Clean virtual terminal in Proteus
Sushil Kumar
Hello
I am new here, recently I working in Proteus using LPC2138 micro-controller
and make the programs in keil.
I connect virtual terminal with LPC2138 and i able to transmit string to
virtual terminal,
but i am not able to clean the virtual terminal.
Is any command in C program which clean the virtual terminal?
Here is code i c program:
#include <LPC213X.H>
#define in1 (1<<3)
#define in2 (1<<4)
#define in3 (1<<5)
#define in4 (1<<6)
void delay(unsigned int m)
  T0MR0 = 3000*m;
  T0MCR = 0x04;
  T0TC = 0x00;
  T0TCR = 0x01;
  while(T0TC < T0MR0);
  T0TC = 0x00;
void ser_tx(unsigned char ch)         // transmiter
  U0THR = ch;
  while((U0LSR & (1<<5)) == 0);
char ser_rx()                // receiver
  unsigned char ch;
  while((U0LSR & (1<<0)) == 0);
  ch = U0RBR;
  return(ch);
void ser_str(char *ch)
  while(*ch != '\0')
    ser_tx(*ch++);
int main()
  //char buffer[100];
  char ch;
  IODIR0 = 0xff;
  U0LCR = 0x83;  //  Enable DLAB and using 8-bit character lengh
  PINSEL0 = 0x05;  // assign the PINs RX and TX for UART0
  U0DLM = (unsigned int)((3000000/(16*9600))/256);   // calculate baud rate
for MSB
  U0DLL = (unsigned int)((3000000/(16*9600))%256);   // calculate baud rate
for LSB
  U0LCR = 0x03;  // Disable the DLAB, for protect the further changes to
these values
  U0FCR = 0x07;  // Enable and reset TX and RX FIFO
  ser_str("1. First Motor Rotate\r");
  ser_str("2. Second Motor Rotate\r");
  ser_str("3. Both Motors Anti-rotation\r");
  ser_str("4. Both Motors Stop\r");
  ser_str("Enter your choice for motor rotation\r");
  ser_str("Choice= ");
  while(1)
    ch = ser_rx();
    ser_tx(ch);
    switch(ch)
      case '1':
            IOSET0 = in1;
            IOCLR0 = in2;
          //  delay(250);
            break;
      case '2':
            IOSET0 = in3;
            IOCLR0 = in4;
          //  delay(250);
            break;
      case '3':
            IOSET0 = in2;
            IOCLR0 = in1;
          //  delay(250);
            IOSET0 = in4;
            IOCLR0 = in3;
          //  delay(250);
            break;
      case '4':
            IOCLR0 = in2;
            IOCLR0 = in1;
          //  delay(250);
            IOCLR0 = in4;
            IOCLR0 = in3;
          //  delay(250);
            break;
      default:
            ser_str("\rSorry! Your choice is wrong\r");
            break;
