How I install Google apps and Google account in Nanopi2. I tried install google play and google play services from apk but not success. Nanopi2 Android 5.1.1
Install Google apps
I can't do it. I trye'd install from the resource http://www.apkmirror.com/ - there is a lot of popular apps Don't forget to enable in the setup option - permission to download from "unknown sources"
I attribute this to the fail too. It was necessary to provide holes for planting of the cooler. I Noticed that when it heated, the processor starts work with errors
Too bad than my Orange Pi PC with full Android and Google Play services. I add a small heat sink, I want a big heat sink but space is too close. Friendlyarm is bad of supporting and small community :(
Welcome to real world - the сhinese IT-industry ! Programs fundamentally do not run, the hotline does not speak English, at the slightest problems - personal leaved any contacts disappear from address , and as standard - no any guarantee. I had to buy on Aliexpress - although you could start a dispute and return me my money. As well - found piece of metal and a screen for $75 you can safely throw out - you are "cheated". I have regretted that did not buy normal Raspberri pi2 - speed is the same but much more convenient with programs and support...
@sdobridnuk: Yes. Chinese is Chinese, lack of everything. I also have a RP2 but It does not run Android :(. I can't install GAPPS.
On the PR2 platform you can run over 33 (!) operation systems. And android too. see http://www.cyanogenmod.org/
RP2 can't run smooth Android because of no Driver Hardware Graphic Acceleration. NanoPi2 is too hot when play video 720p 1080p and auto shutdown. Bad
hello, NanoPi 2 is openc source ,you can down load the source code in github: https://github.com/friendlyarm . The source code of nanopi 2 donot integration Google Play, but you can download ,nanopi 2 supports oogle Play .
