that come from? Confirm that you did: turn-wifi-into-ap-mode off And check with: cat /sys/module/bcmdhd/parameters/op_mode Can you get the NanoPi closer to the router you want? Just during setup and then see if it still works in the current location. Your setup is similar to mine. Did you manage to SSH into the unit before trying to connect to the internet?
I typed the command cat / sys / module / bcmdhd / parameters / op_mode and the result is 0 as you can see below: wlan0 Link encap:Ethernet HWaddr 04:e6:76:71:52:8e inet6 addr: fe80::6e6:76ff:fe71:528e/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:33 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:7110 (6.9 KiB) root@nanopi:~# cat /sys/module/bcmdhd/parameters/op_mode 0 root@nanopi:~# apt-get update Err http://wiki.friendlyarm.com jessie InRelease Err http://wiki.friendlyarm.com jessie Release.gpg Could not resolve 'wiki.friendlyarm.com' Err http://ftp.us.debian.org jessie InRelease Err http://ftp.us.debian.org jessie Release.gpg Could not resolve 'ftp.us.debian.org' ^Cading package lists... 10% I am with my nanopi near the router and still is not connecting. Will be any problem in the configuration?
I can connect via ssh on my nanopi without the internet, as the result below: jgomes@ubuntu:~$ ssh root@192.168.100.1 root@192.168.100.1's password: The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Jan 1 12:02:12 2015 from 192.168.100.207
After a lot of messing around I finally connected up a UART to serial converter and watched the boot-up messages. You will probably see a place where it pauses and counts up to 1 minute 40 seconds then proceed ... that indicates that you didn't connect. Also, when you do a: turn-wifi-into-ap-mode off you will be told that a systemctl daemon-reload is recommended. When I did that it finally connected. I had further struggles every time I changed to a different router. It felt like something was not accepting the new router until I messed around for another length of time. When it works it seem to keep working, which is helpful :)
Ah, yes I had some issues until I finally followed the tutorial and did a: apt-get update Suggest you sort that first.
Check up can ping http://wiki.friendlyarm.com
Were you able to connect to the internet following this site configuration: http://wiki.friendlyarm.com/wiki/index.php/NanoPi#Setup_Wi-Fi
In nanopi file system I can surf, but I can not connect to the Internet by wifi nanopi. I did the ping and see the result: root @ nanopi: ~ # ping http://wiki.friendlyarm.com ping: unknown host http://wiki.friendlyarm.com
Sorry, I wasn't paying full attention ... you can't do apt-get upgrade UNTIL you get connected to the internet.
